CPU Usage
Discussion in 'cakewalk.audio' started by moonpie, Jun 14, 2010.
  1. moonpie Guest
    Message Count:
    Hello all.
    I have a question that I'm afraid I may already know the answer to,
    and I dont like it...
    I'm doing a mixdown of a song my band is recording, and there are
    quite a few tracks, with many effects. Whenever possible, individual
    tracks are routed to a Bus with effects on the bus (and not on the
    individual tracks)
    Even so, when i'm mixing down, I get CPU usage of 48% and its causing
    the dreaded dropouts. Short of eliminating effects, or
    freezing/bouncing tracks, would adding more RAM to the machine help
    with this issue? I'm running Home Studio 6 under Windows XP, with 2
    gigs of ram.
    I'm thinking no, it wouldnt help, only a faser processor would... but
    I dont know.
    Any advice would be appreciated.
      • Advertising
  2. Sue Morton Guest
    Message Count:
    Since you're mixing, and not recording, have you increased the
    latency/buffers? When I record I have my ASIO latency set as low as
    possible, this is often sufficient for mixing too... but when there are
    many synths and/or many tracks, many effects, etc. I have raised latency
    as high as 100+ in order to work. Latency really means nothing unless
    you are recording from outside source, or working with realtime video.
    Give that a try?
    N.B. "If five is good, then 20 is better" in my experience does NOT
    apply here. Some soundcard drivers can introduce new problems if
    latency is too high. Go only as high as you need to get the job done is
    what I recommend. Good luck!
    Sue Morton
    "moonpie" <> wrote in message
    news:...
    > Hello all.
    > individual tracks)
    > gigs of ram.
    > I dont know.
  3. Gary R. Hook Guest
    Message Count:
    Right. The only oddity you'll experience is a delay between stopping
    playback (hitting the spacebar?) and actual cessation of sound. Or
    tweaks to an effect before it becomes audible. But even at 100+ ms the
    delay is not unpleasant.
    Also agree that you don't want to make it too long. But something in
    the 100 - 130 ms range can alleviate a lot of stress on the CPU while
    still providing modest playback performance.
  4. moonpie Guest
    Message Count:
    On Mon, 14 Jun 2010 09:37:43 -0500, "Gary R. Hook"
    I'll try that, great idea. Never considered that. Its a work in
    progress, like most i suppose... mix some, then somebody says, well,
    you should really add an electric 12 string to double this part... So
    then I have to add another track, and then turn off all the effects on
    everything, just to be able to record another track without it
    dropping out.,.. very weird, but if thats how it is, then ok
    one thing i've noticed, i often get a hard droput near the very end,
    at the same spot every time. I've noticed it "hangs up" when it gets
    to a spot where the audio on two tracks ends suddenly, the rest of the
    tracks keep going. Its like the play bar gets to the spot where those
    two tracks run out of audio, and it just stops.
    Is it possible that a sudden end to audio information could cause a
    hiccup like that?
      • Advertising
  5. Glennbo Guest
    Message Count:
    In news: the killer robot moonpie
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    > hiccup like that?
    I've seen that with Sonar before, and ended up adding recorded silence to
    the end of the song, then bouncing the audible and silent clips into one
    single clip. Sonar's audio engine is pretty finicky, and easy to cause
    pops, clicks, and even dropouts.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  6. polymod Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns9D976D1F95CADBrownShoesDontMakeIt@85.214.73.210...
    moonpie
    > > hiccup like that?
    Yup.
    Reaper 3.60 is up<g>
    Poly
  7. Glennbo Guest
    Message Count:
    The killer robot "polymod" <> grabbed the controls
    of the spaceship cakewalk.audio and pressed these buttons...
    >> > a hiccup like that?
    >> silence to the end of the song, then bouncing the audible and silent
    >> clips into one single clip. Sonar's audio engine is pretty finicky,
    >> and easy to cause pops, clicks, and even dropouts.
    > Yup.
    I downloaded and installed it this weekend. Even started a new song with
    a mamoth midi instrument I created using Ticky Clav, Sample Tank with an
    acoustic guitar, an Arp string ensemble, and a Roland Juno synth model.
    It's a cool sound in that the clav and acoustic guitar are panned off of
    each other and decay away to nothing, while the strings and synth are
    lower volume, also panned off of each other, but sustain forever. It's
    got a plucky and etherial sound that made me wander off to Mahavishnu
    territory halfway through the song. No dropouts, pops or clicks. ;)
    ________ __
  8. moonpie Guest
    Message Count:
    On Mon, 14 Jun 2010 13:04:33 -0400, "polymod" <>
    >moonpie
    >> > hiccup like that?
    >Yup.
    >Poly
    you read my mind. Friend of mine is using Reaper and loves it, could
    probably go over to his house and get some lessons. Is the audio
    engine in Reaper less particular? How easy is it to learn the
    interface?
    more importantly, how easy is it to take a big SONAR project and put
    it to Reaper?
  9. Glennbo Guest
    Message Count:
    The killer robot moonpie <> grabbed the controls
    > Is the audio engine in Reaper less particular?
    It's one of, if not the baddest audio engine on the planet.
    > How easy is it to learn the interface?
    It's got a bit of a learning curve. Was totally worth it IMO.
    > it to Reaper?
    Audio tracks can easily be moved en masse using Reaper's "ReaRoute",
    which is a virtual ASIO audio cable. Midi tracks can also be moved in
    that same shot using Reaper's ability to act as a ReWire device.
    ________ __
  10. Steve Ardcorr Guest
    Message Count:
    Just a guess, but with regards to sonar suddenly stalling at the end
    of the 2 audio tracks, I'm wondering whether it might be that you need
    to check the, "play effect tails after stopping" in options/audio/advanced
    Either check it or uncheck? Probably the former.
    Steve
    news:...
    > hiccup like that?
    --- news://freenews.netfront.net/ - complaints: ---
  11. moonpie Guest
    Message Count:
    On Mon, 14 Jun 2010 18:03:59 +0000 (UTC), Glennbo
    >> it to Reaper?
    i use 'lectronic drums with a midi brain, that sends a midi signal to
    sonar, and then i insert EZ drummer as a soft synth to it. I assume
    Reaper can do this too, but doesnt hurt to ask... can it?
  12. moonpie Guest
    Message Count:
    On Tue, 15 Jun 2010 10:47:00 +0100, "Steve Ardcorr"
    >Steve
    thats a good idea too, thanks!
  13. Glennbo Guest
    Message Count:
    My drum kit.
    http://members.cox.net/glennbo/PadDrums.jpg and
    http://members.cox.net/glennbopix/ReaperDrums.jpg
    > I assume Reaper can do this too, but doesnt hurt to ask... can it?
    At 1ms latency on my system.
    ________ __
  14. moonpie Guest
    Message Count:
    On Tue, 15 Jun 2010 13:42:41 +0000 (UTC), Glennbo
    >My drum kit.
    it says "Superior Drums". I guess those are ToonTrack, not some sort
    of native Reaper drum thing? So you posted those pics to say, YES, it
    does it exactly the same way as sonar?
    uh.... is that better or worse than sonar?
    Ha! you guys are about a billion miles ahead of me in all this.
  15. Glennbo Guest
    Message Count:
    The killer robot moonpie <> grabbed the controls of
    >>My drum kit.
    Yeah, that's Superior Dummer 2 which is EZ-Drummer's big brother, and like
    you I use a pad kit to play Superior when I'm recording.
    1ms is ultra fast, and makes it so no lag is felt. I was able to hit 1.5ms
    latency with Sonar, but at the cost of dealing with flakey stuff happening.
    ________ __
  16. moonpie Guest
    Message Count:
    On Tue, 15 Jun 2010 16:31:17 +0000 (UTC), Glennbo
    >>>My drum kit.
    ok thanks.
    is there anything that you can do in sonar, that you really cant do in
    reaper?
    how about reaper tutorials? are they easy to find?
  17. Glennbo Guest
    Message Count:
    > reaper?
    Not anything that I ever did in Sonar, but I use both Sonar and Reaper
    mostly to record performances of me or others actually playing a part, so
    more often than not, I'm simply hitting record and then playing something.
    There are numerous tricks that Reaper can do that Sonar cannot do though.
    You can side-chain *any* automatable plugin in Reaper, as it allows you to
    use the changing levels on one track tweak FX parameters on a completely
    different track. It also will let you either stack multiple softsynths on
    one track, or you can have one midi track drive softsynths on multiple
    other tracks. The latter can easily be laced up using drag-n-drop routing,
    which is in fact, exactly what I used on a song I'm currently working on.
    http://members.cox.net/glennbopix/Drag-n-DropRouting.avi
    There are some up on youtube.com, and their forum can answer most if not
    all questions you might have on how to accomplish things.
    ________ __
  18. moonpie Guest
    Message Count:
    On Tue, 15 Jun 2010 17:28:17 +0000 (UTC), Glennbo
    >> reaper?
    thank you, you're very helpful.
    I might try it, after i get two songs finished in sonar, i might play
    around with reaper.., i dont think changing horses in midstream is too
    good of an idea right now
    are you on the reaper forum?
  19. Glennbo Guest
    Message Count:
    >>controls of the spaceship cakewalk.audio and pressed these buttons...
    >>> in reaper?
    >>so more often than not, I'm simply hitting record and then playing
    >>something. There are numerous tricks that Reaper can do that Sonar
    >>cannot do though. You can side-chain *any* automatable plugin in
    >>Reaper, as it allows you to use the changing levels on one track tweak
    >>FX parameters on a completely different track. It also will let you
    >>either stack multiple softsynths on one track, or you can have one
    >>midi track drive softsynths on multiple other tracks. The latter can
    >>easily be laced up using drag-n-drop routing, which is in fact,
    >>not all questions you might have on how to accomplish things.
    I wouldn't suggest doing anything more than playing around with Reaper at
    first. For me, I real quickly found it to be more resilliant to my piling
    on FX and running at ultra low latency, and since I was between projects, I
    just started my next one in Reaper to see how far I'd get. Thirty or so
    songs later, I'm still using it. ;)
    Only on occasion. I really dislike web based forums.
    ________ __
  20. moonpie Guest
    Message Count:
    On Tue, 15 Jun 2010 18:17:29 +0000 (UTC), Glennbo
    >>>> in reaper?
    I take it Reaper works in Windows XP as well as Windows 7?
      • Advertising
Share This Page
