Audigy2 vs Audiophile 2496
Discussion in 'alt.steinberg.cubase' started by Jack Jarmush, Nov 12, 2004.
  1. Jack Jarmush Guest
    Message Count:
    ....Now that I have the Audigy hater's attention.... Could you tell me if I
    go out and buy an M-Audio Audiophile 2496 today will I still have
    static/distortion/noise/echo etc. when I run heavy VSTi's(Halion
    Strings)with SX2 on a 2.4 GHz PC with 768 MB RAM?
    I't looks like I will get the 2496 but is the Audigy really the static
    problem?
    Also I am thinking about getting the Ozone midi controller along with the
    built in Audiophile card.........anybody have anything to say about the
    Ozone before I blow my hard earned paycheck.......or would you rather just
    laugh.
    JJ
      • Advertising
  2. Laurence Payne Guest
    Message Count:
    On Fri, 12 Nov 2004 01:56:43 +0100, "Jack Jarmush"
    Maybe. The problem could be several places in your system.
    Echo?
    >problem?
    >laugh.
    If a 2-octave keyboard matches your level of keyboard skill - i.e. you
    aren't really a keyboard player - and you want a compact unit, the
    Ozone could suit your needs. If you're something of a player (or
    hope to be) and if you envisage making music away form your computer
    at all, get the Audiophile card alone and look around for a
    second-hand synth with 5 octaves and some on-board sounds.
    CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
    "Possibly the world's least impressive web site": George Perfect
  3. Jack Jarmush Guest
    Message Count:
    "Laurence Payne" <> wrote in message
    news:...
    I
    > >static/distortion/noise/echo etc. when I run heavy VSTi's (Halion
    > >Strings) with SX2 on a 2.4 GHz PC with 768 MB RAM?
    Thanks for the honest answer. I have tried to optomize my system as best I
    can but do you have any tips.
    > Echo?
    Yeah it is as if the different layers of the sample randomly sound after
    striking a key sort of like echo (not midi echo).
    just
    > >laugh.
    I do have a 88 key Yamaha p-80 digital piano (excellent instrument) but it
    doesn't have a modulation wheel which is needed for Halion String programs.
    I am not a ''real'' piano player/keyboardist but the 2 octave Ozone would be
    used for playing string parts (with the mod wheel) but now that you mention
    it 2 octaves isn't even enough for that so I will take your advise and stick
    to the card a la tarte. BTW I am a ''real'' saxophonist (but that, like
    usual, doesn't help).
    JJ
  4. MArtin Chiselwitt Guest
    Message Count:
    > problem?
    > laugh.
    > JJ
    funny, i am buying one of these today to replace my soundblaster audigy.
    i would b einterested to know how you get on with yours...
    i am never gonna by a creative card again....
      • Advertising
  5. Aphelion Guest
    Message Count:
    Did you try increasing the ASIO buffer?
    Ap
  6. Laurence Payne Guest
    Message Count:
    On Fri, 12 Nov 2004 03:03:53 +0100, "Jack Jarmush"
    Describe your system, from input (mic, guitar etc.) to loudspeaker.
    What is connected to where? How do you set levels?
    Describe your procedure for recording a song.
  7. Niall / Lina Guest
    Message Count:
    No guarantees that an Audiophile will fix your problems. With a reasonably
    high spec PC like yours, you should be able to get the Audigy to work well
    at least with a medium-high latency. If increasing the latency doesnt help,
    then the problem may well lie elsewhere (or it could be a physical problem
    with the card, although this would manifest itself outside of Cubase
    too....)
    Niall
    "Jack Jarmush" <> skrev i meddelandet
    news:cn11ob$jq$...
    > problem?
    > laugh.
    > JJ
  8. Jack Jarmush Guest
    Message Count:
    "Aphelion" <> wrote in message
    > Ap
    I have tried adjusting the ASIO Buffer Latency on the Creative, SB Audigy
    and the dirsctx full duplex ASIO drivers but without any real change.
    If I select low disk streaming at least the crazy echo stops but the crackle
    is just as bad......btw the crackling is only on one stereo side, if I pan
    full right there is no crackling.
    JJ
  9. Jack Jarmush Guest
    Message Count:
    At the moment I have a friends Evolution midi controller hooked up to the
    midi interface to the Audigy2 card via 1 midi in cable.
    I use SX2 with Halion String Player and Halion String Edition programs (of
    course)
    Creative ASIO driver set to 20 ms Latency (have tried up to 500 ms without
    result)
    I open up SX2, add midi track, add VSTi (HSE), load HSE program combi vln
    xfade xxl (one of the heaviest programs), test the program with the on
    screen player/keyboard and get crackles and all sorts of disturbing noise, I
    then try adjusting the disk streaming vs RAM options and when I set it to
    low disk streaming (so mostly using RAM) the echo is gone burt the
    crackling is still there.
    Then I reapeat and go is cicles until I can't take it anymore and go out and
    buy 512 MB more RAM. I shpild have bought two 256 MB RAM chips because
    that's how my motherboard likes it but I will change that today. So I have
    768 MB RAM but still snap, crackle, pop!!!! aaaaaaaaAAAAAAAA!!!
    My com is not dedicated to music, I use it for email, surfing, and just
    about anything I can use it for.....do you think I need to re-format (I hope
    not cause I don't feel confident to do that, the last time I tried on my old
    com I really messed it up).
    Is it normal for SX2 to use + - 250 MB RAM when empty and idle? (on XP)
    I am gonna bump up the RAM to 1GIG and see if that helps......will report
    back.
    JJ
  10. Niall / Lina Guest
    Message Count:
    Only on one side?? That doesnt sound like a typical software problem. Does
    the Audigy have a "reverse stereo" option in the mixer? If so, does
    selecting it shift the problem to another speaker?
    Niall
    news:cn2g13$pkc$...
    > > Ap
    crackle
    > JJ
  11. Jack Jarmush Guest
    Message Count:
    .......well I upgraded to 1 GB RAM and installed a new Audiophile 2496 and to
    my astonishment (not really) it didn't solve anything : -- (
    Remember that old Rice Crispies commercial.....that's what my VSTi's sounds
    like.
    The guy at the shop where I bought the Audiophile was "absolutely sure'' the
    2496 would solve the problem....but he would say that.
    Well now (?215. later) I ask myself...........Did I need the Audiophile
    anyway......yes(so the ?115 spent on that was inevitable).
    Did I need more RAM?.........probably not (so the ?100 spent on that was a
    waste).
    Maybe I'll return the DIMM.....or just change my name to it ;-)
    Will trade unused brain cells for advise.
    JJ
  12. Jack Jarmush Guest
    Message Count:
    in the last post from me the euro sign (as in money) became a ? after
    posting which is quite appropriate.
  13. Niall / Lina Guest
    Message Count:
    Is the problem still only present in one channel?
    Are you using the Audiophile ASIO drivers?
    news:cn324t$bqs$...
    to
    sounds
    > like.
    the
    > waste).
    > JJ
  14. Jack Jarmush Guest
    Message Count:
    "Niall / Lina" <> wrote in message
    The crackling sound is only on one stereo side, the crazed echo is on both.
    I tried changing amps and speakers, tried setting buffer to max and still
    crackling (like a camp fire) . I am using the Audiophile ASIO driver. the
    noise is I think ........well it is worse than with the Audigy. I guess that
    that Audiophile drivers must be better than Creative but why then all the
    noise? I am gettings pops now with the Audiophile, something I didn't get
    with the Audigy. This is driving me nuts.....I just want to work on music
    not all this wasting time and money on a fantasy of being able to make good
    string sounds from a PC.
    ....a personal note,
    about 10 years ago I bought Cubase with an Atari and an M1 synth (it was all
    the rage at the time). I learned to use the set up but the sounds that were
    available at that time sucked so I sold the thing and decided to wait until
    they figure out a way to use good sounds from a home system. Well they said
    now you can, just buy a powerful computer, Cubase SX2, Halion String
    Edition, more RAM, a semi-pro sound card (Audiophile) and you're
    off.........not. There must be a way, if not someone please tell me so I can
    stop wasting my time and money trying and get back to making music the old
    fashioned way.
    JJ
  15. Aphelion Guest
    Message Count:
    On Fri, 12 Nov 2004 23:12:22 +0100, "Jack Jarmush"
    It's a setup problem, and.....it's entirely possible to do what you
    want to do. This stuff is being used in studios worldwide for film
    scoring composition...etc.
    re: setup problem.
    I'm guessing it's a hardware conflict.
    If you would be kind enough to post your system specs once more
    (sorry, I missed the first part of this thread) maybe we would all
    have some fresh ideas. It may take digging into the BIOS.
    Also, post the IRQ portion from "System Tools/System Information".
    You can copy/paste the info.
    Ap
  16. Jack Jarmush Guest
    Message Count:
    but do you know anyone doing it in there kitchen ;-)
    Thanks for the encouragement. I do hear some good string samples on the TV
    and some movies, I can still hear that they're samples but it sounds nice
    anyway.
    You asked for my pecs :
    Pent 4/ 2.4 GHz
    Audiophile 2496
    1 GB RAM
    Windows XP
    Cubase SX2
    I tried to get info from system tools but it wouldn't display anything.
    JJ
  17. Jack Jarmush Guest
    Message Count:
    I have Cubase and HSE on the same partition as the OS. Do you think that
    could be causing crackling and bad performance from VST's.?
    news:...
    both.
    that
    good
    > re: setup problem.
    > Ap
  18. Aphelion Guest
    Message Count:
    On Sat, 13 Nov 2004 06:51:33 +0100, "Jack Jarmush"
    Just returned from a gig... to answer your question, No! I don't think
    that's the problem.
    Need to see your IRQ list.
    In System Tools... run System Information, go to the menu and select
    IRQ. Mark it, copy it, and paste it into a post.
    Heve you tried tuning off Hyperthreading in the BIOS?
    Ap
    >news:...
    >both.
    >that
    >good
    >> re: setup problem.
    >> Ap
  19. Jack Jarmush Guest
    Message Count:
    > that's the problem.
    > Sorry but I can't access system tools/system information. Everything else
    in System tools is working just not the info. Could you give me an example
    of what info you need so I can get it another way.
    No, don't know what Hyperthreading is but I could look into it.
    > Ap
    > >news:...
    > >both.
    still
    the
    guess
    > >that
    the
    get
    music
    > >good
    > >> re: setup problem.
    > >> Ap
  20. Aphelion Guest
    Message Count:
    On Sat, 13 Nov 2004 08:17:40 +0100, "Jack Jarmush"
    >> that's the problem.
    You mean it's there but it won't run? This is a problem in and of
    itself.
    Looks like this:
    IRQ 0 System timer OK
    IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
    IRQ 3 RME DIGI96/8 PST OK
    IRQ 4 Standard Enhanced PCI to USB Host Controller OK
    IRQ 5 Printer Port (LPT1) OK
    IRQ 6 Standard floppy disk controller OK
    IRQ 7 NVIDIA nForce PCI System Management OK
    IRQ 7 Creative SB Audigy OK
    IRQ 8 System CMOS/real time clock OK
    IRQ 9 Microsoft ACPI-Compliant System OK
    IRQ 10 RADEON 9200 SERIES OK
    IRQ 11 Standard OpenHCD USB Host Controller OK
    IRQ 11 OHCI Compliant IEEE 1394 Host Controller OK
    IRQ 11 U.S. Robotics 56K Fax PCI OK
    IRQ 12 PS/2 Compatible Mouse OK
    IRQ 13 Numeric data processor OK
    IRQ 14 NVIDIA NForce 2(tm) SPP/IGP ATA Controller OK
    IRQ 15 NVIDIA NForce 2(tm) SPP/IGP ATA Controller OK
    Jack, I don't know how much I can help right now, I'm in the middle of
    a lot of work.
    In my opinion you most likely have a hardware/software conflict,
    probably with the computers BIOS operating system and Windows. It's
    not uncommon but does take some know how.
    >> Have you tried tuning off Hyperthreading in the BIOS?
    Have you ever gone into the BIOS and made adjustments?
    Ap
      • Advertising
Share This Page
