Keyboard Forums
Reply
Thread Tools Display Modes
help- a bit clueless
Resident
      08-23-2010
I've been playing about 20 years but mostly live shows- I own a Kurzweil PC88 and Korg M50. Currently that is all I can carry around to live gigs. I'm in need of more sounds since I MIDI the 2 together but sometimes find myself needing another patch. What is my best option for more sound patches? Do I go with something like a Rack-mounted unit like the Motif and MIDI that in- or can I use something like a computer laptop and software to get more sounds/patches?? I wasn't sure if I could use a software package to find unique sounds and download them into the KORG.- I don't want to much technical stuff to do during a live gig- so the simpler the better to give me more options without lugging around another board
Keyboard Master
Burn4Him's Avatar
Send a message via Skype™ to Burn4Him
      08-23-2010
your best bet is probably a rack unit. the motif rack would suit your needs.
but if you decided you wanted to go a little crazy and splurge a bit and get something completely awesome try this on for size
http://www.museresearch.com/
check out the receptor
HIS Kingdom Come, HIS Will be Done!
www.neorising.com
Keyboard Addict
elwoodblues1969's Avatar
      08-23-2010
I whole-heartily agree,having a module to store you computer software patches gives you infinite possibilities & will completely eradicate your problem.
The Muse Receptors are very pricey(around $1,500 to $2,000 I believe),but I really think it would be worth selling your Korg M50 if you needed to and just use you Kurzweil as a midi controller and go hog-wild!
-Elwood
Keyboard Master
Burn4Him's Avatar
      08-23-2010
haha yah elwood is right i should have asked for your budget first lol they are crazy pricey
www.neorising.com
Keyboard Addict
      08-23-2010
Here's a link to gives you a good overview of what you'd be looking at,price-wise;
http://www.fullcompass.com/search.ph...FYxU2godMjY-wA
-Elwood
Resident
      08-23-2010
wow- more than I wanted to spend but looks like a nice toy- I want to keep the M50 since I like having 2 boards to play live. (You never know when something does not want to work!)-
How does that device work? you just MIDI into it and you can play all those sounds thru any board?
Keyboard Master
Burn4Him's Avatar
      08-23-2010
yeah you can plug midi into it or you can use it threw your existing DAW and blow your options way open!
www.neorising.com
Super Moderator
goz211's Avatar
      08-23-2010
Quote:
Can you be more specific about what sounds you want that the PC88 and M50 don't have?
Resident
      08-24-2010
well maybe I just need some help- I MIDI the 2 boards together for most songs. However I use the PC-88 mostly for piano (has the 88 keys and the feel)- There are times I need to use specific sounds from the M50 (banjo-fiddle etc)- and then I need a better organ sound from the PC88 and there its a bit limited. So I would like to also play the 2 boards independently at times- (using the M50 with a specific sound solo)- and then I need better sounds (non piano) out of the PC88- So if I had the PC88 MIDI'ed to another module- I could get more sounds when needed....make sense?
Keyboard Master
Burn4Him's Avatar
      08-24-2010
if you just want a sweet organ sound hammond makes a sweet midi module with drawbars its pretty cool and sounds great!
ps. whats your budget?
www.neorising.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
