Compression Dilemma
Discussion in 'alt.steinberg.cubase' started by UkJay, Jan 19, 2009.
  1. UkJay Guest
    Message Count:
    Hi
    I have dabbled with compression in various ways on my recordings, and
    in many instances I feel as if I could do the same job by adjusting
    the level manually!
    It may be the fact that I'm using plug-ins instead of hardware and
    they don't do a good enough job, also the use of equalisation seemed
    to be more beneficial to bring out the main vocal rather than
    compression.
    I have read many articles on this subject and it seems that certain
    engineers have magic fingers and add sparkle to recordings with their
    secret knowledge!
    I've never been happy with any recordings I've ever done in the
    respect of the overall sound, but I think I'm learning slowly.
    In my latest recording "Running For Donna Louise" a charity song I
    decided NOT to use compression on the overall final mix although I
    have used some on the vocals.
    I did try compression on drums, but again I seemed to have better
    control just with judicious use of volume levels
    I have talked about this a while back but I still don't seem very
    impressed with compression using software.
    Can anyone convince me otherwise?
    Jay
    http://www.ukjay.co.uk
      • Advertising
  2. Hans Guest
    Message Count:
    On Mon, 19 Jan 2009 13:10:43 -0800 (PST), UkJay <>
    wrote:
    >Hi
    >the level manually!
    First of all: there are many compression plug-ins out there that do a
    marvellous job. As good as or better than hardware.
    Second: listen to any Whitney Houston ballad.
    Fantastic vocals (doesn't matter if they are to your taste: they are
    fantastic) and compressed until there's almost no dynamics left.
    So if you feel as if your fingers could do an equal job, then you're
    not compressing right.
    Compression is a powerful tool.
  3. UkJay Guest
    Message Count:
    On 19 Jan, 21:10, UkJay <> wrote:
    > Hi
    > the level manually!
    > compression.
    > secret knowledge!
    > Jayhttp://www.ukjay.co.uk
    Hi
    A big thanks to everyone who has contributed in helping me with
    compression
    There have been some really interesting replies!
    I posted this question in :-
    alt,music.home-studio, rec.music.makers.songwriting, and
    I dont use compression for the sake of it, my feeling is that it
    should help a track seperate
    everything and stop it being muddy sounding (if used correctly)
    I have been trying to pep up vocals and make the drum tracks more
    punchy without going into
    distortion, but I don't really appreciate the use of all the settings
    on a compressor and I need to
    take more time experimenting with this I suppose.
    It is temting to use compression for the sake of it even on the final
    overall mix, thinking that I'm
    some big shot wizard ;-) but I must admit I refrained from doing this
    on my latest recording
    "Running For Donna Louise" as I didn't think it would improve things.
    I may have gone a bit over the top with equalisation on the vocals
    though, but my voice does need
    every bit of help it can get!
    So once again THANKS for all the advice.
    Jay
  4. mo lei tau SODDI Guest
    Message Count:
    "UkJay" <> wrote in message
    news:...
    >> Hi
    >> the level manually!
    >> compression.
    >> secret knowledge!
    > Hi
    > compression
    > Jay
    The single most important question should probably be 'when does a track
    require compression?'
    In the case of purely electronic/synth tracks, I would think 'rarely' - but
    I could be wrong, I usually am.
    In the electronic environment, the variables of volume can be more easily
    controlled at the source. Unless you program it a certain way, a synth
    really doesn't have the dynamic range of something like an electric bass or
    the human voice.
    In the case of loops or samples, the dynamics are inherent in the original
    recording, and there isn't too much you can do post facto. Good EQing helps
    more.
    Having said that, and as I ONLY work with the computer/electronic palette
    (and in Cubase), I use compression two ways - one, at the end of certain VST
    effects chains, to avoid level spikes; and two, when using certain VST
    instruments that start out too hot. After I have the levels set in both
    cases, I remove the compression for recording.
    The recently deceased Robert Prosky had the single best line in John
    Carpenter's "Christine": "Ya can't polish a turd."
    That turd reference only applies to my work. I'm sure no one else in this NG
    turns out bum tracks that they GOTTA use.
      • Advertising
  5. UkJay Guest
    Message Count:
    > Hi
    > the level manually!
    > compression.
    > secret knowledge!
    Hi
    In reply to mo lei tau SODDI yes I've produced many
    sows ears (turds) but they are what makes others good because how can
    you have good if ther'es
    no bad?
    Getting back to my latest recording/compression dilemma, I know that
    compression should help
    in stopping overloading (peaks) but I find that compression can
    introduce more headaches if
    it isn't set up correctly, and this is the steep learning curve I am
    always struggling with.
    I know I want vocals and percussion to sound punchy but I haven't the
    experience of how to use
    the setting to achieve this as yet!
    Listening to my latest song "Running For Louise" I can hear breathing
    (sound more like wheezing) in places
    but that may be a result of being to close to the mic rather than
    compression or volume levels.
    ( I do like to get close )
    I know I could "go in" to the sound file and tidy that up but I didn't
    really notice it till too late!
    Anyway another step up the ladder of exprience if nothing else!
    Jay
  6. UkJay Guest
    Message Count:
    > Hi
    > the level manually!
    > compression.
    > secret knowledge!
    Hi
    you have good if there's no bad?
    compression should help in stopping overloading (peaks) but I find
    introduce more headaches if it isn't set up correctly, and this is the
    experience of how to use the setting to achieve this as yet!
    (sound more like wheezing) in places but that may be a result of being
    compression or volume levels. ( I do like to get close )
    didn't
    Anyway another step up the ladder of experience if nothing else!
    Jay
      • Advertising
Share This Page
