Hmm...... this may soundlike a stoooopid question but................. Where are the VST Instruments located in Cubase LE 4 ??? on earlier versions it was under the menu Devices Or Window..can't remember which This is for OSX btw. Thanks in advance for your help
<> wrote in message news:... > Hmm...... this may soundlike a stoooopid question but................. > > Where are the VST Instruments located in Cubase LE 4 ??? > > on earlier versions it was under the menu Devices Or Window..can't > remember which > > This is for OSX btw. I don't use Cubase 4 LE very often, but it was a freebie with a couple of devices (Alesis H4 and Tascam US1641) so I have installed it on my Windows laptop. I've just taken a quick look and it appears that you need to create an Instrument track in the Arrange window and from the channel inspector panel on the left you can select from available VST instruments. Hopefully it's the same on the Mac version
