DnD from EZplayer to Reaper
Discussion in 'cakewalk.audio' started by Dave \Mod Bod\ Modisette, Aug 1, 2010.
  1. Dave \Mod Bod\ Modisette Guest
    Message Count:
    Is there any special settings that I need to make to enable me to Drag
    and Drop from EZplayer to Reaper? I've got playback from the EZP
    transport to Reaper but I can't DnD. It's important that I do it from
    EZP so I don't need to know any workarounds.
    Dave "Mod Bod" Modisette
    http://www.gatortraks.com/forum
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news:4c55bb97$0$4846$ the killer robot
    "Dave \"Mod Bod\" Modisette" <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    I just tried dragging a few clips out of EZPlayer and they seemed to work.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. Dave \Mod Bod\ Modisette Guest
    Message Count:
    Thanks for letting me know. There isn't any special "tick boxes" I need
    to check? It took me a few minutes to figure out how to rout the Midi
    out from EZP into a receive channel but I can't get DnD to work in
    Reaper. I'm using x64. That could be the issue.
  4. Dave \Mod Bod\ Modisette Guest
    Message Count:
    BTW, are you using the latest update of Reaper?
      • Advertising
  5. Glennbo Guest
    Message Count:
    In news:4c55e749$0$15498$ the killer
    robot "Dave \"Mod Bod\" Modisette" <> grabbed
    the controls of the spaceship cakewalk.audio and pressed these
    buttons...
    >>> Drag and Drop from EZplayer to Reaper? I've got playback from the
    >>> EZP transport to Reaper but I can't DnD. It's important that I do
    >>> it from EZP so I don't need to know any workarounds.
    >> work.
    > need to check? It took me a few minutes to figure out how to rout the
    > Midi out from EZP into a receive channel but I can't get DnD to work
    > in Reaper. I'm using x64. That could be the issue.
    I'm running 32 bit XP, and just put EZP in the same FX bin as I had
    Superior 2. Once opened, I selected the Allaire grooves and then dragged
    several clips onto the track I normally record my drums on from the pad
    kit. It all played just as if I had recorded the part myself.
    ________ __
  6. Glennbo Guest
    Message Count:
    In news:4c55e7c9$0$15498$ the killer
    buttons...
    >> work.
    Yep. Version 3.651 Build 14314.
    ________ __
      • Advertising
Share This Page
