Hey Glennbo. I'm thinking of get a set of electronic drums for my music room and was looking for your input. I just really want the triggers to run samples from the computer but most of the time the units are complete systems with full brain. This one is about the most affordable one I've seen and some of those Roland TD systems are going for $3500. Have you messed with the TD-3 system? Would this be a good intro system for a novice? TIA http://vancouver.en.craigslist.ca/rds/msg/1698722819.html Peter
The killer robot "Peter Roussy" <> grabbed the controls of the spaceship cakewalk.audio and pressed these buttons... > I'm thinking of get a set of electronic drums for my music room and > was looking for your input. I just really want the triggers to run > samples from the computer but most of the time the units are complete > systems with full brain. This one is about the most affordable one > I've seen and some of those Roland TD systems are going for $3500. > Have you messed with the TD-3 system? Would this be a good intro > system for a novice? > > TIA > > http://vancouver.en.craigslist.ca/rds/msg/1698722819.html Any of the Roland V-Drums kits will work very well as a midi controller. I have the TD-5 brain with a bunch of pads, and use it strictly as a soundless controller for midi recording. -- Remove YourHeadFromYourAss to Reply by email ________ __ / ____/ /__ ____ ____ / /_ ____ / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ / /_/ / / __/ / / / / / / /_/ / /_/ / \____/_/\___/_/ /_/_/ /_/_.___/\____/ --------------------------------------------------------------------- Glennbo http://www.soundclick.com/glennbo Non-Linear Sound http://www.soundclick.com/jambits Hear My Music http://www.soundclick.com/ThePseudonyms
Thanks Glennbo Pete "Glennbo" <> wrote in message news:Xns9D5F5BDD2F45BrownShoesDontMakeIt@188.40.43.213... > The killer robot "Peter Roussy" <> grabbed the controls > of the spaceship cakewalk.audio and pressed these buttons... > >> I'm thinking of get a set of electronic drums for my music room and >> was looking for your input. I just really want the triggers to run >> samples from the computer but most of the time the units are complete >> systems with full brain. This one is about the most affordable one >> I've seen and some of those Roland TD systems are going for $3500. >> Have you messed with the TD-3 system? Would this be a good intro >> system for a novice? >> >> TIA >> >> http://vancouver.en.craigslist.ca/rds/msg/1698722819.html > > Any of the Roland V-Drums kits will work very well as a midi controller. > I > have the TD-5 brain with a bunch of pads, and use it strictly as a > soundless controller for midi recording. > > -- > Remove YourHeadFromYourAss to Reply by email > ________ __ > / ____/ /__ ____ ____ / /_ ____ > / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ > / /_/ / / __/ / / / / / / /_/ / /_/ / > \____/_/\___/_/ /_/_/ /_/_.___/\____/ > --------------------------------------------------------------------- > Glennbo http://www.soundclick.com/glennbo > Non-Linear Sound http://www.soundclick.com/jambits > Hear My Music http://www.soundclick.com/ThePseudonyms
> > Any of the Roland V-Drums kits will work very well as a midi controller. > > I > > have the TD-5 brain with a bunch of pads, and use it strictly as a > > soundless controller for midi recording. > > > > -- These are drum controllers you play with sticks?
In news:-september.org the killer robot Phoenix <> grabbed the controls of the spaceship cakewalk.audio and pressed these buttons... >> > Any of the Roland V-Drums kits will work very well as a midi > controller. >> > I >> > have the TD-5 brain with a bunch of pads, and use it strictly as a >> > soundless controller for midi recording. >> > >> > -- > > These are drum controllers you play with sticks? Yeah, it's this kit. http://members.cox.net/glennbo/PadDrums.jpg -- Remove YourHeadFromYourAss to Reply by email ________ __ / ____/ /__ ____ ____ / /_ ____ / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ / /_/ / / __/ / / / / / / /_/ / /_/ / \____/_/\___/_/ /_/_/ /_/_.___/\____/ --------------------------------------------------------------------- Glennbo http://www.soundclick.com/glennbo Non-Linear Sound http://www.soundclick.com/jambits Hear My Music http://www.soundclick.com/ThePseudonyms
