Creative Audigy 4 Pro woes
Discussion in 'alt.steinberg.cubase' started by Gary, Nov 15, 2009.
  1. Gary Guest
    Message Count:
    I've been using this in conjunction with Cubase SX3 for a few years now, no
    problems. At the time I installed XP and noted that the Audigy card *has* to
    have an exclusive IRQ to function fully.
    I thought it was about time I upgraded my system (which was an old Athlon
    2200+ processor, Abit KR7A motherboard) and opted for an AMD Phenom II x4
    955 BE processor with an Asus M4A77TD motherboard. The latter wasn't my
    first choice, but I wanted the 3 PCI slots for various essential cards,
    including the Audigy 4.
    I did a clean install of XP SP3 and all is working as expected (excellent
    processing power) but it allocates the Audigy a shared IRQ. Whilst it still
    works, the full functionality isn't realised, with apparently no ASIO 2
    support for example. My usual way to ensure it gets its own IRQ is to
    install XP using the "Standard PC" HAL configuration during the initial set
    up, as it's not something that can be changed afterwards. However, this will
    not work under a multiprocessor system :(
    It would seem my only choice will be to get a new soundcard with the same
    facilities, which doesn't have such stupid IRQ issues.
    If anyone can offer advice or suggest solutions/work arounds to the Audigy
    problem, then I'll greatly appreciate it.
    Also, if anyone can suggest another card (PCIe) that will offer similar or
    better performance, then that'll be welcome too.
    TIA,
      • Advertising
  2. nickm Guest
    Message Count:
    "Gary" <> wrote in message
    news:hdokmq$kv2$-september.org...
    > no problems. At the time I installed XP and noted that the Audigy card
    > *has* to have an exclusive IRQ to function fully.
    > still works, the full functionality isn't realised, with apparently no
    > ASIO 2 support for example. My usual way to ensure it gets its own IRQ is
    > to install XP using the "Standard PC" HAL configuration during the initial
    > set up, as it's not something that can be changed afterwards. However,
    > this will not work under a multiprocessor system :(
    > TIA,
    > Gary
    Good old PCI and IRQ sharing issues eh? :)
    Don't give up just yet. You *may* find some info in the motherboard manual
    that will help. I haven't had cause to look for any of the more recent
    systems I've built over the last two or three years, but there pretty much
    always used to be a table in motherboard manuals that showed which PCI
    sockets and graphics sockets were hard wired to share the same IRQ. Using
    this info made it somewhat easier to move fussy cards that demanded their
    own IRQ to an appropriate PCI slot. In the (very likely) event that your
    motherboard manual doesn't contain any useful info, you could try simply
    swapping your various PCI cards around in an attempt to find a workable
    solution. You might also be able to set IRQ control to your preferences
    rather than being controlled by the OS in the BIOS.
  3. Gary Guest
    Message Count:
    Thanks Nick, I've tried two PCI slot permutations thus far, one remaining...
    I've disabled the BIOS to select the IRQ allowing XP to do so. However, the
    lack of the "Standard PC" HAL configuration during installation set up
    usually means XP happily lets numerous devices use the same IRQ :(
  4. nickm Guest
    Message Count:
    news:hdosbi$53r$-september.org...
    > remaining...
    > the lack of the "Standard PC" HAL configuration during installation set up
    Yes. More or less that used to work with some troublesome cards, but with
    older single core CPUs. I'm thinking in particular of an old Pinnacle 500
    video capture card which needed 3 separate IRQs and took some fiddling about
    with to get it to work properly with XP. I think XP SP3 was a step too far
    for this card though. :-(
    Creative cards have never been particularly good with regard to DAW
    application. I don't know about the Audigy 4 to be fair, but the earlier
    Audigy cards were a pain, so it's not even something I'd consider and
    haven't done since Windows 98 days. You'd possibly be better going for a
    decent external Firewire interface or possibly a USB interface (I personally
    prefer Firewire because there's usually less chance of bandwidth issues - no
    onboard USB hubs to worry about). Look at M-Audio, Tascam or Edirol for
    starters and for some future proofing - there's always MOTU too. Echo Audio
    always used to make reliable kit too - I still have a couple of ten or
    eleven year old Echo Gina ver 1 cards which were great in their day.
    Good luck
      • Advertising
  5. Gary Guest
    Message Count:
    I've always endured IRQ issues with Creative Soundblaster cards (who
    hasn't?!), but I expected the Audigy 4 to have resolved such problems, sadly
    it wasn't the case.
    > personally prefer Firewire because there's usually less chance of
    > bandwidth issues - no onboard USB hubs to worry about). Look at M-Audio,
    > Tascam or Edirol for starters and for some future proofing - there's
    > always MOTU too. Echo Audio always used to make reliable kit too - I
    > still have a couple of ten or eleven year old Echo Gina ver 1 cards which
    Thanks, I'll have a browse.
    I had briefly looked at PCIe cards, but the mainstream products don't seem
    to have any aimed at 'serious' audio use, no MIDI ports etc.
  6. nickm Guest
    Message Count:
    I'm currently using a Yamaha 01v96v2 with mLAN card as my main multi-channel
    Firewire interface. Running under Windows 7 64 bit on an Intel i7 based
    system and using the XP 64 bit driver in Test Mode. Works really well -
    especially considering it shouldn't. I can't really understand why Yamaha
    haven't developed a proper 64 bit driver for Vista and Windows 7. I have
    also got a MOTU Traveler and an M-Audio FW1814 both of which work well with
    a laptop - M-Audio took a very long time to come up with a 64 bit driver for
    Windows which is why I got the Traveler.
    It depends on your budget, number of inputs and outputs required, quality
    required and computer interface preference. If money isn't particularly an
    issue (when isn't money an issue?), I would definitely take a look at the
    MOTU Ultra-Lite Mk3 or the Traveler Mk 3. MOTU stuff isn't cheap, but it's
    pretty decent in my experience and they seem to be on the ball with drivers.
    Otherwise, maybe one of the Tascam interfaces. I have a little old 2 in/2
    out + MIDI Edirol UA-20 which, when Vista 64 first appeared in Jan 2007 was
    discontinued, BUT Edirol still had a 64 bit driver for Vista available from
    day one - and it's still supported in Windows 7. You sometimes see these on
    eBay for not too much cash.
  7. Hueyduck Guest
    Message Count:
    Hi gary,
    Don't have the time to be sure that my answers will fit exactly your
    case, but anyway:
    - You Motherboard manual might indicate the default IRQ settings and
    sharing map (my old KG7raid manual did)
    - Have you tried all of your 3 PCI slots? With no scientific protocol,
    you just have to try each PCI slot until Windows shows that your audio
    card is the only one using a given IRQ==> this is what I had done with
    my old PC.
    - if no PCI slot gives you satisfaction, chose the one wich makes your
    audio card share a IRQ with something you don't care about (integrated
    audio chipset, firewire, LAN...). Then disable the peripheral which is
    sharing it's IRQ with your audio card. Reboot: you're done.
    Just in case it helps ...
    Huey
  8. Gary Guest
    Message Count:
    "Hueyduck" <> wrote in message
    news:4b004237$0$3037$...
    Yep.
    Thanks, I did used to do this on a previous installation (I had a separate
    XP installation purely for music creation use, which is not a bad idea
    anyway).
    However, I removed all other PCI cards today and while the Audigy did indeed
    appear to have an exclusive IRQ, it still doesn't function correctly,
    clearly it will only work on a specific IRQ, presumably 5, as with so many
    Soundblaster cards.
    Therefore my only choice (as there's no installation technique I can employ
    to choose the IRQ for it) appears to be a new card :(
  9. Gary Guest
    Message Count:
    Thanks for the info and suggestions. To be honest I don't really need
    anything beyond what's provided with the Audigy 4 Pro, so I'll be looking at
    the more economical options.
  10. Hueyduck Guest
    Message Count:
    What would be your budget if you decided to buy a new card?
    Huey
  11. Gary Guest
    Message Count:
    news:4b027c41$0$25388$...
    In the region of £125.
  12. nickm Guest
    Message Count:
    news:hdu20h$u1a$-september.org...
    Just for a rough idea of prices etc... I've taken a look on Dawsons Web
    site - www.dawsons.co.uk (other suppliers are available)
    Prices may possibly be bettered elsewhere (very probably). Look at
    www.dv247.com for example (I haven't looked there for comparison)
    USB Audio/MIDI
    M-Audio Fast Track Pro 4x4 Mobile USB Audio/MIDI interface £160
    Edirol UA4-FX USB Audio interface - £145
    Alesis IO2 USB Audio Interface £110 - this looks quite good for the money
    Tascam US-122L - £130
    Tascam US-144 £160
    PCI - Audio/MIDI
    M-Audio Audiophile 2496 Digital Audio Card - £58.71
    M-Audio Audiophile 192 PCI - £130
    M-Audio Delta 1010LT - £146
    EMU 0404 PCI - £100
    Just a few there that would do the job and priced sort of near your budget
    :) All better IMO than the Audigy
    Nick
  13. Gary Guest
    Message Count:
    Excellent, thanks Nick :)
  14. Gary Guest
    Message Count:
    Much to my surprise, I've now resolved the problem and I'm still rolling my
    eyes over it... ;)
    The problem was that the only ASIO options given within Cubase SX 3 were for
    DirectX, so very limited, high latency etc.
    I couldn't see a way out of this and assumed it was the card's driver
    limiting the functionality because of hardware constraints (.i.e. not having
    the correct IRQ resources). This seemed to be borne out when, on a previous
    installation a few years ago, it would only seem to function correctly when
    (after a lot of jiggery pokery) I got it working on IRQ 5.
    However, I thought I'd install a VST instrument to at least see if the
    latency was manageable in the short term at least, but was then surprised to
    find the Creative ASIO and other parameters were now suddenly made available
    (at first with the standalone instrument and then via Cubase). Note that
    even before, ASIO4ALL wasn't given as an option either.
    After all the head scratching, it's quite a relief :)
      • Advertising
Share This Page
