Cubase and Delta 1010 midi hook up
Discussion in 'alt.steinberg.cubase' started by Jim, Aug 22, 2010.
  1. Jim Guest
    Message Count:
    Hi,
    To get midi to function (record) properly, do I need anything more
    than midi in and midi out connections with this configuration? I
    noticed a midi connection on the back of the delta 1010 as well but
    don't know what to hook it to (if needed).
    Thanks,
    Jer
    --- news://freenews.netfront.net/ - complaints: ---
      • Advertising
  2. lancelightning Guest
    Message Count:
    On Sun, 22 Aug 2010 18:28:26 -0400, Jim <> wrote:
    >Hi,
    >Thanks,
    >Jer
    Sorry but I'm not sure that I fully understand your question. The midi
    connection on your Delta should work ok with Cubase. Connect a midi
    keyboard/controller and it will trigger any virtual instument (VSTi)
    or an external sound module if you have one or more. It will probably
    allow you to control loads of other Cubase functions too, depending on
    what facilities the keyboard has onboard
    LL
  3. Jim Guest
    Message Count:
    >>Hi,
    >>Thanks,
    >>Jer
    >LL
    Thanks for your response LL.
    I have it hooked up to my Korg Triton LE and can see and hear midi
    data I record into Cubase. The problem is I don't seem to have control
    of what sounds it's recording. I'll play and record an organ sound but
    when played back...I hear some random keyboard sound.
    Jer
  4. Phil W Guest
    Message Count:
    "Jim" <> schrieb im Newsbeitrag
    news:...
    >>>Hi,
    >>>Thanks,
    >>>Jer
    >>LL
    > Jer
    Typical misunderstanding:
    MIDI is ONLY "controller data", not sounds!!!
    Seems like, you urgently need a good reading an basics of (home) recording
    in general. ;-)
      • Advertising
  5. Jim Guest
    Message Count:
    >news:...
    >>>>Hi,
    >>>>Thanks,
    >>>>Jer
    >>>LL
    >> Jer
    >in general. ;-)
    Ok, let me rephrase...How can I get sounds in my Triton LE recorded
    into Cubase. Is there some sort of midi map I need for that particulat
    keyborad?
    Jer
  6. Phil W Guest
    Message Count:
    Jim:
    >>news:...
    >>>>>Hi,
    >>>>>Thanks,
    >>>>>Jer
    >>>>LL
    >>> Jer
    >>in general. ;-)
    > keyborad?
    > Jer
    Okay, that´s the next step! ;-)
    I´m not a MIDI freak, so others might be better at answering this. But I´ll
    try it anyway...
    1) select the sound patch in your Triton LE (or whatever external MIDI sound
    generator) to your choice
    2) connect MIDI OUT of the computer´s audio interface to the Triton´s MIDI
    IN
    3) connect the LINE OUT of the Triton to the LINE IN of the audio interface
    4) in cubase: make a new Audio track (mono or stereo depends on your cabling
    situation, usually stereo for synths)
    and set the inputs according to the Line INs, where you connected the Triton
    5) record ENABLE this audio track
    6) play back the song in *real-time* sending MIDI notes to the Triton, while
    receiving it´s audio output into the audio interface/soundcard.
    that´s the whole deal.
  7. lancelightning Guest
    Message Count:
    >>>Hi,
    >>>Thanks,
    >>>Jer
    >>LL
    >Jer
    As Phil has said, you're actually recording midi data and not the
    actual sounds. Likewise, I'm no midi whizz but, as I understand it,
    the trick is to get Cubase to return this data back to your Korg in a
    format which it can read and thus play back the correct voices. There
    are various 'maps' you can load in Cubase...possibly one for your
    Triton...You'd have to do your homework here. Its not really my thing
    as I use Vsti's and no outboard sound sources.
    I think I'm on the right lines but maybe one of the other guys here
    who know this stuff better than me can help make more sense of it for
    you.....LL
  8. lancelightning Guest
    Message Count:
    >you.....LL
    I just loaded up Cubase 5. Check out 'midi device manager'...there's 3
    Korg Triton maps in there to choose from. I don't if these will sort
    your problem as I have never used a Triton, but I'd guess that this is
    the area to be looking........LL
  9. Phil W Guest
    Message Count:
    "lancelightning":
    >>you.....LL
    And, if you find, one of these maps suits your needs and wishes, you´ll have
    to check out, how to send patch-changes (or something similar) with your
    MIDI events. Then, you can include the "correct" sound patch in the MIDI
    events and the Triton sets to those patches when starting playback in
    Cubase.
    Look up the Cubase manual, for how to do this!
    If I understood and remember it correctly, Cubase does not record MIDI patch
    numbers/banks by default.
    As I wrote before, what works usually, is to record MIDI without patches,
    then select the desired sound on the external MIDI sound generator (Triton
    LE in your case) and start playback, while recording the synths audio output
    to a (new) audio track.
    With this method, you can also record other sounds as audio, than the one,
    you actually used, when recording the MIDI notes.
    IF you want several different sounds from the Triton within one song, you
    have to repeat the whole procedure for each sound!
    Once, you have successfully captured the audio output from the Triton, you
    can mute the MIDI tracks and use the corresponding audio track(s) for
    mixing.
    Here are some links for further reading (besides the manual, of course
    http://www.laurencepayne.dsl.pipex.com/CubaseFAQ.htm
    since Laurence doesn´t seem to be active since a few months, here´s his
    Cubase FAQ
    http://www.cubasewiki.com/index.php?title=Cubase_FAQ
    just found it by searching the web. Also check out the rest of this page!
    seems quite helpful
    good luck,
    Phil
  10. Jos Geluk Guest
    Message Count:
    > have to check out, how to send patch-changes (or something similar) with
    > your MIDI events. Then, you can include the "correct" sound patch in the
    > MIDI events and the Triton sets to those patches when starting playback
    > in Cubase.
    > patch numbers/banks by default.
    While I agree with all of this, it is even simpler, once you have loaded
    the correct MIDI map for your Triton. You create a MIDI track, and
    choose the appropriate sound in the left hand column. Then at playback,
    Cubase will send the right bank and patch select messages to the Triton.
    You don't need to touch the Triton at that point, and you don't need to
    manually insert patch or bank select messages. BTW the Triton is not
    unique in this, any external MIDI module works this way AFAIK.
    > patches, then select the desired sound on the external MIDI sound
    > generator (Triton LE in your case) and start playback, while recording
    > the synths audio output to a (new) audio track.
    > one, you actually used, when recording the MIDI notes.
    > you have to repeat the whole procedure for each sound!
    This will work, but to save you some time: you can build up to 16 tracks
    in Cubase (one for each MIDI channel), each set to a different Triton
    sound, all without changing the settings on the Triton.
    And you can of course record 16 separate audio tracks, but you can also
    just do a mix-down, mixing the audio channel pair from the Triton with
    other audio tracks in one go. (Mixdown must be set to "Real-time" for
    this to work).
    > you can mute the MIDI tracks and use the corresponding audio track(s)
    > for mixing.
    > Cubase FAQ
    > page! seems quite helpful
    Jos.
    Ardis Park Music
    www.ardispark.nl
  11. Jim Guest
    Message Count:
    Thanks for all your advice and insight on this guys, I really
    appreciate the time you took to answer this for me. I'll try all these
    out and will post back when / if I get this figured out.
    Jim
    On Tue, 24 Aug 2010 10:59:42 +0200, Jos Geluk <>
    >> in Cubase.
    >this to work).
    >> for mixing.
    >> Cubase FAQ
    >Jos.
      • Advertising
Share This Page
