Acronis Partition Manager ???
Discussion in 'cakewalk.audio' started by Steve_Karl, Apr 23, 2010.
  1. Steve_Karl Guest
    Message Count:
    Anyone using it ? Reviews ?
    How about the "bootable media" ... will it create a bootable rescue CD or even possibly
    a bootable rescue thum drive ???
    Are there any free ones that you know off that are good and will create bootable CD or ideally flash drive?
    Thank you,
    Steve Karl
      • Advertising
  2. John Braner Guest
    Message Count:
    > Thank you,
    > Steve Karl
    Steve,
    It works fine here - although it doesn't run on 64 bit windows :-\.
    It works great from the rescue CD though - and I also use the Acronis boot manager, so you can run
    the partition manager from there ie before you boot into a partition. I'm not sure if it works with
    a USB drive, but it works fine from a CD.
    John Braner
    http://cdbaby.com/cd/JohnBraner
    http://www.soundclick.com/johnbraner
  3. Steve_Karl Guest
    Message Count:
    "John Braner" <> wrote in message news:hqs7k9$804$-september.org...
    >> Thank you,
    >> Steve Karl
    > Steve,
    > It works great from the rescue CD though - and I also use the Acronis boot manager, so you can run the partition manager from
    > there ie before you boot into a partition. I'm not sure if it works with a USB drive, but it works fine from a CD.
    > John Braner
    Thanks John!
    Steve
  4. Phoenix Guest
    Message Count:
    On Fri, 23 Apr 2010 10:52:57 -0400, "Steve_Karl" <>
    > >> Thank you,
    > >> Steve Karl
    > > Steve,
    > > John Braner
    > Thanks John!
    > Steve
    I have Acronis Backup and I know once you buy it you can download the
    rescue media as an ISO file so you don't even have to install; think
    I had to pay a fee for that though. But partition Manager is probably
    the same way.
    You may also want to check out Paragon Hard Disk Manager. I'm still
    learning this program since it came with my new laptop but it runs on
    64-bit, and when I checked out their forum I was struck by the prompt
    response time and relative lack of complaints...
      • Advertising
  5. Ben Goldman Guest
    Message Count:
    Steve_Karl let loose with the following tirade:
    > flash drive?
    > Thank you,
    > Steve Karl
    YaST (think Control Panel) repartitioned my NTFS just fine and it's free.
    Free downloads of Live CD ISO and full blown DVD ISO.
    http://software.opensuse.org/112/en
    openSUSE supports PCs with 32 Bits and 64 Bits.
    Live GNOME
    A GNOME desktop you can run from CD or from USB stick.
    4.7GB DVD
    Contains a large collection of software for desktop or server use. Suitable for installation or
    upgrade.
    Cheers,
    Ben
  6. Sue Morton Guest
    Message Count:
    Paragon's a good product, I use it. I use Easeus too, it fixed one
    system Acronis and Paragon couldn't.
    IMO you can't have too many tools for fixing problems with partitions,
    boot sectors etc. As Ben mentioned, the unix based cd's, also Ultimate
    Boot CD for Windows, BartPE, WinPE, etc. are all good to have at hand.
    Whatever works is what you should use :)
    Sue Morton
    "Phoenix" <> wrote in message
    news:-september.org...
    >> >> Thank you,
    >> >> Steve Karl
    >> > Steve,
    >> > John Braner
    >> Thanks John!
    >> Steve
    > rescue media as an ISO file so you don't even have to install; think I
    > the same way. You may also want to check out Paragon Hard Disk
    > Manager. I'm still learning this program since it came with my new
    > laptop but it runs on 64-bit, and when I checked out their forum I was
    > struck by the prompt response time and relative lack of complaints...
  7. Ben Goldman Guest
    Message Count:
    Sue Morton let loose with the following tirade:
    > IMO you can't have too many tools for fixing problems with partitions, boot sectors etc.
    You're dang skippy! ;-)
    Cheers,
    Ben
      • Advertising
Share This Page
