Best way to set accurate delays?
Discussion in 'alt.steinberg.cubase' started by The Cedar Room, Dec 2, 2009.
  1. The Cedar Room Guest
    Message Count:
    Can anyone advise me the best method for delaying a track by say 2.8 MS
    using Cubase 5? Is there a plugin that gives me a readout with milliseconds
    accuracy that I can set?
    Thanks
    Steve.
      • Advertising
  2. Jos Geluk Guest
    Message Count:
    The Track Inspector has a delay setting that claims to be accurate to 10
    microseconds. That is, the control has two decimal places and claims
    to be in milliseconds. However, that doesn't make sense at current
    sample rates.
    If you want to be really sure, calculate the amount of samples that you
    need to delay the track with. E.g. at a sample rate of 44100Hz, your 2.8
    ms would work out as 2.8*44.1 samples or 123 samples. Set the primary
    time display to samples. Make sure the information line on top of the
    project window is visible. Select all events on the track, and increase
    the start time with 123 samples. Done.
    Does this help?
    Jos.
    Ardis Park Music
    www.ardispark.nl
  3. Laurence Payne Guest
    Message Count:
    On Wed, 02 Dec 2009 05:13:43 GMT, "The Cedar Room"
    Use the offset setting in the Inspector. Or turn Snap off, zoom right
    in and physically move the part.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  4. Guest Guest
    Message Count:
    If you want to use a plugin, there's ...
    http://www.voxengo.com/product/sounddelay/
    "The Cedar Room" <> wrote in message
    news:bImRm.59415$...
    > milliseconds accuracy that I can set?
    > Thanks
    > Steve.
  5. The Cedar Room Guest
    Message Count:
    Thanks everyone for comments it was very helpful, problem solved.
    Steve
    <> wrote in message
    news:gvxRm.17808$2...
    >> Thanks
    >> Steve.
      • Advertising
Share This Page
