Cubase 5 licensing/copy protection?
Discussion in 'alt.steinberg.cubase' started by tonewheel, Jun 21, 2009.
  1. tonewheel Guest
    Message Count:
    Hi,
    I'm considering getting Cubase 5 - currently using Cubase LE that came
    bundled with some hardware. With LE I'm able to install it as many
    times as I like which is useful as I have it on my main home studio
    computer plus a laptop for location recordings. I never use both at
    the same time.
    Would this be possible with 5? I'm thinking that if there's just a
    dongle then I could plug that into whichever computer I was using that
    day, but if it's one of those products that forces 1-time activation
    then I'm out of luck (unless I buy two copies of course).
    Also, if it is 1-time activation, and I find I want to re-install my
    complete OS (I do this from time to time), will the software activate
    again without problem (anyone tried this?). If I completely replaced
    my studio PC what then? (I'm generally not a fan of activation s/w for
    precisely this issue!)
    Looking for some guidance before laying out half a grand..
    cheers,
    TWJ
      • Advertising
  2. Phil W Guest
    Message Count:
    tonewheel wrote:
    > Hi,
    > the same time.
    According to what a Steinberg guy said at a Cubase5 demonstration workshop
    recently, it *is* possible and allowed to install Cubase5 on as many
    machines as you wish to. To use the program, you have to plug in a dongle.
    So, it´s possible and allowed to move the USB dongle from computer to
    computer.
    He said nothing about an activation procedure.
    That´s all I can say about this, as I´m not a C5 user yet...
    Hope that helps,
    Phil
  3. Laurence Payne Guest
    Message Count:
    >Hi,
    >the same time.
    Yes, it's a dongle. Install wherever you like, carry the dongle
    around.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  4. tonewheel Guest
    Message Count:
    On 21 June, 16:41, Laurence Payne <> wrote:
    > >Hi,
    > >the same time.
    > around.
    > CubaseFAQ page:http://www.laurencepayne.co.uk/CubaseFAQ.htm
    Brilliant, cheers chaps for speedy replies :)
    TWJ
      • Advertising
Share This Page
