Advanced latency busting for virtual instruments - any tips?
Discussion in 'alt.steinberg.cubase' started by XODDI, Mar 11, 2010.
  1. XODDI Guest
    Message Count:
    Windows XP Pro SP3
    Intel Core 2 2.4
    2 G RAM
    Cubase Studio 4, latest rev 4.5?
    Echo Audio Fire vers 4.8
    Got this running at 11.6 msec latency, it's the best I can comfortably do -
    10.2 makes things a little unstable around the edges.
    My main problem now is with th NI Komplete suite - Battery, Kontakt, FM8,
    Absynth, Massive.
    They seem to feel "mushy" - i.e., with even a bit more latency from MDI
    note-on than other VSTis, including a standalone installation of Reaktor.
    They record and render OK from a MIDI track, but I am over-compensating for
    the "mushiness" in playing and it is showing up in the MIDI recordings.
    Am I making any sense?
      • Advertising
  2. Hueyduck Guest
    Message Count:
    XODDI a écrit :
    > Windows XP Pro SP3
    > Intel Core 2 2.4
    > 2 G RAM
    > do - 10.2 makes things a little unstable around the edges.
    The latency you can set depends on the quality of your audio card and
    the quality of its driver.
    The latency you will be actually able to use (eg without cracks and pops
    and shcrounch) depends on the power of your PC, its ability to give all
    of its power to the background tasks without being interrupted (here
    lies the importance of the many audio tweaks for XP you can find on the
    net), and again, the quality of the driver of your audio card.
    When RME upgraded their driver vrom 2.9 to 3 for the hammerfall series,
    many users gained something like 30% speed, latency-wise. I mean that
    with the same hardware, they were able to lower their latency and still
    play scrounchless tune.
    > FM8, Absynth, Massive.
    > Reaktor. They record and render OK from a MIDI track, but I am
    > over-compensating for the "mushiness" in playing and it is showing up in
    No, it's not :)
    Actually, 2 things are not making sense:
    The latency you are currently achieving is what I had with my old AThlon
    2000+ (one core @ 1.7 GHz ! ).
    With a core2 quad Q9550, I can start working with a 1.5ms latency. I
    finish many projects, with effects, midi, VSTi, streaming, etc... @ 6ms
    latency.
    I even can make a simple vocal recording with 0.75 (<1ms) latency.
    So a 11 ms latency is a bit disappointing for you hardware. Again: I
    don't know about your audio card or its drivers.
    And from what I know, above 10ms, I start to feel the mushiness,as you
    call it.
    The 2nd thing that doesn't make sense to me is that you would have
    different latency "feeling" with different VSTi.
    My diagnostic would be that you are not using the correct driver.
    Many card have an "ASIO multimedia" driver wich is not the one you want
    to use. You want to use the other drivers featuring "ASIO" in its name.
    Huey
    PS: if you don't find the audio tweaks for XP, and if you do need them,
    just ask. Someone might be able to post them here.
  3. Max Doorrijhoogte Guest
    Message Count:
    On Thu, 11 Mar 2010 19:46:47 +0100, Hueyduck <>
    ......to what kind of audio tweaks are you referring?
  4. Hueyduck Guest
    Message Count:
    This one, for instance:
    Processor scheduling should be set to background services and not Programs.
    Start > Settings > Control Panel > System > Advanced > Performance
    Settings > Advanced
    Tab > Background Services
    Here's the list I apply when I prepare a new PC (taken in 2003 from a
    site called musicxp, or something).
    For consistency, before carrying out the tuning tips suggested below,
    switch to classic view in the
    control panel. To do this, Start > Control Panel > "Switch to Classic View".
    Then, switch to classic view for the menu. To do this, Start > Control
    Panel > Taskbar and Start Menu >
    Start Menu Tab > Classic Start Menu.
    If you require further information on a particular tip, click on the
    associated
    1. Processor scheduling should be set to background services and not
    Programs.
    Settings > Advanced
    2. Visual effects should be set to a minimum.
    Settings > Visual
    Effects Tab > Adjust for best performance
    3. Switch Off Desktop Background Image
    Right Click Desktop > Properties > Desktop Tab > Background None
    4. Disable Screen Saver
    Right Click Desktop > Properties > Screen Saver > None
    5. Disable Fast User Switching
    Start > Settings > Control Panel > User Accounts > Change the way users
    log on or off >
    Untick Use Fast User Switching
    6. Switch Off Power Schemes
    Start > Settings > Control Panel > Power Options > Always On > Turn off
    monitor and turn
    off hard discs to Never
    http://www.musicxp.net/tuning_tips.htm (1 of 4) [26/10/2003 16:32:45]
    Tuning Tips
    7. Switch Off Hibernation
    Start > Settings > Control Panel > Power Options > Hibernate > Untick
    Hibernation
    8. Activate DMA on Hard Discs/CD ROMS
    Start > Settings > Control Panel > System > Hardware > Device Manager > IDE
    ATA/ATAPI Controllers > Right Click Primary IDE channel and Secondary
    IDE channel >
    Properties > Advanced Settings Tab > Transfer Mode to "DMA if available"
    for both
    devices.
    9. Disable System Sounds
    Start > Settings > Control Panel > Sounds and Audio Devices > Sounds Tab
    > Sound
    Scheme to None.
    10. Do Not Map Through Soundcard
    Start > Settings > Control Panel > Sounds and Audio Devices > Hardware
    Tab > (highlight
    your soundcard from the list) > Properties > Audio Devices > (highlight
    your soundcard
    from the list) > Properties, and check the "Do not map through this
    device" checkbox.
    11. Disable System Restore
    Start > Settings > Control Panel> System > System Restore Tab. Tick the
    "Turn off System
    Restore on all Drives"
    12. Disable Automatic Updates
    Start > Settings > Control Panel> System > Automatic Updates > Turn off
    automatic
    updating. I want to update my computer manually
    13. Startup and Recovery Options
    Start > Settings > Control Panel> System > Advanced > Startup and
    Recovery Settings >
    Untick Automatically Restart
    14. Disable Error Reporting
    Start > Settings > Control Panel> System > Advanced > Error Reporting >
    Disable Error
    Reporting
    15. Disable Remote Assistance
    Start > Settings > Control Panel> System > Remote > Untick Allow remote
    assistance
    invitations to be sent from this computer
    http://www.musicxp.net/tuning_tips.htm (2 of 4) [26/10/2003 16:32:45]
    Tuning Tips
    16. Fix Swap File (Virtual Memory)
    Settings > Advanced
    > Virtual Memory Change > Custom Size. Set initial and maximum size to
    the same value.
    17. Speed Up Menus
    Start > Run > Regedit > HKEY_CURRENT_USER > Control Panel > Desktop
    Folder. Set
    MenuShowDelay to 1
    18. Disable Offline Files
    Start > Settings > Control Panel > Folder Options > Offline Files Untick
    "Enable Offline
    Files"
    19. Disable Remote Desktop
    Start > Settings > Control Panel > System > Remote > Untick "Allow users
    to connect
    remotely to this computer"
    20. Disable Internet Synchronise Time
    Start > Settings > Control Panel > Date and Time > Internet Time >
    Untick "Automatically
    synchronize with internet time server"
    21. Disable Hide Inactive Icons
    Start > Settings > Taskbar and Start Menu > Taskbar TAB > Uncheck "Hide
    Inactive Icons"
    22. Disable Automatic Desktop Cleanup Wizard
    Start > Settings > Control Panel > Display > Desktop > Customise Desktop
    > Untick "Run
    Desktop Cleanup Wizard every 60 days"
    23. Disable NTFS Last Access Time Logging (NTFS File Systems Only)
    Start > Run > regedit > HKEY_LOCAL_MACHINE > System > CurrentControlSet >
    Control > Filesystem. Add a new DWORD value -
    "NtfsDisableLastAccessUpdate" and set
    value to 1.
    http://www.musicxp.net/tuning_tips.htm (3 of 4) [26/10/2003 16:32:45]
    Tuning Tips
    24. Disable Notification Area Balloon Tips
    Start > Run > regedit > HKEY_CURRENT_USER > Software > Microsoft > Windows >
    CurrentVersion > Explorer > Advanced. Create a new DWORD value called
    EnableBalloonTips and set to 0.
    25. Disable CDROM Autoplay
    Services > Cdrom. Set autorun to 0.
    26. Disable Disc Indexing Service
    Right Click Start > Explorer > Right Click Each Disc > Properties >
    Untick "Allow Indexing
    Service to index this disc for fast file searching"
    http://www.musicxp.net/tuning_tips.htm (4 of 4) [26/10/2003
    16:32:45]Tuning Tips
    Tuning Tips
    associated
    Programs.
    Settings > Advanced
    Settings > Visual
    log on or off >
    monitor and turn
    Tuning Tips
    Hibernation
    IDE channel >
    for both
    devices.
    > Sound
    Scheme to None.
    Tab > (highlight
    your soundcard
    device" checkbox.
    "Turn off System
    automatic
    Recovery Settings >
    Disable Error
    Reporting
    assistance
    Tuning Tips
    Settings > Advanced
    the same value.
    17. Speed Up Menus
    Folder. Set
    MenuShowDelay to 1
    "Enable Offline
    Files"
    to connect
    Inactive Icons"
    > Untick "Run
    value to 1.
    Tuning Tips
  5. XODDI Guest
    Message Count:
    "Hueyduck" <> wrote in message
    news:4b99397c$0$21858$...
    > XODDI a écrit :
    >> Windows XP Pro SP3
    >> Intel Core 2 2.4
    >> 2 G RAM
    > The latency you can set depends on the quality of your audio card and the
    > and shcrounch) depends on the power of your PC, its ability to give all of
    > its power to the background tasks without being interrupted (here lies the
    > importance of the many audio tweaks for XP you can find on the net), and
    > many users gained something like 30% speed, latency-wise. I mean that with
    > the same hardware, they were able to lower their latency and still play
    > scrounchless tune.
    >> Absynth, Massive.
    >> for the "mushiness" in playing and it is showing up in the MIDI
    >> recordings.
    > No, it's not :)
    > latency.
    > call it.
    > Many card have an "ASIO multimedia" driver wich is not the one you want to
    > Huey
    Hurr durr - I had it configured to run SynCModular without glitches. Remove
    SynC and 2.9 ms is easy. I will tweak further.
    Bye bye SynCModular. I loved you.
      • Advertising
Share This Page
