cannot view synth rack
Discussion in 'cakewalk.audio' started by jeffl, Jun 17, 2010.
  1. jeffl Guest
    Message Count:
    Sonar 7.2
    Recently I am unable to view the synth rack regardless of what project I
    open. I cannot find it hiding on the edge of the screen--not sure what
    happened. All the other views pop up when I hit their icon or shortcut keys
    but neither works when summoning the synth view.
    Any ideas?
    Thanks again,
    Jeff
      • Advertising
  2. jeffl Guest
    Message Count:
    I found a workaround--views>show open view tabs ---this puts a tab and you
    can access the synth rack in track view at the bottom
    something's funny in my DAW. Fatal errors several times tonight. I haven't
    added any software and my DAW is not online..hmmmmm.....
    FWIW I'm starting to work with more people (once again) using mac/protools.
    I'm thinking of jumping ship--ie buying all new stuff (and also keeping what
    I've been using)...ie--adding a pro mac setup plus protools and whatever
    else I can afford
    "jeffl" <> wrote in message
    news:hvchp6$1up$-september.org...
    > Sonar 7.2
    > keys but neither works when summoning the synth view.
    > Any ideas?
    > Thanks again,
    > Jeff
  3. Steve_Karl Guest
    Message Count:
    How old is your OS hard drive?
    It might be getting some bad sectors from wear 'n' tear old age.
    chkdsk C: /F and look at the results in the DOS box.
    http://sightsea.com/renders/chkdsk.jpg
    If more than ZERO
    then run chkdsk C: /R and it will move any data out of the bad
    and mark them as "do not use these"
    .... but then get an other OS drive asap.
    S
    "jeffl" <> wrote in message news:hvcjtt$hvr$-september.org...
    >I found a workaround--views>show open view tabs ---this puts a tab and you can access the synth rack in track view at the bottom
    > something's funny in my DAW. Fatal errors several times tonight. I haven't added any software and my DAW is not
    > online..hmmmmm.....
    > FWIW I'm starting to work with more people (once again) using mac/protools. I'm thinking of jumping ship--ie buying all new stuff
    > (and also keeping what I've been using)...ie--adding a pro mac setup plus protools and whatever else I can afford
    > "jeffl" <> wrote in message news:hvchp6$1up$-september.org...
    >> Sonar 7.2
    >> Recently I am unable to view the synth rack regardless of what project I open. I cannot find it hiding on the edge of the
    >> screen--not sure what happened. All the other views pop up when I hit their icon or shortcut keys but neither works when
    >> Any ideas?
    >> Thanks again,
    >> Jeff
  4. Steve_Karl Guest
    Message Count:
    DOH sorry ...
    you won't be able to see the results in the DOS box becase you can't run it on C: in windows.
    Maybe in even viewer
    Maybe some one can tell you where the results can be seen after the fact, if not in event wiever.
    SK
    "Steve_Karl" <> wrote in message news:hvctoc$qu3$-september.org...
    > If more than ZERO
    > S
    >> online..hmmmmm.....
    >>> Sonar 7.2
    >>> Any ideas?
    >>> Thanks again,
    >>> Jeff
      • Advertising
  5. Glennbo Guest
    Message Count:
    The killer robot "jeffl" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > mac/protools.
    You ought to have a look at Reaper dood! Lotsa Pro Tools converts over
    there on their web forum. It runs on PCs and Macs too, besides being way
    efficient. The song I just put up has 32 tracks and 56 FX, most of heavy
    weight stuff like Vintage Warmers out the wazoo, numerous softsynths, and
    my PC was still only hitting around 35% CPU use.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  6. Sue Morton Guest
    Message Count:
    Jeff --
    I know your frustration well. But before you go that very expensive
    route...
    I recall you've looked at Reaper... have you given it serious
    consideration?
    Reaper is a 30-day trial BUT the program is always fully functional.
    That's the only reason I have a license today. My time was/is limited,
    so when I decided to examine Reaper I could not evaluate it properly in
    30 calendar days. It took me the better part of a year to learn it well
    enough to know I could use it, and I licensed my copy.
    I can't speak for the Reaper folks, of course, but I can't see how
    they'd mind you working with the program long enough to know if you can
    use it, as I did. Since you'd not be using the program to produce
    income or other viable work without paying for the license, it's in
    their best interest to allow you whatever time you need. If they were
    truly concerned about holding people to a 30 calendar day trial they
    would make it a LOT harder for the average Joe to run the program past
    the trial period by forcing them to use cracks etc.
    I'm not a spokesperson for Reaper and I'm not suggesting I think Reaper
    *will* work for you. But it costs you nothing (except your time) to
    check it out.
    Macs, protools etc. are all possibilities too -- and a lot more
    expensive to 'try'. Yes that's working out well for a number of people,
    but so is Sonar, Reaper, Nuendo, Samplitude, Cubase...
    Just my $0.02 USD.
    Sue Morton
    > haven't added any software and my DAW is not online..hmmmmm.....
    >> Sonar 7.2
    >> hit their icon or shortcut keys but neither works when summoning the
    >> synth view.
    >> Any ideas?
    >> Thanks again,
    >> Jeff
  7. Phoenix Guest
    Message Count:
    On Thu, 17 Jun 2010 06:40:05 -0400, "Steve_Karl" <>
    wrote:
    > DOH sorry ...
    > SK
    > > If more than ZERO
    > > S
    > >> online..hmmmmm.....
    > >>> Sonar 7.2
    > >>> Any ideas?
    > >>> Thanks again,
    > >>> Jeff
    You can run chkdsk on C: in Windows, just not with the other
    parameters. IIRC it gives a warning about possible inaccuracies but
    may give you an idea; then you do chkdsk/f and press Y when it asks
    you if you want it to run on reboot.
  8. gray asphalt Guest
    Message Count:
    Has this been answered yet? What happens when
    you click "enable tabs for open views" under the
    Views menu?
    > Sonar 7.2
    > Any ideas?
    > Thanks again,
    > Jeff
      • Advertising
Share This Page
