Anyone have issues with Creative Sound Mixer MIDI volume levels changing?
Discussion in 'rec.music.synth' started by Chris Moyer, Sep 3, 2004.
  1. Chris Moyer Guest
    Message Count:
    Hi, I have an Audigy Platinum. Whenever I try to play MIDI files,
    either on the internet, or in Cakewalk, the volume is always set low-
    perhaps 40% volume. NEARLY EVERY TIME I play a Midi file, the volume
    always defaults to about half. If I put the MIDI volume back up at
    100% in the Sound Mixer, I can listen to maybe 3 or 4 MIDI songs at
    that level. Then, for some reason, the volume goes back to half
    again. This is more of an irritation than anything. I can live with
    it, but if there's a way to set the level so it is always at 100%,
    that would be ideal. Anybody with SBLIVE or Audigy card know how to
    do this? Thanks.
      • Advertising
Share This Page
