batteries K2500
Discussion in 'alt.music.synth.kurzweil' started by Ben van den Broek, Nov 23, 2003.
  1. Ben van den Broek Guest
    Message Count:
    Can anyone tell me: can I simply replace the batteries of my K2500 keyboard
    without loss of the internal ROM?
    (answer may also be posted in Dutch...)
    Ben
      • Advertising
  2. Michael Houston Guest
    Message Count:
    Yes.
    On Sun, 23 Nov 2003 18:52:21 +0100, "Ben van den Broek"
    >Ben
    Michael Houston
    musicianmike at cox dott net (you know what to do)
  3. lAzZar0 Guest
    Message Count:
    test 123
    On Mon, 24 Nov 2003, Michael Houston wrote:
    > Yes.
    > >Ben
    > Michael Houston
  4. David C. Guest
    Message Count:
    "Ben van den Broek" <> writes:
    > keyboard without loss of the internal ROM? (answer may also be
    > posted in Dutch...)
    ROM is never erased by loss of power/battery. Neither is flash
    memory.
    PRAM is, however.
    If you change the batteries quickly, you shouldn't lose your PRAM.
    But just to be safe, I recommend saving memory to disk, just in case.
    This way, you can restore it if it gets lost. Even with the PRAM
    upgrade, the memory (1.25M) should fit on a single floppy disk.
    In my case, it was no big deal, because I have my entire system state
    (PRAM and sample memory) saved to a Zip disk. So a loss of PRAM while
    changing batteries really doesn't matter to me.
    -- David
  5. Ben van den Broek Guest
    Message Count:
    Thanx. Worked well.....
    "David C." <> schreef in bericht
    news:...
    > > posted in Dutch...)
    > memory.
    > PRAM is, however.
    > -- David
      • Advertising
Share This Page
