Keyboard Forums
Reply
Thread Tools Display Modes
Separating a sound effect from a song... Need help :(
Keyboard Master
Sargas's Avatar
      04-13-2009
I've found a quite funny sound in a song, and I want to separate it from the rest of the song, so that I have that sound only, without the other instruments... Here's the sound
@ 5.56
I've tried just cutting the song, but the piano enters before the sound has finished fading, and I don't want to have the piano...
Any help is appreciated.
Thanks in advance
Keyboard Addict
Mourndark's Avatar
      04-16-2009
Ah yes, Jordan's whistle sound...
It turns up in a few of his solos (Scenes from New York, ...Seasons springs to mind), although as you say it might be difficult to extract. I'll have a listen to some others to see if it's better. In the meantime, you might try a high-pass filter applied to the end of the clip to cut out the lower freq piano part. Start at about 10KHz then gradually turn it up from there would be my advice.
Keys: Roland Fantom X8, M-Audio ProKeys 88SX, Roland JP-8000, Custom Keytar, Collard & Collard Upright
Software: Cubase SX3, Sibelius 5
Other: Roland XV-5080, Yamaha StagePAS 150, Custom Laser Harp, Stylophone
Ask Me About: All the above, MIDI, Performing Broadway Musicals
Keyboard Master
      04-17-2009
That sound's called a slide whistle; I bet you could find it somewhere though.
For that matter, I don't know the name of the track that the honky-tonk and slide whistle excerpt is from, but I know I've seen it on the Jordan Rudess Online Conservatory, in the section of the site where he has some clips up from his Keyboard Madness DVD. In that clip, he's going through his own parts, so there might be an exposed version of the slide whistle you could sample.
Really though, it's a common enough sound, so I bet it'd be easy enough to find somewhere else too.
Keyboard Rig: Nord Stage 73, Korg TR-61, Roland KC-150, Behringer MX-400
Computer: Dell Laptop, 2.4 GHz dual-core, 2 GB RAM, Edirol UA-25
Software: Cubase, Absynth, FM8, Sylenth, Prophet V, Kontakt 3, Battery 3, Kore 2
Have questions? Read this first
Keyboard Master
Sargas's Avatar
      04-18-2009
Okey, I'll start off with searching for if I can find the sound somewhere, where someone has already done the job for me :P
If that doesn't work, I'll see if I have a program that can cut out specific frequencies, if not, I guess I just have to get one :P
Thanks for the answers
EDIT: Just found a site with TONS of different slide whistles.... Will take some time to look through them all, but it might be in there somewhere
Here's the site, if anyone else is interested: http://www.audiosparx.com/sa/display..._group_iid.994
EDIT 2: Just noticed that you have to pay for the sounds
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
grudgy blues sound effect dlevanchuk General Keyboard Discussion 0 11-05-2009 08:18 AM
sound effect dlevanchuk General Keyboard Discussion 1 11-05-2009 08:17 AM
Finding the right sound for each song Bren General Keyboard Discussion 2 09-02-2009 12:52 AM
Motion Sound KP200s Stereo KB Amp stef823 Keyboard Classifieds 0 04-09-2009 11:07 PM
Pure sound keyboard Przemo(c) General Keyboard Discussion 2 01-09-2008 05:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
