Keyboard Forums
Reply
Thread Tools Display Modes
Need keyboard recommendation! Help!!!!
Newbie
      02-01-2010
I need a keyboard that can plug into a computer and retrieve synth/alternate keyboard sounds from programs such as Logic or Reason....preferably 61 keys semi weighted or weighted.
what is out there for me? i can't find anything that got great reviews.
budget is about $500-600
thanks all,
mitchell
Keyboard Addict
evergreenthompson's Avatar
      02-02-2010
Your best bet is probably to peruse Guitar Center (http://www.guitarcenter.com/), Musician's Friend (http://www.musiciansfriend.com/), Sweetwater (http://www.sweetwater.com/), and any stores near you to see what's available in your price range.
I don't think you're going to find much for weighted and semi-weighted in 61 keys in your price range, though.
Korg M50-88 | KARMA M50, ACID Music Studio, Audacity, MuseScore, MS Songsmith | Windows 7 Ultimate 64-bit on Gateway P-7805u FX
Resident
      02-08-2010
Do you need the computer to have sounds? If not, look at a midi controller. M-audio makes the Axiom and the Axiom Pro (the main difference being a feature called hyper-control; youtube axiom pro to see what that's about). Those would be in your price range.
The Novation Remote Sl and Compact Remote would also be in your range. Also, the Studiologic VMK-161plus and VMK-161org controllers. Most of these are semi-weighted (the studiologic VMK-161plus is fully weighted, whereas the VMK-161org is a waterfall semi-weighted organ-style keyboard).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Creating A Two-Keyboard MIDI Setup kanthos MIDI 25 11-19-2009 01:05 PM
Sub $1000 keyboard recommendation jordanstreet Keyboard Purchase Recommendations 1 10-08-2008 09:57 AM
Need a Keyboard Recommendation Pastor Jeff General Keyboard Discussion 16 12-23-2007 09:36 PM
Looking to buy a keyboard. I need help. shirtless General Keyboard Discussion 0 10-17-2007 12:05 AM
Casio noisey keys- need advice on new keyboard gotalien General Keyboard Discussion 1 09-27-2007 08:02 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
