Control Surface?
Discussion in 'alt.steinberg.cubase' started by Jim, Jun 12, 2010.
  1. Jim Guest
    Message Count:
    Hello,
    I have Cubase3 SX and would like to know what I need to get to be able
    to control functions like record, stop, play etc. My friend has a
    Mackie device which has these on it, is it called a control surface?
    If so, what ones would you recommend for Cubase or does it matter?
    Thanks,
    Jim
    --- news://freenews.netfront.net/ - complaints: ---
      • Advertising
  2. Danny T Guest
    Message Count:
    On Jun 11, 10:04 pm, Jim <> wrote:
    > Hello,
    > Thanks,
    > Jim
    I have used about a dozen of them and for the basic functions, for the
    cost, get yourself a Tascam US 428. It actually gives you 8 faders but
    they are not motorized. I never used them because of that but it has 2
    midi in/out you may like and you can use the 4 tracks in and 2 out if
    you don't have a higher end converter. I actually really miss mine
    that I sold on ebay. I wish I hadn't. The transport is simple and
    always worked.
  3. nickm Guest
    Message Count:
    "Jim" <> wrote in message
    news:...
    > Hello,
    > Thanks,
    > Jim
    Behringer B-Control Fader BCF2000. 8 channel (x3 banks) motorised faders,
    transport control. Emulates Mackie Control. Works great.
    http://www.dv247.com/computer-hardw...-total-recall-usb-midi-controller-desk--21929
    for example - £133GBP/161 Euro. You can use multiple BCF2000 simultaneously
    to emulate a 24 channel mixer desk.
    Nick
  4. Cyberserf Guest
    Message Count:
    > news:...
    > > Hello,
    > > Thanks,
    > > Jim
    > transport control.  Emulates Mackie Control.  Works great.http://www.dv247.com/computer-hardware/behringer-bcf2000-total-recall...
    > for example - 133GBP/161 Euro.  You can use multiple BCF2000 simultaneously
    > Nick
    I concur, the BFC2000s works well in Mackie Emulations mode and one
    controller can control up to 32 tracks (using the Bank up and down
    buttons for 4 groups of 8 channels)...a simply non-latch foot switch
    can also be attached for one stomp record and if you connect via USB,
    it'll also provide an extra Midi in (I run my drum machine through
    it). The biggest problem is that the fader motors are quite noisy,
    particularly when you have multiple track automation going. On the
    plus side, it is much, much cheaper than a real Mackie Hui (though no
    jog wheel and the quality cannot really be compared...Mackies are
    nice). There are really quite a number of choices out there and SX3
    has direct support for most or you can create your own mapping.
    -CS
      • Advertising
  5. Jos Geluk Guest
    Message Count:
    Op 12-6-2010 5:04, Jim schreef:
    > Hello,
    > Thanks,
    > Jim
    For just transport (stop/start/record) also consider the Frontier Tranzport.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  6. Jim Guest
    Message Count:
    Cool...thanks to all of you for your advice / input, helps a lot!!
    Jim
    On Fri, 11 Jun 2010 23:30:07 -0700 (PDT), Danny T
    >> Hello,
    >> Thanks,
    >> Jim
    >always worked.
  7. Danny T Guest
    Message Count:
    > > Hello,
    > > Thanks,
    > > Jim
    > Jos.
    > Ardis Park Musicwww.ardispark.nl
    Hey - this unit looks pretty cool too. I really liked the US-428 feel
    and especially the jog wheel. Does this one feel solid and look like
    it will last? You can only buy used Tascam units though I think that
    isn't a problem. I think I rather like the small frame of your idea.
  8. Jos Geluk Guest
    Message Count:
    >>> Thanks,
    >>> Jim
    Yes...as far as a plastic case can feel solid, it does. It sits on top
    of my piano keyboard, so I can hit the buttons easily, and the rubber
    feet prevent it from slipping off. The jog wheel feels pretty reliable
    too. But what's really cool is that it's wireless, so I can move it
    around the studio, e.g. play guitar at the other end without having to
    reach over to the mixing desk.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  9. Danny T Guest
    Message Count:
    > >>> Thanks,
    > >>> Jim
    > Jos.
    Now that is cool. My biggest issue has always been being on both sides
    of the glass. I can extend a monitor but not too far and the iphone
    app helps but having a remote will be a big help too.
    Thanks
  10. Jos Geluk Guest
    Message Count:
    It is an infrared connection, or it feels like one anyway, so I am not
    sure it will work in your circumstances. I have been experimenting: At
    more than six meters, it will sometimes lose its connection, but three
    meters with double glazing in between is no problem. There is a
    connector with a 1.5m cable that needs to be plugged into an USB port of
    the computer. The placing of that connector (which is the size of a
    small cell phone) is important, and so may the state of the battery.
    Another important thing that I like: the action is absolutely instantaneous.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  11. XODDI Guest
    Message Count:
    On Jun 11, 11:04 pm, Jim <> wrote:
    > Hello,
    > Thanks,
    > Jim
    My M-Audio Keystation 88 has controls that are supposed to work with
    Cubase, but I cannot verify as their USB > MIDI Enigma software
    bollixed up my computer.
      • Advertising
Share This Page
