Basic software to assist in music composition?
Discussion in 'rec.music.synth' started by NoName, Jan 11, 2009.
  1. NoName Guest
    Message Count:
    I am seeking software to assist in some relatively basic music
    composition.
    Background: I've written a play where, among the characters, I have a
    teenager who is an aspiring rock'n'roll star. The play is not a
    musical, but the teen performs snippets from a few songs. I've
    written lyrics, now I need music -- melody and chords. Because the
    character is a teenager, the songs don't actually have to be all that
    great (the kid is still developing his craft), just sort of plausible.
    What I want is the following:
    1. Software where I can enter my lyrics, and then also use the
    computer keyboard to enter a melody (which I will make up) on a staff,
    and hear the notes as I enter them. (I don't have an electronic piano
    keyboard to plug into the PC, and I'm not planning to buy one for
    this.) I should then be able to play back the melody over the
    keyboard to hear it. Of course, I should be able to synchronize the
    display of melody and lyrics.
    2. Here's where it gets trickier. I want to be able to indicate some
    kind of general "mood" and tone -- upbeat, silly, serious, sad, things
    along those lines -- and have the software suggest possible chords to
    accompany the melody. I then need to play back the chords and melody
    together over the PC, edit to make changes, etc.
    3. Ideally, it would be nice to be able to specify a choice of
    instrument sound, such as guitar or piano.
    4. Of course, the whole thing needs to be saveable as an audio file,
    like mpg or something along those lines.
    5. The less expensive, the better. I don't want to spend $1000
    dollars, and I'd prefer to keep it $100, or something like that.
    Software with a good, useable trial version for download would be
    ideal.
    Any leads, links to appropriate Web sites, etc., would be nice. I use
    Windows XP. Please reply on-list, or to Steveqdr [just as written] aa
    tt yyaahhoooo ddoott ccoomm
      • Advertising
  2. Rick Paul Guest
    Message Count:
    With the exception of the notation part, most of what you mentioned sounds
    very much like a new product I just heard about a few days ago, believe it
    or not from Microsoft. It's called Songsmith:
    http://research.microsoft.com/en-us/um/redmond/projects/songsmith/
    I think it costs about $30, and there is a trial version. I haven't tried
    it, but it looks like you sing your melody into the program using any mic
    (including the kind built into a notebook PC), then you also tell it things
    liket he kind of mood you're looking for and the musical style, then it
    comes up with chords for you to build an accompaniment. You can also tweak
    the chords it comes up with to tailor it, and they are using instruments
    from Garritan, who supply some pretty good quality stuff in their mainstream
    products.
    I'm pretty sure the product doesn't do notation, though. You could try a
    low end version of a mainstream DAW program or notation program for that
    (e.g. Cakewalk Music Creator is about $35 or $40 -- see
    http://www.cakewalk.com/Products/MusicCreator/ for an overview of features),
    but I doubt any of those will suggest chords for you.
    Band-in-a-Box, which was also mentioned in a response to this message, is a
    good way to experiment with styles and chord changes, but I don't think
    it'll suggest chords for you, either, and I don't recall what it offers on
    the notation side (my version of BiaB is quite a number of versions old now,
    too). Definitely worth checking out, though, as it's possible the newer
    versions may do more of what you're asking for here.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
    "NoName" <> wrote in message
    news:...
    > composition.
    > ideal.
      • Advertising
Share This Page
