Running CW Home Studio 2, I'm finding that it takes several attempts almost every time I record or playback to get CW to run. Get a couple of "dropout/audio stopped" failures. Once it gets going it's fine until I hit stop again. This just started occurring, it's worked flawlessly up to this point. Any suggestions as to what could be causing this? Thanks
On Sat, 8 May 2010 21:55:14 -0700 (PDT), muzician21 <> wrote: > Running CW Home Studio 2, I'm finding that it takes several attempts > almost every time I record or playback to get CW to run. Get a couple > of "dropout/audio stopped" failures. Once it gets going it's fine > until I hit stop again. This just started occurring, it's worked > flawlessly up to this point. > Any suggestions as to what could be causing this? > Thanks Is this the same system it was running flawlessly on? What are the system specs? -- borus
"muzician21" <> wrote in message news:... > Running CW Home Studio 2, I'm finding that it takes several attempts > almost every time I record or playback to get CW to run. Get a couple > of "dropout/audio stopped" failures. Once it gets going it's fine > until I hit stop again. This just started occurring, it's worked > flawlessly up to this point. > > Any suggestions as to what could be causing this? > > Thanks Did you try a system restore to an earlier point when the machine was working? Poly
On 08/05/2010 9:55 PM, muzician21 wrote: > Running CW Home Studio 2, I'm finding that it takes several attempts > almost every time I record or playback to get CW to run. Get a couple > of "dropout/audio stopped" failures. Once it gets going it's fine > until I hit stop again. This just started occurring, it's worked > flawlessly up to this point. > > Any suggestions as to what could be causing this? Do you have Windows Update updating itself in the background? I've forgotten to turn that off once or twice, and everything works fine until it decides to download some enormous patch while you're trying to record. Other possibilities might be a fragmented HD, shortage of swap space, or a failing drive. Cheers, Martin
On May 9, 11:05 am, "polymod" <> wrote: > Did you try a system restore to an earlier point when the machine was > working? Uninstalled and reinstalled CW, problem cleared up.
