Audiophile 2496 vs 192
Discussion in 'alt.steinberg.cubase' started by SSR, Apr 21, 2009.
  1. SSR Guest
    Message Count:
    Hello
    Anyone have experience taking this upgrade and noticing a significant
    improvement in the recorded audio? I know the balanced ins/outs will improve
    hum and noise rejection, but the recorded audio actually sound noticeably
    better? What about VSTs - will the sound quality of these be affected?
    Thanks
      • Advertising
  2. SSR Guest
    Message Count:
    Hello Phil
    I really appreciate your detailed response and I take your points.
    My recorded vocals are my main source of discontent - I am using 2 mics -
    Electrovoice Cardinal and Apex 210 Ribbon (which I have modified by removing
    the internal wind screens and it sounds much more open now) thru a Yamaha
    mg124c mixer(this has on board compression which I use very sparingly if at
    all) into my 2496. I also have the Maudio DMP3 but didn't really notice much
    of a difference in recorded quality thru that. The quality of my voice I can
    do nothing about but I keep looking for the focused sound with silent space
    around it as I hear when listening to say a slow Elvis song. Yet relatively
    my vocal sounds dispersed. Adding reverb (Cubase reverb A) just adds
    reverberation - I can't move the voice back from up front. I have yet to get
    the settings to achieve that.
    Maybe its just down to finding the right effects but I keep wondering if the
    initial recording is maybe not clean enough - hence my question whether the
    192 grass is greener. I wonder should I build a vocal booth - but then I
    start wondering if that will introduce unwanted reflections and there is the
    difficulty of trying to operate Cubase remotely :(
    I guess the best thing is to suck it and see - my local supplier has a full
    refund within 7 days policy although I don't like to take advantage but how
    else do I decide.
    Thanks
    "Phil W" <> wrote in message
    news:gsjaiq$qi3$...
    > SSR wrote:
    >> Hello
    >> improve hum and noise rejection, but the recorded audio actually
    >> sound noticeably better?
    > The Delta 192 has better converters than the 2496. If, and how much, *you*
    > can really hear the difference - I can´t tell you, as I haven´t used or
    > heard the 192 yet (and I don´t know, how good your hearing is).
    > Generally, better converters are something you can hear and it´s a good
    > idea to improve on them. On the other hand, I´ve been using a 2496 for 3,5
    > years now (and a technically similar card from Terratec for 2 years before
    > that) and have never experienced any hum problems due to the unbalanced
    > connectors. The sound quality has been satisfying for my personal needs so
    > far. The drivers for both cards are the same anyway, so there should be
    > any sound quality or performance differences influenced by these.
    >> these be affected?
    > The actual sound quality of VST effects and VST instruments (as well as
    > any other plug-in formats, like DX) won´t be affected by different quality
    > converters. The converters are only responsible for the quality of audio
    > signals to go into the computer and come out of it. Since VST plug-ins are
    > processed internally on the computer, the quality of the audio interface
    > does *not* matter to them. What´s more important, is the quality of the
    > "audio engine" of your DAW software.
    > Anyway, better converters will get "better" quality audio into and out of
    > the computer. That means, your recordings from *external* sources may
    > sound better and when monitoring "VSTs" may sound better, so you can set
    > fx or sound patch settings in VSTi a bit more accurately. This can be
    > "important" for live use of VST fx or VSTi and for mixing "in the box".
    > Don´t forget, there are also numerous other factors, that are important as
    > well, like good monitoring (in a "good sounding" room), quality of input
    > signals (before the reach the audio interface) and so on...
    > The actual "sound quality" of an audio plug-in (effect or "virtual
    > instrument") is determined by the quality of its implementation. In other
    > words, the quality depends on the quality of the programming code behind
    > the plug-in. It´s same principle as with hardware fx and instruments -
    > there are good sounding ones available, as well as less good sounding
    > ones. That can depend on the price, but it doesn´t necessarily have to.
    > There are quite good sounding freeware (or cheap) plug-ins out there and
    > not so good sounding commercial ones.
    > An audio interface with "good" converters won´t turn a not so great
    > sounding source to a really great one. These things can´t do magic. ;-)
    > They only offer more accurate reproduction.
    > The more important consideration will probably be, if you want/need
    > balanced connectors or if you could live with unbalanced ones. And, of
    > course, if you´re willing to pay the higher price for balanced connectors
    > and better converters.
    > Phil
  3. Phil W Guest
    Message Count:
    SSR wrote:
    > Hello
    Generally, better converters are something you can hear and it´s a good idea
    to improve on them. On the other hand, I´ve been using a 2496 for 3,5 years
    now (and a technically similar card from Terratec for 2 years before that)
    far. The drivers for both cards are the same anyway, so there should be any
    > these be affected?
    The actual sound quality of VST effects and VST instruments (as well as any
    the computer. That means, your recordings from *external* sources may sound
    better and when monitoring "VSTs" may sound better, so you can set fx or
    sound patch settings in VSTi a bit more accurately. This can be "important"
    words, the quality depends on the quality of the programming code behind the
    plug-in. It´s same principle as with hardware fx and instruments - there are
    good sounding ones available, as well as less good sounding ones. That can
    depend on the price, but it doesn´t necessarily have to. There are quite
    good sounding freeware (or cheap) plug-ins out there and not so good
    An audio interface with "good" converters won´t turn a not so great sounding
    source to a really great one. These things can´t do magic. ;-) They only
    The more important consideration will probably be, if you want/need balanced
    connectors or if you could live with unbalanced ones. And, of course, if
    you´re willing to pay the higher price for balanced connectors and better
    converters.
    Phil
  4. Phil W Guest
    Message Count:
    SSR wrote:
    > Hello Phil
    *blush* nice to hear that ;-)
    > mics - Electrovoice Cardinal and Apex 210 Ribbon (which I have
    > modified by removing the internal wind screens and it sounds much
    > more open now) thru a Yamaha mg124c mixer(this has on board
    > compression which I use very sparingly if at all) into my 2496. I
    > also have the Maudio DMP3 but didn't really notice much of a
    There you have it: the main focus to improve would rather be a noticably
    better sounding preamp AND working on your voice/singing abilities than to
    get a better version of your Delta 2496 soundcard.
    The preamps in both devices you mention, are not the best - even though they
    should be somehow "okay". The most recordings, I´ve done were vocal
    recordings (although not of myself) with the 2496. IMHO the sound quality of
    the 2496 is sufficient for that and the 192 won´t be so much different, that
    it´s worth to buy a new one, as you already have the 2496. Better save the
    money up for a better pre-amp, so you can get a better signal into the sound
    card. I don´t really have the experience to suggest something, but very
    often, the RNP (Really Nice Preamp) is suggested. Costs about 500$ IIRC and
    probably sounds noticably better than the cheap pre-amps in your rather
    low-end pre-amps in the small Yamaha mixer.
    Another aspect is, if the mics really suit your voice. They may be good, but
    not optimal for your voice. There are situations, where a silly SM58 fits
    better with certain singers, than "expensive" mics. ;-)
    One thing, you might try with the Yamaha mixer is to tweak the EQ a little
    bit and see, if that helps. For example, try rolling off the "lows" a bit.
    How are "using 2 mics" to record your voice exactly? Do you place both mics
    close to each other and try to sing into both with the same amount? The
    reason, I ask, is that we tried this technique for a while and have found,
    that it´s usually better to use only 1 mic at once and sing into that
    directly.
    > can do nothing about but I keep looking for the focused sound with
    > silent space around it as I hear when listening to say a slow Elvis
    > song. Yet relatively my vocal sounds dispersed. Adding reverb (Cubase
    > reverb A) just adds reverberation - I can't move the voice back from
    > up front. I have yet to get the settings to achieve that.
    You can (probably) at least try do improve your singing technique, to get
    more constant levels and more secure intonation. ;-)
    It also makes a big difference, which reverb you use. These also have
    different sound characters. I´m personally not really impressed by "Reverb
    A" and "Reverb B". The "Roomworks" reverb in SX3 sounds way better, but
    isn´t always best suited. You might want to try some other freeware reverb
    plug-ins, too:
    http://www.kjaerhusaudio.com/download.php
    -> the free "Classic Series" stuff is nice
    http://www.dasample.com/index.php?show=glaceverb
    - a bit strange to set, but sounds good
    http://www.knufinke.de/sir/sir1.html
    - very CPU-"hungry", but with good "impulse response" samples it can sound
    really great!
    there are tons of free IR samples available from various sites on the web,
    so if you bother to download and try enough, you can get the "sound" of
    really good real rooms and hardware reverb units virtually "for free" ;-)
    check the "Links" section on the SIR website.
    BTW: the parameter to "move" a signal in the mix is called "Pre-Delay"
    > if the initial recording is maybe not clean enough - hence my
    > question whether the 192 grass is greener.
    Well, as I said, I don´t think that´s your real problem. The 192 will
    probably sound a bit more accurate, but as you describe it, your actual
    problems already come up, before the signal hits the sound card. I´ve done
    quite "clean" vocal recordings with various mics (SM58, a Schoeps, Rode
    NT-1a, a Gefell) through cheap Behringer mixers and a cheap ART "Tube MP" -
    which is definitely low-end stuff. One band, that I recorded a full album´s
    (15 tracks) vocals tracks for with an old SM58 through the ART pre straight
    into the Delta2496, said "wow, those vocal tracks sound amazingly clean"...
    Not necessarily my opinion, but if the "paying clients" are happy with the
    result, I won´t say "Well guys, we could have done even greater!" ;-) The
    tracking was done in their rehearsal space, which is certainly not the best
    sounding environment. Anyway, the final result sounds quite good. It was a
    DIY production, but I´ve heard stuff from so-called "studios" (with better
    equipment, than we had) that doesn´t sound as good.
    > vocal booth - but then I start wondering if that will introduce
    > unwanted reflections and there is the difficulty of trying to operate
    > Cubase remotely :(
    Building a good vocal booth takes a lot of work and material. Another option
    might be "MicroTraps" from http://www.realtraps.com/products.htm - not a
    cheap option, but probably better than building a vocal booth yourself.
    Also do some reading on Ethan Winer´s website:
    http://www.ethanwiner.com/articles.html
    The fact of operating your DAW software remotely, when you´re recording
    yourself, can be hassle. Been there, done that. But it can work, if you use
    keyboard shortcuts to operate Cubase. Either get a long cable extension for
    your keyboard or try a wireless keyboard. Another key is, to use "markers"
    (in a "marker track" in Cubase), so you can jump/skip to various positions
    in the time-line, and also consider the "pre-roll" function. Look up the
    Cubase manual, if you´re not sure how it works.
    > a full refund within 7 days policy although I don't like to take
    > advantage but how else do I decide.
    That´s an option, but you might also think about, what you get from them to
    try. Maybe try some different mics and pre-amps at the shop, if possible.
    When you find something, that sounds promising, take it home for an
    "in-depth" test in your typical recording environment.
    Good luck,
    Phil
      • Advertising
  5. SSR Guest
    Message Count:
    Hi Phil
    I think you have got me over my present gear aquisition syndrome- I tried
    the free reverbs you suggested - what a difference. I think I am OK with my
    vocal sound now
    I am looking into the possibility of a DIY preamp e.g. next - any
    suggestions?
    Many thanks for you help
    Sirtaz
    news:gsjj81$2b1$...
    > SSR wrote:
    >> Hello Phil
    > they should be somehow "okay". The most recordings, I´ve done were vocal
    > of the 2496 is sufficient for that and the 192 won´t be so much different,
    > that it´s worth to buy a new one, as you already have the 2496. Better
    > save the money up for a better pre-amp, so you can get a better signal
    > into the sound card. I don´t really have the experience to suggest
    > something, but very often, the RNP (Really Nice Preamp) is suggested.
    > Costs about 500$ IIRC and probably sounds noticably better than the cheap
    > pre-amps in your rather low-end pre-amps in the small Yamaha mixer.
    > but not optimal for your voice. There are situations, where a silly SM58
    > fits better with certain singers, than "expensive" mics. ;-)
    > mics close to each other and try to sing into both with the same amount?
    > The reason, I ask, is that we tried this technique for a while and have
    > found, that it´s usually better to use only 1 mic at once and sing into
    > that directly.
    > plug-ins, too:
    > really great!
    > MP" - which is definitely low-end stuff. One band, that I recorded a full
    > album´s (15 tracks) vocals tracks for with an old SM58 through the ART pre
    > straight into the Delta2496, said "wow, those vocal tracks sound amazingly
    > clean"... Not necessarily my opinion, but if the "paying clients" are
    > happy with the result, I won´t say "Well guys, we could have done even
    > greater!" ;-) The tracking was done in their rehearsal space, which is
    > certainly not the best sounding environment. Anyway, the final result
    > sounds quite good. It was a DIY production, but I´ve heard stuff from
    > so-called "studios" (with better equipment, than we had) that doesn´t
    > sound as good.
    >> Cubase remotely :(
    > option might be "MicroTraps" from http://www.realtraps.com/products.htm -
    > not a cheap option, but probably better than building a vocal booth
    > yourself.
    > use keyboard shortcuts to operate Cubase. Either get a long cable
    > extension for your keyboard or try a wireless keyboard. Another key is, to
    > use "markers" (in a "marker track" in Cubase), so you can jump/skip to
    > various positions in the time-line, and also consider the "pre-roll"
    > function. Look up the Cubase manual, if you´re not sure how it works.
    > to try. Maybe try some different mics and pre-amps at the shop, if
    > possible. When you find something, that sounds promising, take it home for
    > an "in-depth" test in your typical recording environment.
    > Good luck,
    > Phil
  6. Phil W Guest
    Message Count:
    SSR wrote:
    > Hi Phil
    > tried the free reverbs you suggested - what a difference. I think I
    > am OK with my vocal sound now
    Fine! ;-) There are many more free reverb plug-ins, but these are the ones,
    that worked out for me. Over time, I´ve tried a lot and also got rid of a
    lot of stuff... anyway, if you don´t try it out, you can´t find the
    good-sounding free plug-ins... At least, you have to invest some time, when
    you want to save on money.
    > suggestions?
    As I said, RNP is a regular suggestion - though I haven´t used or heard it
    yet.
    With my last band, we recorded at a local "audio school" a few times. There,
    we used an "SPL Goldmike" and a "Mindprint DTC", which sound nice, but are
    not in the same price region as an RNP. There is a "smaller" version of the
    DTC called "EnVoice" which is actually a "channel strip" (pre-amp + EQ +
    compressor) for about the same price as the RNP.
    The "low-cost" pre-amps (up to 200$ or so) don´t sound very much different.
    To get in a better league soundwise, you´ll have to take a bigger step.
    Others here can probably suggest other pre-amps...
    - Sorry, I don´t want to offend you here!!! - It seems, as if you´re still
    learning to use all the "tools" required in a recording and mixing
    situation. Until you haven´t learned a few more things and concepts about
    the whole thing, you should rather not spend anymore money. Better try
    around and learn to use the tools that you already have now "in practice",
    then decide to buy something, when you have a better idea of what makes
    sense to spend money for.
    Of course, it´s easy to buy new stuff and pretend, your music sounds better,
    just because you have better pre-amps or compressors or whatever now. Some
    friends of mine used to do that for a few years. They bought stuff, gave it
    a short try, were amazed for a short while, but almost never took the time
    to dive into the usage deeper. After a while, they sold the stuff again...
    As far as their musical efforts were concerned: they usually rather played
    around with their "new toys", than trying to get actual musical work done.
    Well, they did have fun that way, but in the end there were almost no real
    musical results.
    Now, decide what´s more important to you... even if you don´t have the
    greatest hardware available, it´s still worlds better than what people used
    for "home-recording" 15 years ago!
    My personal attempt is to focus on the music first, then worry about
    technical details. ;-)
    Phil
  7. SSR Guest
    Message Count:
    Hi Phil
    Not offended at all, I absolutely agree about not getting on the 'upgrade'
    bandwagon unless it produces real improvements. I don't part with my moolah
    easily unless the bang for buck is real and real big :) (I drive a 23 year
    old Mercedes 300e which I paid 8 grand for 4 years ago and I fully maintain
    it myself and is in pristine condition inside and under the hood - I
    wouldn't swop it for a new car if it was given to me free. They just don't
    make them as maintainable any more.)
    When I find a suitable design I will probably build myself a good quality
    preamp but for the moment I am content with my recorded vocal sound with SIR
    as the reverb. It was the Cubase Reverb A and B that were destroying it. ( I
    found a good test is to listen to the wet only signal to get a sense of the
    reverb quality - Reverbs A and B are dire)
    Now I can get back to the music instead of the technology.
    Thanks again
    SSR
    news:gsohe0$op8$...
    > SSR wrote:
    >> Hi Phil
    > ones, that worked out for me. Over time, I´ve tried a lot and also got rid
    > of a lot of stuff... anyway, if you don´t try it out, you can´t find the
    > when you want to save on money.
    >> suggestions?
    > yet.
    > There, we used an "SPL Goldmike" and a "Mindprint DTC", which sound nice,
    > but are not in the same price region as an RNP. There is a "smaller"
    > version of the DTC called "EnVoice" which is actually a "channel strip"
    > (pre-amp + EQ + compressor) for about the same price as the RNP.
    > different. To get in a better league soundwise, you´ll have to take a
    > bigger step.
    > better, just because you have better pre-amps or compressors or whatever
    > now. Some friends of mine used to do that for a few years. They bought
    > stuff, gave it a short try, were amazed for a short while, but almost
    > never took the time to dive into the usage deeper. After a while, they
    > sold the stuff again... As far as their musical efforts were concerned:
    > they usually rather played around with their "new toys", than trying to
    > get actual musical work done. Well, they did have fun that way, but in the
    > end there were almost no real musical results.
    > used for "home-recording" 15 years ago!
    > Phil
      • Advertising
Share This Page
