Anyone here know of a good Vsti or similar which I can use to create a half-decent brass section suitable for old school pop-rock? I've got loads of old soundfonts and there's some stuff in HalionOne, but nothing really hits the spot. I used to be able to do it years ago with an old Akai sampler. It was very time consuming but it sounded great. Sadly the Akai is long gone. I'd like to avoid having to load up an enormous library of samples as this something I'd only use ocassionally - most of my songs being guitar orientated. Any help would be appreciated.....LL
On Sun, 29 Aug 2010 19:56:29 +0100, lancelightning <> wrote: >Anyone here know of a good Vsti or similar which I can use to create a >half-decent brass section suitable for old school pop-rock? I think very highly of the Edirol Orchestral
On Aug 29, 1:56 pm, lancelightning <> wrote: > Anyone here know of a good Vsti or similar which I can use to create a > half-decent brass section suitable for old school pop-rock? > > I've got loads of old soundfonts and there's some stuff in HalionOne, > but nothing really hits the spot. I used to be able to do it years ago > with an old Akai sampler. It was very time consuming but it sounded > great. Sadly the Akai is long gone. > > I'd like to avoid having to load up an enormous library of samples as > this something I'd only use ocassionally - most of my songs being > guitar orientated. > > Any help would be appreciated.....LL I believe that the sound of the instrument is less important then the way it is plays. first of all, try playing each part on its own track and think horn. For instance, when playing sax, of you're trying to get a punch high note, it might help to put in a quick little grace not idea at the octave lower. If you have ever played sax and tried to punch the high note, you'll notice that you squeak in the lower octave note. .... Anyway, if you think like that, even the cheapest of sounds will do nicely, especially for old school music styles.
On Sun, 29 Aug 2010 13:13:12 -0700 (PDT), Danny T <> wrote: >On Aug 29, 1:56 pm, lancelightning <> wrote: >> Anyone here know of a good Vsti or similar which I can use to create a >> half-decent brass section suitable for old school pop-rock? >> >> I've got loads of old soundfonts and there's some stuff in HalionOne, >> but nothing really hits the spot. I used to be able to do it years ago >> with an old Akai sampler. It was very time consuming but it sounded >> great. Sadly the Akai is long gone. >> >> I'd like to avoid having to load up an enormous library of samples as >> this something I'd only use ocassionally - most of my songs being >> guitar orientated. >> >> Any help would be appreciated.....LL > >I believe that the sound of the instrument is less important then the >way it is plays. first of all, try playing each part on its own track >and think horn. For instance, when playing sax, of you're trying to >get a punch high note, it might help to put in a quick little grace >not idea at the octave lower. If you have ever played sax and tried to >punch the high note, you'll notice that you squeak in the lower octave >note. .... Anyway, if you think like that, even the cheapest of sounds >will do nicely, especially for old school music styles. Food for thought. I have never played sax though I have worked live with a brass section. But I hear what your'e saying and I'll experiment. Thanks for the input....LL
On Sun, 29 Aug 2010 21:22:25 +0200, Max Doorrijhoogte <> wrote: >On Sun, 29 Aug 2010 19:56:29 +0100, lancelightning <> wrote: > >>Anyone here know of a good Vsti or similar which I can use to create a >>half-decent brass section suitable for old school pop-rock? > >I think very highly of the Edirol Orchestral Thanks...I'll check it out...LL
> > Food for thought. I have never played sax though I have worked live > with a brass section. But I hear what your'e saying and I'll > experiment. Thanks for the input....LL Read the manual for the instrument you're gonna use because some things are not evident. Some midi messages will send dynamics control to the instrument and it might do all the difference. As for good VST instruments, the best I know is NI Kontakt. Another good one is Garry Garritan Jazz and Big Band. Paulo
On Mon, 30 Aug 2010 16:47:32 +0100, "Paulo Gomes" <> wrote: >> >> Food for thought. I have never played sax though I have worked live >> with a brass section. But I hear what your'e saying and I'll >> experiment. Thanks for the input....LL > >Read the manual for the instrument you're gonna use because some things are >not evident. Some midi messages will send dynamics control to the instrument >and it might do all the difference. >As for good VST instruments, the best I know is NI Kontakt. Another good one >is Garry Garritan Jazz and Big Band. > >Paulo > I have thought about investing in Kontakt. The trouble is that some of the sample libraries can be enormous. I will look into the other one though. Thanks Paulo.....LL
"lancelightning" <> schrieb im Newsbeitrag news:... > Paulo Gomes wrote: >>> Food for thought. I have never played sax though I have worked live >>> with a brass section. But I hear what your'e saying and I'll >>> experiment. Thanks for the input....LL >> >>Read the manual for the instrument you're gonna use because some things >>are >>not evident. Some midi messages will send dynamics control to the >>instrument >>and it might do all the difference. If I understand it correctly, this is also covered by "expression maps", which are a new feature since Cubase 5. But to make use of that, the instrument must support this, of course. ;-) >>As for good VST instruments, the best I know is NI Kontakt. Another good >>one is Garry Garritan Jazz and Big Band. > I have thought about investing in Kontakt. The trouble is that some of > the sample libraries can be enormous. > > I will look into the other one though. NI has the free "Kontakt Player" (a kind of "demo" for the "big" Kontakt), which you might want to try for a start. There´s also free content available for that, but I don´t know, if there are brass sounds included. Anyway, it´s worth a try - also to see, if you get along with the controls in Kontakt. http://www.native-instruments.com/#/en/products/producer/kontakt-player/ Good luck on your quest, Phil
Op 30-8-2010 17:47, Paulo Gomes schreef: >> >> Food for thought. I have never played sax though I have worked live >> with a brass section. But I hear what your'e saying and I'll >> experiment. Thanks for the input....LL > > Read the manual for the instrument you're gonna use because some things are > not evident. Some midi messages will send dynamics control to the instrument > and it might do all the difference. > As for good VST instruments, the best I know is NI Kontakt. Another good one > is Garry Garritan Jazz and Big Band. I find it very hard work to make sampled brass sound credible, to the extent that I have turned down assignments because I felt I wouldn't be able to come close enough to the real thing. Having said that, I second the Garritan. As Paulo said, look for ways to tweak the sound in real time. That may help. The Garritan is very good in that respect. E.g. a saxophone is rarely played in tune; adding some stray pitch bends here and there may just be what you need. With the Garritan, you can do that with all kinds of filters, noises, flutters and vibrations. However, not all of the Garritan instruments sound good. Jos. -- Ardis Park Music www.ardispark.nl
> >NI has the free "Kontakt Player" (a kind of "demo" for the "big" Kontakt), >which you might want to try for a start. There´s also free content available >for that, but I don´t know, if there are brass sounds included. Anyway, it´s >worth a try - also to see, if you get along with the controls in Kontakt. >http://www.native-instruments.com/#/en/products/producer/kontakt-player/ > > >Good luck on your quest, > >Phil Thanks guys for the various replies. I'll have a good look at what's been suggested and I'll let the group know what I decide to go with. LL
Oh I forgot one plugin that I was told is very good too, it's the Arturia Brass. Good luck "lancelightning" <> wrote in message news:... > >> >>NI has the free "Kontakt Player" (a kind of "demo" for the "big" Kontakt), >>which you might want to try for a start. There´s also free content >>available >>for that, but I don´t know, if there are brass sounds included. Anyway, >>it´s >>worth a try - also to see, if you get along with the controls in Kontakt. >>http://www.native-instruments.com/#/en/products/producer/kontakt-player/ >> >> >>Good luck on your quest, >> >>Phil > > Thanks guys for the various replies. I'll have a good look at what's > been suggested and I'll let the group know what I decide to go with. > > > LL
Aaah..I reckon that a friend of mine has got that one. I'll have to have a look at his setup. Thanks Paulo On Tue, 31 Aug 2010 18:13:08 +0100, "Paulo Gomes" <> wrote: >Oh I forgot one plugin that I was told is very good too, it's the Arturia >Brass. >Good luck > >"lancelightning" <> wrote in message >news:... >> >>> >>>NI has the free "Kontakt Player" (a kind of "demo" for the "big" Kontakt), >>>which you might want to try for a start. There´s also free content >>>available >>>for that, but I don´t know, if there are brass sounds included. Anyway, >>>it´s >>>worth a try - also to see, if you get along with the controls in Kontakt. >>>http://www.native-instruments.com/#/en/products/producer/kontakt-player/ >>> >>> >>>Good luck on your quest, >>> >>>Phil >> >> Thanks guys for the various replies. I'll have a good look at what's >> been suggested and I'll let the group know what I decide to go with. >> >> >> LL >
On Aug 29, 4:33 pm, lancelightning <> wrote: > On Sun, 29 Aug 2010 13:13:12 -0700 (PDT), Danny T > > > > > > <> wrote: > >On Aug 29, 1:56 pm, lancelightning <> wrote: > >> Anyone here know of a good Vsti or similar which I can use to create a > >> half-decent brass section suitable for old school pop-rock? > > >> I've got loads of old soundfonts and there's some stuff in HalionOne, > >> but nothing really hits the spot. I used to be able to do it years ago > >> with an old Akai sampler. It was very time consuming but it sounded > >> great. Sadly the Akai is long gone. > > >> I'd like to avoid having to load up an enormous library of samples as > >> this something I'd only use ocassionally - most of my songs being > >> guitar orientated. > > >> Any help would be appreciated.....LL > > >I believe that the sound of the instrument is less important then the > >way it is plays. first of all, try playing each part on its own track > >and think horn. For instance, when playing sax, of you're trying to > >get a punch high note, it might help to put in a quick little grace > >not idea at the octave lower. If you have ever played sax and tried to > >punch the high note, you'll notice that you squeak in the lower octave > >note. .... Anyway, if you think like that, even the cheapest of sounds > >will do nicely, especially for old school music styles. > > Food for thought. I have never played sax though I have worked live > with a brass section. But I hear what your'e saying and I'll > experiment. Thanks for the input....LL- Hide quoted text - Also, program in some brass-like articulation with better envelopes than are usually stock on store-bought brass patches. Subtle modulation.
So? "lancelightning" <> wrote in message news:... > Anyone here know of a good Vsti or similar which I can use to create a > half-decent brass section suitable for old school pop-rock? > > I've got loads of old soundfonts and there's some stuff in HalionOne, > but nothing really hits the spot. I used to be able to do it years ago > with an old Akai sampler. It was very time consuming but it sounded > great. Sadly the Akai is long gone. > > I'd like to avoid having to load up an enormous library of samples as > this something I'd only use ocassionally - most of my songs being > guitar orientated. > > Any help would be appreciated.....LL
On Mon, 18 Oct 2010 12:40:08 +0100, "Paulo Gomes" <> wrote: >So? > >"lancelightning" <> wrote in message >news:... >> Anyone here know of a good Vsti or similar which I can use to create a >> half-decent brass section suitable for old school pop-rock? >> >> I've got loads of old soundfonts and there's some stuff in HalionOne, >> but nothing really hits the spot. I used to be able to do it years ago >> with an old Akai sampler. It was very time consuming but it sounded >> great. Sadly the Akai is long gone. >> >> I'd like to avoid having to load up an enormous library of samples as >> this something I'd only use ocassionally - most of my songs being >> guitar orientated. >> >> Any help would be appreciated.....LL > I'll probably make do with my soundfonts and HalionOne for now. I've yet to complete the song in question. There's been some good suggestions but I don't want to spend a lot on something that I'll only use occassionally. I'll let you know when my song is done and see what you think LL
Op 18-10-2010 23:05, lancelightning schreef: > I'll probably make do with my soundfonts and HalionOne for now. I've > yet to complete the song in question. > > There's been some good suggestions but I don't want to spend a lot on > something that I'll only use occassionally. > > I'll let you know when my song is done and see what you think I could provide Garritan brass sounds to your song, if you're interested. Jos. -- Ardis Park Music www.ardispark.nl
On Tue, 19 Oct 2010 09:28:56 +0200, Jos Geluk <> wrote: >Op 18-10-2010 23:05, lancelightning schreef: > >> I'll probably make do with my soundfonts and HalionOne for now. I've >> yet to complete the song in question. >> >> There's been some good suggestions but I don't want to spend a lot on >> something that I'll only use occassionally. >> >> I'll let you know when my song is done and see what you think > >I could provide Garritan brass sounds to your song, if you're interested. > >Jos. Wow..nice idea Jos. I'll get back to you when I've got the song into some sort of shape. I'm rather busy with other things at the minute..but I'm hoping to do some recording next week....LL
