Cubase and MIDI functionality
Discussion in 'alt.steinberg.cubase' started by Jim, Jun 12, 2010.
  1. Jim Guest
    Message Count:
    Hello,
    I have Cubase3 SX and have MIDI kind of working with it. I can record
    MIDI and see the MIDI data in the track but my problem is that I can't
    seem to control or even get out the correct sounds of the keyboard I
    have it connected to via MIDI. I have a Korg Triton LE.
    Is there something I have to configure to get the sounds from it?
    Thanks,
    Jim
    --- news://freenews.netfront.net/ - complaints: ---
      • Advertising
  2. XODDI Guest
    Message Count:
    On Jun 12, 4:31 pm, Jim <> wrote:
    > Hello,
    > Thanks,
    > Jim
    "Local Off" on the keyboard?
  3. Jos Geluk Guest
    Message Count:
    Op 12-6-2010 22:31, Jim schreef:
    > Hello,
    If I understand your setup correctly, you will need two midi cables. One
    goes from MIDI OUT on the Korg to the MIDI in of your sound card. This
    one seems to be working. Then you will need another one from your sound
    card's MIDI OUT to the MIDI IN of the Korg. This will feed the recorded
    notes from Cubase into the Korg so it can actually produce sounds.
    And yes, like Xoddi says, you will have to set "Local OFF" so the
    sounds can be controlled by Cubase.
    Sorry if this is a bit obvious and does not solve your problem.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  4. Jim Guest
    Message Count:
    Thanks Jos and Xoddi, I'll give 'er a look!!
    Jim
    On Mon, 14 Jun 2010 21:42:55 +0200, Jos Geluk <>
    >> Hello,
    >Jos.
      • Advertising
Share This Page
