Cubase SL 2.0 - Recording from synthesizer
Discussion in 'alt.steinberg.cubase' started by Matthias Cl, May 12, 2004.
  1. Matthias Cl Guest
    Message Count:
    Hi, I'm Matthias.
    My problem is about recording in Cubase SL 2.0.
    I've got a synthesizer (Korg Triton LE) linked with my pc via an
    Edirol Midi Interface.
    My pc is a Pentium 4 3.0 Ghz, so a powerful machine.
    My soundcard is a C-Media AC 97 Audio Device.
    This soundcard was integrated in my pc from the time I bought it.
    Because my pc is still very new, I've got the latest drivers for this
    soundcard.
    Now the problem is, when I want something to be recorded from my
    synthesizer to my pc, I've got a certain latencyproblem which causes
    that not only the notes are displayed later than they are played, but
    also that the first notes after activating the recordingmode are never
    recorded.
    This is a problem I also have with the synchronizer.
    To make myself clear: First I display the synchronizer and I check
    that all the inputs and the options (and also those on my synthesizer)
    are activated correctly, etcetera…
    I activate the synchronizing mode and the recording starts; the notes
    are displayed a few moments after you start recording (latency), but
    the first notes which are played, aren't recorded.
    What can I do to prevent this latency and have the first notes
    recorded?
    Does it help to have a new, non-integrated, more expensive soundcard?
    Any help is very welcome.
    You may always send to the following address:
    Greetings and thanks a lot,
    Matthias ;-).
      • Advertising
  2. Aphelion Guest
    Message Count:
    On 12 May 2004 06:30:40 -0700, (Matthias Cl)
    wrote:
    >Hi, I'm Matthias.
    Hi Matthias,
    See reply at bottom.
    >soundcard.
    >recorded.
    >recorded?
    First of all, the answer is Yes. The internal audio cards are really
    inexpensive devices used for general audio, CD/DVD playback...etc. The
    drivers are not usually up to snuff.
    However... the internal audio may in fact not be completely to blame.
    There's a known problem using (emulated) MIDI ports.
    Do not use the emulated ports.
    CubaseSL should have some "release notes" in the root folder.
    Look for the section on "ignoreportfilter" or "MIDIPortFilter".
    After moving the "ignoreportfilter" file to the Cubase root directory,
    do the following:
    Under Devices/Device Setup is a menu for "Direct Music" or "DirectX",
    Go there and select "NO" for all of the ports you should not be left
    with any emulated ports. Also... do not select "All MIDI Inputs". Go
    through, or use Ctrl/Selct to set each track's input port to the
    actual MIDI input you are using.
    As for syncing.... and missing notes, part of the prolem may be the
    emulated ports so try that fix first.
    Usually the recording device is designated as "sync" master. Cubase
    does send MIDI clock so set it up as the master clock source. The
    synth should follow Cubase.
    Ap
    >Matthias ;-).
  3. Matthias Cl Guest
    Message Count:
    (Aphelion) wrote in message news:<>...
    > wrote:
    > Thank you very much for your help, I'll try it out as soon as possible !!!
    > Matthias
    > >Hi, I'm Matthias.
    > Hi Matthias,
    > >soundcard.
    > >recorded.
    > >are activated correctly, etcetera?
    > >recorded?
    > do the following:
    > Ap
    > >Matthias ;-).
  4. Matthias Cl Guest
    Message Count:
    (Matthias Cl) wrote in message news:<>...
    > You say not to use emulated MIDI ports but, what do I have to use instead of it?
    Greetings,
    Matthias.
    Hi, I'm Matthias.
    > soundcard.
    > recorded.
    > recorded?
    > Matthias ;-).
      • Advertising
  5. Aphelion Guest
    Message Count:
    On 13 May 2004 09:03:16 -0700, (Matthias Cl)
    Ports that do not have (emulated) after the name.
    Ap
  6. iCon Guest
    Message Count:
    "Aphelion" <> wrote in message
    news:...
    news:<>...
    instead of it?
    > Ap
    With my SB Vibra card, using anything BUT the (emulated) port produces
    either no sound or a very long delay. In other words, the (emulated) midi
    port is the only one that works right. What do you make of that? Bad driver
    for the SB? But why does the DirectMusic (emulated) midi port work?
    Also, as I understand it, you can prevent any midi ports you choose from
    showing up in any Cubase menus by setting the "Show" column to "No" in
    Device Setup. So what does the ignoreportfilter file achieve that you can't
    do in Device Setup?
  7. Aphelion Guest
    Message Count:
    >news:...
    >news:<>...
    >instead of it?
    >> Ap
    I know this is true for a few audio systems, almost always motherboard
    systems or AC97 compliant audio cards. It can also be that the system
    or Cubase has detected the port incorrectly.
    >do in Device Setup?
    Most often, using emulated ports causes MIDI sync problems and/or
    delays, or even notes that appear early.
    This is from the MIDI port filter text file, should be in your
    application root directory.
    MIDI port filter - Important note regarding MIDI Interfaces
    Cubase SX / SL version 1.02 or higher has a function to filter out
    redundant MIDI ports provided by the MIDI interface driver. For
    instance if the MIDI interface driver installs both Windows MIDI ports
    and DirectMusic ports, these ports used to both show up in former
    Cubase SX / SL versions. Since DirectMusic mirrors the Windows MIDI
    ports as "emulated" DirectMusic ports by itself, it was possible that
    the MIDI ports showed up even 3 times in the MIDI device list in
    Cubase SX / SL. These multiple appearances of the MIDI ports were
    actually "multiple versions" of the same physical MIDI port.
    To avoid this, Cubase SX / SL 1.02 and higher provides an option to
    remove these redundant entries utilizing the MIDI port filter.
    However, in some cases the non-filtered, left over MIDI ports that
    will show up in the MIDI device list of Cubase SX / SL can be the ones
    that actually do not work as the MIDI interface driver doesn't support
    the DirectMusic architecture as Cubase SX / SL would expect.
    These cases were for example found with the following MIDI Interfaces:
    - MIDIMAN MIDIsport 8x8
    - MOTU MIDITimepieceAV
    In this case, you can re-enable the filtered MIDI ports by proceeding
    as follows:
    - Browse to the Cubase SX / SL application folder (usually
    C:\programs\steinberg\cubasesx)
    and locate the folder "MIDI Port Enabler"
    - Open this folder
    - Pick the file "ignoreportfilter" and move it into the Cubase SX / SL
    application folder (one directory up)
    - Start Cubase SX / SL
    Now all available MIDI ports provided by the MIDI interface driver
    will appear in the MIDI device list of Cubase SX / SL. Please be aware
    that the MIDI ports now can show up 2 or 3 times in the list. If
    you're used to manage your MIDI IN by setting "All MIDI Inputs" in the
    MIDI IN selector, you should go to the Device Setup/All MIDI Inputs
    and disable the unwanted ports. Otherwise you will record MIDI from
    multiple ports which results in double MIDI notes.
    Your Steinberg Team
  8. iCon Guest
    Message Count:
    news:...
    driver
    can't
    > >do in Device Setup?
    So if you enable all the midi ports with the ignoreportfilter file, then
    disable the ones you don't want in Device Setup so they can't be used, you
    get the same result. Right? Or are they "more" disabled when the
    ignoreportfilter file does it?
  9. Aphelion Guest
    Message Count:
    >news:...
    >driver
    >can't
    >> >do in Device Setup?
    I think it depends on what type of MIDI ports the driver installs.
    There are at least two types and not all show up unless the
    "ignoreportfilter" file is moved to the root application directory.
    On my system I could only see the DirectMusic (emulated) ports, the
    standard Windows MIDI ports were not visible until the
    ignoreportfilter file was in place.
    It's possible that AC97 codec type audio systems only install
    DirectMusic MIDI drivers. In this case, they would not be emulated.
    It's confusing because the manufacturer has the choice of what kind of
    drivers to use. Motherboard audio/MIDI systems and inexpensive game
    cards may only support DirectMusic and not install standard Windows
    MIDI ports.
    Ap
  10. Matthias Cl Guest
    Message Count:
    > >news:...
    > driver
    > can't
    > >> >do in Device Setup?
    > MIDI ports.
    > Ap
    > I saw yesterdag on the site of staudio.com the soundcard DSP 24 Value.
    As I can see on the image I think it would be possible with this
    soundcard to link my synthesizer with it without have to use another
    linking part, like the emulated MIDI port. If I would have this port,
    so I don't have to use the emulated port and I also would have a
    soundcard which is much better than the actual one, could I solve the
    problems of the soundcard and the emulated MIDI port solve at once by
    buying this DSP 24 Value soundcard?
    Greetings,
    Matthias.
      • Advertising
Share This Page
