can't set sample rate in Cubase LE 4
Discussion in 'alt.steinberg.cubase' started by gonzo, Aug 20, 2009.
  1. gonzo Guest
    Message Count:
    Hello--
    I am running Cubase LE 4, and I am using it to mix and edit wave files
    created on a couple of Zoom recorders (the H-2 and the H-4). I
    transferred the wave files from the H-2 (which were recorded at 96kHz)
    from the unit to my PC, and then when I try to load them into Cubase
    to edit them, I get an error that the sample rate cannot be changed
    due to the sampleclock being set to external sync. It then wants me
    to convert the files to 44.1 before it loads them into the project.
    It looks to me like the sync is already set to internal (according to
    the transport panel); is there somewhere else I need to adjust
    something?
    Thanks,
    --Stephen
      • Advertising
  2. Swanny Guest
    Message Count:
    gonzo wrote:
    > Hello--
    > something?
    > Thanks,
    > --Stephen
    Try setting the sample rate on your audio interface before entereing
    cubase. It may not be able to alter the interface sample rate once it
    has been set externally.
  3. Jos Geluk Guest
    Message Count:
    gonzo schreef:
    > Hello--
    > something?
    This may be obvious, and not the cause of your problem, but when I get
    that particular message it means that there was some other music
    software running at the time I started Cubase. So be sure to exit all
    other sound processing programs first.
    Jos.
    www.ardispark.nl
      • Advertising
Share This Page
