can't convert midi to audio, could be input/output problem?
Discussion in 'alt.steinberg.cubase' started by attaboy, Sep 24, 2009.
  1. attaboy Guest
    Message Count:
    Hi, I am using sx3, both midi track and audio track are audible, just
    can't get midi track converted to audio, the audio track can be
    created, but no wav form been picked up, the book says, I should
    connect midi output to audio input, could someone advise me how and
    where to go about with this.
    thanks very much
      • Advertising
  2. Hueyduck Guest
    Message Count:
    > connect midi output to audio input,-
    it certainly doesn't say exactly that ;-) Pears and apples, here.
    I assume that your midi tracks are related to external midi device, not
    VST-instruments.
    Your midi tracks don't make any sound, they are just a bunch of numeric
    messages that are sent to your external sound module.
    The sound module obeys, makes the sounds and then spit it out from its
    *audio outputs* (the 2 outputs that are probalbly linked to your mixing
    deks via jack plugs).
    For your midi track to be converted in audio track, you have to record
    what's coming from the audio input of your card on wich your sound
    module *audio* output is sending its sounds to.
    You now have to activate the said inputs in cubase (peripherals/VST
    input, set the one your sound module is plugged into to "active").
    Create an audio track that have your said input as source.
    Soloe your midi track along with your new audio track.
    Set your audio track to "record ready" and record your track.
    Huey
  3. GeF Guest
    Message Count:
    make sure you have selected the right ASIO driver to export your audio file
    Files ===> export ==> audio mix ==> here to select the file format,
    compression or not and so on. In the export audio menu you have to select
    the right driver
    gerard
    http://www.gerardferini.com/
    "attaboy" <> wrote in message
    news:...
    > thanks very much
      • Advertising
Share This Page
