Keyboard Forums
Reply
Thread Tools Display Modes
Beginner need help choosing a keyboard
Newbie
      08-24-2010
I mainly want a keyboard for making beats and stuff like that. My budget is around $300 but I can go a little higher if necessary. I have no experience with any musical instruments. Thanks for any help.
Keyboard Master
Burn4Him's Avatar
Send a message via Skype™ to Burn4Him
      08-24-2010
hello.....ok for 300 bucks your gonna have to get something used and in bad shape..... your best bet is going with software like reason or if you want to go cheaper use fruity loops. i dont think you can even find a used keyboard that will make halfway decent beats for that price.
I suppose you can try to find a beat up mm6 but i would not suggest it.
HIS Kingdom Come, HIS Will be Done!
www.neorising.com
Newbie
      08-24-2010
Software isn't an issue for me but in terms of hardware, I thought I would able to get something good for 300. Are the M-Audio Axiom series any good? If I can't get anything good for that price I may just get an electric guitar.
Keyboard Master
Burn4Him's Avatar
      08-25-2010
the axioms are actually awesome but they are midi keyboards if you want to make beats on your computer using a keyboard then yeah it will work but on its own it makes no sound. it only transmits a midi signal.
www.neorising.com
Newbie
      08-25-2010
Which size would be best for the axiom?
Keyboard Master
Burn4Him's Avatar
      08-25-2010
well thats personal preference however if you have no musical exp. 49 should be ok
www.neorising.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help Choosing Keyboard Amp WILL237 Keyboard Purchase Recommendations 1 05-07-2010 05:47 PM
OT: Studio Ergonomics Matt Koskenmaki cakewalk.audio 10 06-04-2009 05:41 AM
Keyboard Controller for Piano Beginner woldsweather General Keyboard Discussion 4 02-05-2008 09:39 PM
Beginner: which keyboard size is best? Sacipyta General Keyboard Discussion 1 10-08-2007 12:07 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
