Beta drivers for legacy MidiSport interface
Discussion in 'cakewalk.audio' started by Dominique, Apr 6, 2010.
  1. Dominique Guest
    Message Count:
    For those who might be interested.
    M-Audio have finally release a Win7 64-bits beta driver for legacy
    MidiSport USB midi interface. I've installed it but haven't tested it yet
    but the interface shows up in Device manager and music applications.
    http://forums.m-audio.com/showthread.php?18743
    You must log-in to download the file.
      • Advertising
  2. Phoenix Guest
    Message Count:
    it yet
    Im about to install the drivers on my laptop; I was just curious
    whether you've tested them yet.
  3. Dominique Guest
    Message Count:
    Phoenix <> écrivait news:almarsoft.8364761785960890022
    @news.eternal-september.org:
    > it yet
    Sorry for the delay,
    I didn't have time to test it and I just did some quick test and it doesn't
    work. The led in the interface flashes rapidly when I play on the keyboard
    (like it should) but nothing seems to get to the software. I tried it in
    Sonar with softsynths or trying to record, the same configuration in Reaper
    and directly in Kontakt 4.
    Everything works using a Cakewalk/Roland/Edirol UM3 interface or using the
    MIDI port on my Delta 1010.
    The Midiman will return to my 32bits laptop.
    It's not a big issue for me as I have other solutions.
    Some peoples claim that it works with their setup on the M-Audio forums
    though.
  4. malachi Guest
    Message Count:
    "Dominique" <> wrote in message
    news:XnF9D5248C1F4A00doumdomainnet@69.16.185.252...
    I tried using it with my Midisport 8X8/s (greyface).
    With Reaper, the inputs show up on the MIDI configuration dialog but the
    output will only show one output and only if you select it as the default
    MIDI output in the Windows XP control panel. Even if you uncheck the box to
    use only the default output in that screen.
    However, when I install my Yamaha usb MIDI interface (just a
    one-in-one-out), all of the Midisport outputs magically appear in Reaper.
    It's as if the Yamaha is acting as a dongle for the M-audio interface!
    Weird.
    malachi
      • Advertising
  5. Phoenix Guest
    Message Count:
    On Sun, 11 Apr 2010 09:25:53 -0500, "malachi" <>
    tested it yet
    applications.
    but the
    default
    the box to
    Reaper.
    interface!
    > Weird.
    > malachi
    Hmmm...well, there's already a MIDI interface installed on my laptop
    (FW410) so maybe my greyface 4x4 or 2x2 will work. The 410 is only 1
    in 1 out and I could use more, but I have to say the disclaimer with
    the drivers is disquieting. M-Audio will not be responsible for any
    data loss or damage? Data loss I can understand, but damage? What
    kind of damage are they talking about?
    I don't recall seeing damage mentioned with the Delta or FireWire
    driver betas...
  6. Phoenix Guest
    Message Count:
    Update: I just installed. Took a bit of plugging and unplugging to get the
    DAW to see both MIDIsport and MOTU. The MIDIsport is not present under
    "Safely Remove Hardware" which bothers me a bit. I've posted on the forum
    about it; we'll see if anyone answers.
    That disclaimer thing about damages *still* bothers me.
    "Phoenix" <> wrote in message
    news:-september.org...
    > tested it yet
    > applications.
    > but the
    > default
    > the box to
    > Reaper.
    > interface!
    >> Weird.
    >> malachi
    > (FW410) so maybe my greyface 4x4 or 2x2 will work. The 410 is only 1 in 1
    > out and I could use more, but I have to say the disclaimer with the
    > drivers is disquieting. M-Audio will not be responsible for any data loss
    > or damage? Data loss I can understand, but damage? What kind of damage
    > are they talking about? I don't recall seeing damage mentioned with the
    > Delta or FireWire driver betas...
      • Advertising
Share This Page
