A cool little freebie plug-in - DSK miniDRUMZ 2
Discussion in 'alt.steinberg.cubase' started by SODDI, Mar 16, 2009.
  1. SODDI Guest
    Message Count:
    http://www.dskmusic.com/blog/?p=105
    Basically a vintage drum machine ROMpler. Very light on your CPU, easy to
    use. NO CHOICES TO MAKE.
    I use it to sketch out drum parts before I assign final drum sounds - or
    not, as the case may be.
    I can't vouch for the versimilitude of the drum kits, having not owned all
    the machines in question. But they sound good. (In version 1, the levels
    were too low).
      • Advertising
  2. Rev. Diva Schematic Guest
    Message Count:
    > were too low).
    Have they ramped up the sound? MiniDrumZ (along with one or two other
    DSKs) seemed really quiet and needed real pumping up to fit them into a mix.
  3. SODDI Guest
    Message Count:
    "Rev. Diva Schematic" <> wrote in message
    news:gpm9kq$bn1$...
    >> all the machines in question. But they sound good. (In version 1, the
    >> levels were too low).
    > mix.
    Yes.
  4. Rev. Diva Schematic Guest
    Message Count:
    > news:gpm9kq$bn1$...
    >> mix.
    > Yes.
    Lovely, I will have a go with these then, ta!
      • Advertising
  5. SODDI Guest
    Message Count:
    news:gpmct9$agv$...
    >> news:gpm9kq$bn1$...
    >>>> to use. NO CHOICES TO MAKE.
    >>>> or not, as the case may be.
    >>> mix.
    >> Yes.
    Make sure you get 2WarpDelay, too. (My fave)
    http://dsp.mutagene.net/?pid=projects
    It makes crazy feedback.
  6. David Carl Guest
    Message Count:
    >were too low).
    All of the plug ins on that page seemed pretty cool for me. I am just
    getting started with Cubase (LE4, came with my Alesis). What I have
    noticed is that each plug in on that page is already set up for a
    distinct output and not all plug ins are set up for the same output or
    more precisely, the one I have set up for my project. Some of the plug
    ins bring a message when I try to use them that there won't be any
    output because another output was expected. Of course I can change the
    output of the project to match the plug in, but that seems a bit back
    asswards. Any way to change the output of the plug in? Most seem to be
    just .dll files. Be easy on me now, just getting started. Remember how
    that was?
  7. SODDI Guest
    Message Count:
    <David Carl> wrote in message
    news:49c7cb6e$0$31429$4all.se...
    >>were too low).
    > that was?
    Yep.
    The plug-ins that return that kind of message are USUALLY older VST plug-ins
    with mono output that do not adhere to the new VST 2.0 format. But the DSK
    plug-ins may have a different kind of problem
    I haven't had any problems with the DSK synths.
  8. lancelightning Guest
    Message Count:
    I do like this...a very useful tool for a quick drumset to write with.
    Some of the machines emulated here bring back memories.. Cheers LL
    >were too low).
  9. David Carl Guest
    Message Count:
    >>>were too low).
    >> that was?
    >Yep.
    Either way, a plug in output cannot be changed?
    The ones that work, work well with my EMU XBoard.
  10. SODDI Guest
    Message Count:
    news:49c8df18$0$31427$4all.se...
    >>>>to
    >>>>all
    >>>>were too low).
    >>> that was?
    >>Yep.
    >>plug-ins
    I think the outputs are written into the code. Some of these work in older
    versions of Cubase, so if you have one running like I do (3.75), don't get
    rid of them - move them over to the old version.
      • Advertising
Share This Page
