I've been gone for a while. Is cubase running right on Snow Leopard now? If so, is it worth the upgrade? Thanks
On 2010-02-11, Danny T <> wrote: > I've been gone for a while. Is cubase running right on Snow Leopard > now? If so, is it worth the upgrade? > > Thanks Cubase Studio 4 seems to run quite well on SL. Note that I use very little MIDI, mostly just live capture and editing. I upgraded to SL from 10.5 w/o re-installing CS4 and all seems well so far. Good luck! JB -- ----------------------------------------------- The heat from below can burn your eyes out!!
On Feb 12, 9:46 am, John Bleichert <> wrote: > On 2010-02-11, Danny T <> wrote: > > > I've been gone for a while. Is cubase running right on Snow Leopard > > now? If so, is it worth the upgrade? > > > Thanks > > Cubase Studio 4 seems to run quite well on SL. Note that I use very > little MIDI, mostly just live capture and editing. > > I upgraded to SL from 10.5 w/o re-installing CS4 and all seems well so > far. > > Good luck! > > JB > > -- > ----------------------------------------------- > The heat from below can burn your eyes out!! Thanks for the vote. I went sailing for 6 months and soft of got lost from the tech thing.... I do capture too - no midi at all. Have a great day http://www.dannytaddei.com
RE: "I've been gone for a while. Is cubase running right on Snow Leopard now? " I've been using Cubase LE4 with Snow Leopard since it came out, without problems. It's worked fine with 10.6, 10.6.1, and 10.6.2. I previously was using OS 10.4.11, no problems there, either. - John
On Feb 15, 11:28 pm, John Albert <> wrote: > RE: > "I've been gone for a while. Is cubase running right on Snow > Leopard now? " > > I've been using Cubase LE4 with Snow Leopard since it came > out, without problems. It's worked fine with 10.6, 10.6.1, > and 10.6.2. > > I previously was using OS 10.4.11, no problems there, either. > > - John I just ordered snow leopard..... Thanks
Cubase 5 and Snow leopard was pure hell for about the first 6 months. Constant crashes and incompatiblities with various plug-ins. Mostly everything seems to be working now though. (learned my lesson tho... never upgrade straight away) In article <>, Danny T <> wrote: > On Feb 15, 11:28 pm, John Albert <> wrote: > > RE: > > "I've been gone for a while. Is cubase running right on Snow > > Leopard now? " > > > > I've been using Cubase LE4 with Snow Leopard since it came > > out, without problems. It's worked fine with 10.6, 10.6.1, > > and 10.6.2. > > > > I previously was using OS 10.4.11, no problems there, either. > > > > - John > > I just ordered snow leopard..... Thanks
