Hi I have Cubase SX3 and just got a copy of hypersonic 2, everything works well with Hypersonic and a couple of other programs, but when loaded into SX3 if I use the Hypersonic drums, then the kick drums dont work, all the other drums but the kick drums, I have had Cubase VST32 v5 for a long time and moved up to SX3. Ok just as a test I have just tried LM7 drums while writing this, the kick drums in that dont work either, any ideas please, SX3 is new and a lot different to what I expected, but I will work on with it if I can sort this problem Thanks for any help Gordon
Gordon a écrit : > Hi > I have Cubase SX3 and just got a copy of hypersonic 2, everything works > well with Hypersonic and a couple of other programs, but when loaded > into SX3 if I use the Hypersonic drums, then the kick drums dont work, > all the other drums but the kick drums, I have had Cubase VST32 v5 for a > long time and moved up to SX3. Ok just as a test I have just tried LM7 > drums while writing this, the kick drums in that dont work either, any > ideas please, - I don't know hypersonic. But the fact that you have the same problem with LM7 brings up the fact that it might not be a problem related to Hypersonic only. Make sure you don't have another problem completely independant from "hypersonic". Couldn't it be a keyboard problem? Try and transpose teh keyboard to see if you can use the kicks this way. (sorry if it seems obviosu, but I ve been stuck with silly things like that a few times... HUey
"Hueyduck" <> wrote in message news:49b0ed12$0$6707$... > Gordon a écrit : >> Hi >> I have Cubase SX3 and just got a copy of hypersonic 2, everything works >> well with Hypersonic and a couple of other programs, but when loaded into >> SX3 if I use the Hypersonic drums, then the kick drums dont work, all the >> other drums but the kick drums, I have had Cubase VST32 v5 for a long >> time and moved up to SX3. Ok just as a test I have just tried LM7 drums >> while writing this, the kick drums in that dont work either, any ideas >> please, > - > > I don't know hypersonic. > But the fact that you have the same problem with LM7 brings up the fact > that it might not be a problem related to Hypersonic only. > Make sure you don't have another problem completely independant from > "hypersonic". Couldn't it be a keyboard problem? Try and transpose teh > keyboard to see if you can use the kicks this way. (sorry if it seems > obviosu, but I ve been stuck with silly things like that a few times... > > > > HUey Hi Your right about silly things and I think this is one of them, I have tried uninstalling Hypersonic, LM7 Drums dont work still, my soundcard drums don't work (still talking about only the kick drum, both on the C and B flat) I have transposed and it's still the same, this is a weird one. I will stick at it this evening, I was thinking maybe the metronome (which I don't use) may be the problem, or the keys are being used for something else, oh I dont know, just clutching at straws here, anyway, thanks for your help so far HUey Gordon
Gordon a écrit : > > Hi > Your right about silly things and I think this is one of them, I have > tried uninstalling Hypersonic, LM7 Drums dont work still, my soundcard > drums don't work (still talking about only the kick drum, both on the C > and B flat) I have transposed and it's still the same, this is a weird one. > I will stick at it this evening, I was thinking maybe the metronome > (which I don't use) may be the problem, or the keys are being used for > something else, - What about the keys Cubase uses as remote controls. Here's what can be read on Larence's Cubase FAQ, here: http://www.auym23.dsl.pipex.com//CubaseFAQ2.htm#3 Let us know how you did.... Huey
"Gordon" <> wrote in message news:2iXrl.73705$2... > Hi > I have Cubase SX3 and just got a copy of hypersonic 2, everything works > well with Hypersonic and a couple of other programs, but when loaded into > SX3 if I use the Hypersonic drums, then the kick drums dont work, all the > other drums but the kick drums, I have had Cubase VST32 v5 for a long time > and moved up to SX3. Ok just as a test I have just tried LM7 drums while > writing this, the kick drums in that dont work either, any ideas please, > SX3 is new and a lot different to what I expected, but I will work on with > it if I can sort this problem > > Thanks for any help > > Gordon Seems like it could be a drum map problem that may have been caused by previous edits and which could have been saved. Ensure that you are using the GM drum map - which I think you probably are. Check the drum map setup to ensure: that the In note is the same as the Out note; that the note isn't muted; that the MIDI channel is the same as all the other drum sounds, and; that the Output destination is the same as all the other drum sounds. It may also be project specific in that you've inadvertently changed something in a specific project - if you are trying the Hypersonic and LM7 drums in the same project - create a new project from scratch and see if the problem persists
