easier way to notate music
Discussion in 'cakewalk.audio' started by Michael, Apr 2, 2008.
  1. Michael Guest
    Message Count:
    AKA gray asphalt wrote:
    > Why not just replace the Bass clef with a Treble Clef
    > and indicate that the notes are played 2 octaves lower?
    Because it would make an illegible mess of anything written for two hands on
    a piano?
      • Advertising
  2. AKA gray asphalt Guest
    Message Count:
    > a piano?
    I must not be explaining it well. There wouldn't
    be any lines between the Treble and Bass clefs.
    Just space and the notes between the two clefs.
    There isn't anything messy at all.
  3. Michael Guest
    Message Count:
    >> hands on a piano?
    Well, that would present one obvious problem: the final space below the
    treble-clef part of a full staff is a D, and your suggestion would make the
    first space above the bass-clef part a G.
    Are you proposing that instead of two spaces and one line in between, there
    should be 9 lines and 10 spaces in there to accomodate GABCDEFGABCDEFGABCD
    (that's what it would take for an even arrangement of lines and spaces), or
    do you have some other arrangement in mind that allows players to make sense
    of leger lines between the upper and lower staff?
    You should look into the history of notation.
  4. AKA gray asphalt Guest
    Message Count:
    > >> hands on a piano?
    Here are the first measures of Moonlight Sonata
    in revised clef form:
    http://members.cox.net/goodidea/
    The left hand is played as if it were written in the
    Treble Clef except two octaves lower.
      • Advertising
  5. Michael Guest
    Message Count:
    >>>> hands on a piano?
    >> the treble-clef part of a full staff is a D, and your suggestion
    >> would make the first space above the bass-clef part a G.
    >> between, there should be 9 lines and 10 spaces in there to
    >> accomodate GABCDEFGABCDEFGABCD (that's what it would take for an
    >> even arrangement of lines and spaces), or do you have some other
    >> arrangement in mind that allows players to make sense of leger lines
    Looks simple enough... now show me something containing leger lines in the
    left-hand's staff.
  6. AKA gray asphalt Guest
    Message Count:
    > >>>> hands on a piano?
    > left-hand's staff.
    I'm not getting your quesion. ledger lines below C at the
    bottom would be just like ledger lines on a Treble Clef.
    And notes above C at the top would be the same as Treble.
    No wonder no one did this before, if they didn't. It's hard
    to describe ...
    If you give me an address for a midi file or sheet music,
    I'll put it in this form. Thanks for looking at the example.
    I know it sounds nuts to think there is a new way to
    notate music that no one has done before and it's simpler.
    Almost scary. If it does work then I'm sure there is some
    reason why it hasn't been used and someone else
    already did it. But it doesn't look that way.
  7. sambodidley Guest
    Message Count:
    "AKA gray asphalt" <> wrote in message
    news:...
    >> >>>> hands on a piano?
    >> the
    >> left-hand's staff.
    > to describe ...
    The G and F clef are only 2 of the many more clefs in music notation. Gonna
    change all those, too?
  8. AKA gray asphalt Guest
    Message Count:
    Originally, I think, there were lines and that's about
    it. Someone removed one of the lines and the Treble
    and Bass staff appeared.
    If they had removed two lines then then the two staffs
    would have the same notes on them. It's pretty easy
    to read notes on two missing lines. It's just like above
    and below the current staffs.
    Does that make sense?
  9. AKA gray asphalt Guest
    Message Count:
    On Apr 2, 5:36 pm, "sambodidley" <> wrote:
    > "AKA gray asphalt" <> wrote in messagenews:...
    > >> >>>> hands on a piano?
    > >> the
    > >> left-hand's staff.
    > > to describe ...
    Yes. I think they could all be the same. I don't understand
    about the clefs that are played in a different key that they
    are written, though. Don't you think it would be cool for
    people to learn only one set of notes instead of two and
    for players of one instrument to be able to read from an
    arrangement for another instrument more easily?
    Thanks for continuing this conversation.
  10. Rick Paul Guest
    Message Count:
    news:luSIj.1474$...
    Besides centuries of tradition and libraries of music that would all have to
    be changed, you mean? ;-)
    But besides that, I suspect the various clefs developed for good reasons.
    More on that below, but first to more your your notes:
    > It would mean that all notes would go by the EGBDF
    > pattern that many of us learned.
    Yeah, Every Good Boy Deserves Fudge (the way I learned it) or Every Good
    Boy Does Fine (probably more common). But at the same time I learned that,
    at the age of 4, I also learned Good Boys Deserve Fudge Always (i.e. GBDFA,
    the "F clef", or bass clef lines) and "All Cats Eat Good" (i.e. ACEG, the
    bass clef spaces). It's not rocket science, and you get used to it really
    quickly if you're using it.
    I found the notation you gave as an example of your idea disconcerting
    because, even without the little bass clef sign, my inclination, after
    40-some years of playing piano, is to read the notes as being bass clef in
    that position. Of course, even with normal piano notation, sometimes things
    go up high for the left hand, and get treble clef notation, but then there
    is a treble clef down there to make it clearer, too, and it is relatively
    rare, and mostly confined to relatively small sections of songs that need to
    use it.
    > There would have to be two lines between the Treble
    > and new Bass clef so it wouldn't be THAT easy, but it
    > would be a lot easier than the way it is now for people
    > just starting and like me who just didn't ever get past
    > the Treble Clef.
    So you're suggesting we should change centuries of tradition in notation,
    which all piano players have had to get used to, as well as trombone
    players, tuba players, and various other low instruments, because there are
    people out there who had troubles learning the extra clef? And what about
    the alto and tenor clefs used for other instruments, such as the viola (from
    memory, I think that one is alto clef, but I'm not positive on that, only
    that it's the C clef -- I'm not a viola player, though my daughter is, and
    she seemed to have no problem learning it after having already learned the
    treble clef back when she played violin)? Do we need to change those, too,
    for the "clef-challenged"? ;-)
    Maybe while we're at it, we should change the rules of basketball so those
    of us who can't sink a basket worth beans can just walk over and drop it in
    something at the height of a wastebasket? ;-)
    But setting aside the notion that a system that's been used for centuries
    should be changed to suit some number of people who have difficultly
    learning that system, it is worth considering why these systems may have
    developed, and what benefits come from using multiple clefs.
    I'm going to start with the one the viola uses, because, when I first saw
    that, it struck me as ludicrous. Why would viola players, most of whom
    started out as violinists, be forced to learn a new clef that very few other
    instruments used? And it's only something like a step off in where notes
    reside from the treble clef, too. I fact, the way I learned to read parts
    written for viola to play them on a piano to help my daughter learn parts at
    times was to mentally transpose up the notes I was seeing.
    However, if you look at the parts the instruments are playing, and where the
    open strings of the viola sit in relation to the clef it uses (e.g. the
    highest string, the A string, sits right on top of the clef, while the
    lowest string, the C string, sits just below the first ledger line below the
    clef -- where a B below middle C would sit on a treble clef), it seems to
    fit comfortably, and the general parts written for the instrument tend to
    stay within reasonably readable positions on the staff. I'm not so sure it
    would be all that much worse if they were just forced to use the treble
    clef, but it would be slightly worse on the bottom end.
    With the piano, though, one of the nice things about the treble clef/bass
    clef arrangement is that the clefs both arrange themselves around middle C.
    It is one ledger line down from the treble clef and one ledger line up from
    the bass clef, and a grand staff puts it right in the middle. Going down
    for lower right hand parts usually keeps the number of ledger lines
    reasonable, as does going up for higher left hand parts. Also, within the
    relatively comfortable ranges for normal playing, for example on the bass
    end, if you consider, for example what notes would correspond to
    clean-sounding bass notes similar to the range of a bass guitar, for
    example, you are also keeping the number of ledger lines below the bass clef
    staff fairly reasonable, and that is also true above the treble clef staff
    on the high end.
    When you shift the normal left hand playing range to a double octave-down
    treble clef, though, that is not true. While you get to deal with less
    ledger lines going down for low notes, you have to deal with an unwieldy
    number of them when going up for high notes. You've also lost the symmetry
    of the staff placement around middle C, creating an awkward crossover
    between staves, with middle C up on the second ledger line above the double
    octave-down treble clef.
    I suppose I could also ask the question that, if you're trying to simplify
    things here, why not just make one grand staff that runs everything
    together, so you don't have to worry about clefs at all, just keep track of
    relative positions of notes or some such thing? Of course, that would make
    it very tough to read because keeping track of where something is would
    become much more difficult than when you only have 5 lines and four spaces
    in each hand, and a few ledger lines above and below, to help you home in on
    the predominant range of those two hands.
    Or maybe we should just all get used to reading piano rolls? After all,
    that would create no rigid note length restrictions, ledger lines would be a
    thing of the past, no one would ever have to remember line and space letter
    correspondences, etc. And some people never learn to read even treble clef
    notation, so why should we disadvantage them? ;-)
    The fact is, people do write octave-shifted music, in both clefs, all the
    time, when it is convenient to use those. For example, lead sheets and
    sheet music for songs sung by male singers are almost always written in the
    treble clef, with the idea that the actual notes sung are one octave down
    from the notated value. And the 8va, 16va, and equivalent octave down
    shifting marks are also frequently found when they make music for an entire
    piece, or even just a passage from one, easier to read. IMHO, removing the
    symmetry from the clef arrangements for piano music would not be helpful.
    Of course, I've been playing piano music for decades now, but I also know,
    at the tender age of four, it didn't take me terribly long to learn to read
    treble clef and bass clef. I figure if a four year old can do it, it can't
    be all that difficult.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
  11. AKA gray asphalt Guest
    Message Count:
    On Apr 2, 11:05 pm, "Rick Paul" <> wrote:
    > "AKA gray asphalt" <> wrote in messagenews:luSIj.1474$...
    I learned Every Good Boy Does Fine
    > use it.
    I wouldn't suggest that anyone change what works for them.
    This is just an alternative for people who like it.
    > > the Treble Clef.
    I would much rather make it easier to make music than to
    keep up tradition. Isn't music the goal? OTOH I really like
    studying chords and stuff even though it doesn't add
    much to the music I try to play.
    > And what about
    Well, I'm not really saying anyone should use this idea. Mostly
    I wanted to see if anyone had any reasons why it wouldn't work,
    especially if someone else had stumbled across it before I did.
    I think those who are talented and 'clef challenged' as you call it
    should be helped find a way to express their talent. I wonder if the
    whole thing isn't kind of right brain / left brain.
    There aren't rules about music notation that I'm aware of. I don't
    blame you for wanting to keep things the way you learned them
    and I think most people will. Actually this idea, if it is even
    workable will probably die as the Dvorak keyboard.
    OK.
    Do all of the clefs fit comfortable or is this the one of many
    that happens to fit nicely?
    > on the high end.
    For me it would be best if the D were in the middle between the staffs
    because it is actually the center of the keyboard. Getting out of
    using
    C seems to be a hurdle to me and maybe people would learn to transpose
    more quickly if the staffs were set up to match the keyboard.
    I'm not sure if I see that this relates to having clefs that have the
    same letter assignments.
    Wasn't the large staff the original way music was notated?
    They removed one line to make it easier, probably to the
    same arguments you raise here. It might have been better
    to remove two lines, though, imo.
    I'm just trying to help. : -)
    > Rick
    The level of difficulty will dictate whether this idea is used.
    Do you use tabulature for guitar? Has that always been
    around? Can't guitar be played from regular staves and clefs?
    > Rick Paul
    > Web:www.RickPaul.info
    > MySpace:www.myspace.com/rickpaulmusic
  12. BobF Guest
    Message Count:
    news:...
    Wouldn't that be problematic in the end?
    If you consider notation as a language which provides common symbology for
    communication of musical ideas (which it is), then using a different version
    would limit the user's ability to reach the goal that notation was
    originally designed to achieve.
  13. Sue Morton Guest
    Message Count:
    Without getting into a lengthy discussion :) there's so much more you can
    do, e.g. communicate, with multiple clefs than with the same notes
    everywhere.
    If your education stopped at every-good-boy-does-fine, you're missing out on
    a lot of good stuff. Sure your idea might make it easier/simpler for people
    with no/incomplete education to read a bit more music, but as soon as it
    needs to advance this would not cover the basics. It's hard enough for
    composers to communicate with the system we've got now :)
    Not dissing you. I just think'd you'd end up with the current one plus your
    system at best, two imperfect systems instead of just one.
    Have you thought about going back to school? JC or to private teacher?
    Advancing your music theory and advancing your music foundations in general,
    might cause you to agree with some of us --OR-- develop one system that's
    better than the one we have now :)
    Sue Morton
    >> hands on a piano?
  14. sambodidley Guest
    Message Count:
    "AKA gray asphalt" wrote
    > It really helps me but I'm probably representative of a very
    > small percentage of the population.
    In short, do whatever works for you. Just don't expect much company. <g>
  15. Michael Guest
    Message Count:
    > <g>
    .... and I can agree with all of these statements. :)
  16. Rick Paul Guest
    Message Count:
    news:43a8f814-4cf0-460b-ab9d-
    Sue Morton and BobF really gave replies that addressed this. Just to add
    slightly. There are basically three purposes for which I could see you, or
    anyone else, using notation:
    1) To help you remember something you've written to play it back later.
    2) To communicate your piece to other musicians working with you.
    3) To communicate your piece to other musicians who aren't working with you
    (e.g. someone else trying to play your piece).
    In case #1, you can certainly use any system you're comfortable with because
    it really doesn't matter -- it is just your own memory aid. I frequently
    use really messy notation for this stuff -- sometimes even the stuff spit
    out by SONAR itself (shudder) -- because I'm just going to toss it out after
    I've played the part, and no one else will ever need to see it. And I
    probably know what I'm doing well enough that having even a very rough
    reminder of that will help me get past what I'd have forgotten without any
    memory aid whatsoever.
    In cases #2 and, especially, #3, it is a different matter. I might have
    been tempted to say it's a bit like trying to speak English to someone who
    only knows Spanish, but that's not quite the right analogy because people
    who are used to using the bass clef probably also know the treble clef, and
    piano players, where the dual clefs in use at the same time come into play,
    will certainly know the treble clef. Thus, a better analogy might be using
    job-specific lingo when working on a given type of job, rather than just
    speaking plain everyday language that may, for example, not be as precise,
    or may simply be less efficient for the purpose at hand. For example,
    actors in a theater are told to move "stage right" or "stage left" or
    "upstage" or "downstage". Why not just use the plain English "right",
    "left", "backward", and "forward"? Well, that would depend on the
    orientation of not only the actor, but also the director (or whoever is
    blocking the action), and there would be too much potential for
    miscommunication. Perhaps using the lingo makes it harder, initially, for
    inexperienced actors, but it is a lot more it is a lot more efficient for
    communicating directions once people get used to it, and actors with even a
    little experience get used to it rapidly. Sure, they could probably follow
    your directions if you used plain English to tell them what to do, but it
    would likely slow things down due to the inevitable "your right or my right"
    and "my right or stage right" sorts of ambiguities in the cases where there
    might be different points of reference, and just having to stop and think
    about if there might be ambiguities might slow things down a bit.
    And, as I said yesterday after looking at your example, having to read a
    left hand piano part in treble clef slowed me down significantly. Odds are
    it would do the same for the musicians in both cases 2 and 3. The
    difference is, you can be coaching the ones in case 2, but you have no
    control over those in 3. Also, if you are pushing something out to the
    world, it is less likely to meet resistance if the form used conforms to the
    expectations of the potential users. You'd have to change their
    expectations to overcome resistance to your non-standard method of
    communications, and what reason would they have to want to do that? Maybe
    if you had an extremely compelling piece that was only available in that
    form of notation, but, even then, if the market were big enough, someone
    would probably just convert it to standard notation to make it easier for
    people to use.
    But it doesn't make it easier to make music, other than possibly for some
    beginners. As I suggested in my notes from yesterday, it would actually
    make it harder to read much standard piano music because of the number of
    ledger lines that would have to be read (and those are one of the hardest
    things to read quickly when reading music, once they get beyond two or three
    ledger lines, which you'd certainly do commonly if using a what you are
    suggesting).
    Sue's thoughts on needing to learn a bit more to be comfortable with new
    things are right on the money. If you're only playing right hand music,
    like sometimes is the case for beginning piano players (I actually learned
    both pretty early in the game with the method I used -- Theodore Presser),
    then knowing only the treble clef may be okay, but, when you get to learning
    left hand music, any teaching method in common use will be introducing the
    bass clef right away, so anyone learning to play even elementary piano music
    will have learned it.
    There are many who are talented and notation challenged in general, who just
    play by ear. That includes many professional, world class musicians. And
    instrumentalists who play treble clef only instruments and do read music,
    wouldn't likely have to know bass clef anyway. But any musicians who do
    play bass clef instruments, or mixed clef instruments (mainly keyboards),
    would also have learned the bass clef early on, so it's really hard for me
    to see your point here.
    Perhaps reading music in general does have a bit of right brain/left brain
    stuff going. I also think the earlier you learn something that is initially
    a left brained sort of thing, which reading notation initially certainly has
    to be, the better the odds it will be indoctrinated to the degree that it
    becomes intuitive, and thus a right brain sort of thing. I learned to read
    music very early -- at the age of four, very likely before I even learned to
    read English as my hazy memory of that far back suggests we didn't really
    start learning to read until the first grade, and I can definitely place
    myself playing Christmas carols from mixed clef notation for my kindergarten
    class. It is a very intuitive thing for me to do at this stage, though
    certain types of notational conventions do require thought. Mostly those
    are complex conventions that I don't use very much, but something like a
    bunch of ledger lines, where the "picture", if you will, gets less distinct,
    can slow me down to the point of needing to count how many there are in some
    cases, whereas stuff that stays within the staves or within 2-3 ledger lines
    above or below doesn't make me think at all. I don't even think I really
    think in terms of note names, but rather just what I play -- i.e. it is more
    of a notation to note played connection than a notation to note name to note
    played connection.
    Actually, there are lots of rules about music notation. I've got a few
    books on the subject that I purchased to help me learn orchestration and
    transcription beyond what comes intuitively from four decades of reading
    music and playing piano and other instruments. There are even rules for
    when you do things like use stems going up and down. While no one's going
    to crucify you if you violate such rules, and there are even cases where you
    may want to intentionally violate them, the "rules", which are more
    documentation of customs than "laws", are basically about making things
    easily readable, and hopefully sight readable, for trained musicians.
    Without conventions, communication becomes much more inefficient.
    I think that is also why the Dvorak keyboard died. Had it come around at a
    much earlier time, perhaps it would have become the defacto keyboard. But
    years of QWERTY keyboard experience from typewriters through computers has
    resulted in most everyone who uses a keyboard regularly being relatively
    comfortable with that keyboard. And consider what would happen if half the
    world had Dvorak and half the world had QWERTY. You'd go to use your
    friend's computer and all of a sudden you'd be reduced from a 70 wpm typist
    (or whatever rate you're at) to a hunt and peck typist. That is pretty much
    exactly what my reaction to your example notation was. I had to stop and
    think about what note I was reading, as you'd broken the automatic
    connection that had become intuitive over my years of experience.
    I couldn't say, but I didn't pick the viola as an example because it fit
    nicely. Rather I picked it because it used a clef that is much less common,
    so not likely to be known except by people who play the specific instruments
    that use it. I do know, however, that some other instruments do use octave
    shifting to make them fit more comfortably within the staves for the clefs
    they use. For example, I'm reasonably sure the piccolo is one of those,
    writing notes on the treble clef and octave down from how they sound, so the
    parts fit more comfortably within the staff. I also seem to remember the
    tuba goes in the other direction, writing the parts an octave up (in the
    bass clef) to avoid excess low ledger lines.
    > using
    While I've never counted notes on a piano to have even considered the
    concept of the absolute middle position, I do think there is good reason why
    we start out with this concept of "centering", if you will, on middle C,
    when learning piano. In fact, perhaps multiple reasons.
    One is that, in the spirit of "one thing at a time" to learn, when reading
    notes, playing in the key of C avoids accidentals, and C is obviously the
    root note in the C scale. Also, most of us have five fingers in each hand,
    and beginning piano music also generally starts with learning the right hand
    slightly before putting both hands together. Thus placing the thumb of the
    right hand on the root note of the key of C makes a lot of sense. That can
    therefore be the landmark that helps all navigation to other points. For
    example, the book I used started out with little exercises that only used
    the notes C through G, conveniently allowing you to place one finger on each
    note, without having to move your hand at all, and thus starting to develop
    some initial multiple fingering techniques, thus resisting any hunting and
    pecking urges. (That method also started out placing the fingers of the
    left hand on the C through G an octave below, but, of course, with the pinky
    on C and the thumb on G. This allowed for both unison exercises and finger
    number exercises to allow for keeping with a "one thing at a time" sort of
    variation before getting to true note and finger independence between the
    hands. And that part could be done without even introducing notation, since
    they could just print the letter or the finger number.)
    Another is simply the general point in the overall range of the scale where
    things start to divide up in terms of where you can more easily get away
    with playing closely voiced chords, versus playing more widely voiced chords
    or individual notes or octaves. While there may not be an absolute
    borderline in that sort of consideration, middle C tends to be a reasonable
    sort of dotted line border, beyond which going lower sometimes does and
    sometimes doesn't work, depending on context, whereas most everything above
    it does work (bad taste in note combinations' excepted, of course).
    I don't know the history of it, but you may be right. I've only seen the
    grand staff in my first piano book, and it was never actually used, just
    mentioned, probably in demonstrating something like the symmetry of the
    treble and bass clefs around it. And it definitely does make things easier
    to read to keep the space between clefs, not to mention also making it
    easier to notate what parts are meant to be played with each hand, since the
    staff used can show that, leaving you free to use note stem direction for
    legibility, whereas I'd guess that, in a grand staff, you'd be forced to use
    note stem direction to show which hand is intended (i.e. if you wanted to
    show that).
    I have to disagree, though that it would have been better to have removed
    more lines. See my note above about middle C and the natural "dotted line"
    boundary with respect to closely voiced chords. This also relates to the
    number of ledger lines you get when going up from the bottom staff or down
    from the top staff. For example, when going down from the treble clef you
    can still have two ledger lines when going down to a G, and that is
    extremely readable, while also being still pretty likely to work in closely
    voiced chords. Going down further gets you further and further away from
    both considerations, with E still not being horrendous on the readability,
    and starting to push the borders on fit in closely voiced chords toward
    sounding like mud. If you go down to C, though, readability starts going to
    hell, and you're much more likely to start sounding like mud, and when you
    go down below that, you're really at the point of needing, for most purposes
    anyway, to use octaves or at least wider intervals. Of course, your
    argument is more in the other direction, but I'd maintain that it is fairly
    common to want to be able to go up to at least a G with the left hand, for
    example to play a closely voiced C chord, and that is around the limit of
    fairly easy readability with a bass clef, but beyond the point of easy
    readability if using the double octave-down treble clef.
    I don't play guitar very well, and the one book I started trying to learn
    from early on used a treble clef, shifted an octave up from where the notes
    sounded, to notate the music. This was back when I was a teen or preteen
    (it was my brother's guitar and book), and I have no clue if tablature was
    in common use back then. I find tablature tough to read, but I'm not a
    guitarist, so that is a fairly meaningless statement. ;-)
    In general, I think one of the things that stymies me in learning to play
    the guitar is that there isn't the sort of direct correspondence between
    notes and hand positions that exist with the piano, so, for me, it is
    counter-intuitive. I hear good guitar players talking about positions and
    shapes, and I know from the little guitar I do play that you more or less
    have to get used to those to get to a point where the guitar would start
    becoming intuitive. But the musician in me wants to play notes, not shapes
    or patterns or positions. When I hear, say, "CEG" (i.e. a C major chord) in
    my head, I want to play CEG, which my hands easily do on a piano or
    keyboard. But I have to put my fingers in a pattern to play that on a
    guitar, and the pattern is not really intuitive because of the way the
    strings are arranged. By contrast, I think guitar players tend not to think
    of playing CEG, but playing a C chord in a certain position, and what
    eventually becomes intuitive to them is the finger positions/patterns for
    certain types of chords, perhaps even somewhat independent of the root of
    the given chord to a degree, with the actual notes being somewhat incidental
    to the whole thing. This is also the sort of thing that tends to give me
    grief with the Nashville number system (which I tend to think is oriented
    mainly at guitarists, even though keyboard players end up using it, too). I
    am very fast at transposing in my head from the key of C to the key of G,
    for example, when I read music. But if I have to read a 1 chord or 6m
    chord, and just play it in any given key, I have to stop and think what
    number is what note in that key. (I suspect even many piano players don't
    transpose as readily in their heads, but I probably started to develop that
    part of what is intuitive to me by doing a bunch of orchestrations for non-C
    instruments, such as Bb clarinets and trumpets, back when I was in high
    school, and then just getting used to it for transposing sheet music from
    the key it was written in to the key that was most comfortable for me to
    sing it in.)
    Rick
    Rick Paul
  17. Gary R. Hook Guest
    Message Count:
    > For me 'middle D' might be better situated
    > in the middle of the clef, if possible. "middle D
    > means, to me, that the D is symetrically in the
    > middle of the group of keys C thru E and just
    > looks like the 'middle' key.
    Your perspective seems to be somewhat myopic. Notation was invented
    long before the pianoforte or harpsichord, and it has _nothing_ to do
    with where the C key sits on a keyboard.
    Gary R. Hook
    ________________________________________________________________________
    Vocatus atque non vocatus deus aderit
  18. David Burns Guest
    Message Count:
    Tell me the truth. Is this thread an April Fool's joke?
    Dave Burns
    Lowell, MA
    news:luSIj.1474$:
    > the Treble Clef.
  19. Sue Morton Guest
    Message Count:
    Because something is conventional, such as traditional notation, of course
    that doesn't mean there isn't something 'better' (subjective!) to be
    developed and adopted. Getting 'the masses' to accept something new,
    however, almost always requires widespread and majority *rejection* of the
    old, so that change is wanted and embraced.
    Since conventional notation enjoys widespread *acceptance*, regardless of
    potential difficulty for people at various levels of music education, it is
    possible but not probable that a marked change in notation standards would
    be embraced. The DVORAK/QWERTY keyboard evolution already mentioned, is one
    example. A widely accepted convention is a large mountain that is difficult
    to move :)
    So. A broad and well rounded beginning music education is not only useful,
    but creates a solid foundation on which further levels of difficulty can be
    built. No person with two years of piano study is expected to pick up an
    orchestral score for the Boston Pops and understand it fully and completely,
    or even be able to sight-read it all. But the education can continue and
    the foundations built upon and enhanced, rather than *replaced*, to the
    point where that long-ago two year student is now the conductor of that
    orchestra. :)
    It is human nature to want to learn and build basics that can be enhanced to
    any potential, and not to learn an alternate that may be easy in the
    beginning, but must be abandoned and the skill re-learned in order to
    advance. Any new form of notation should be prepared to replace the current
    form in entirety or it stands little chance of acceptance (IMO).
    Sue Morton
  20. polymod Guest
    Message Count:
    "Sue Morton" <> wrote in message
    news:UbrJj.188$...
    Yea, like those bilinear keyboards they came out with many years ago.
    http://images.google.com/imgres?imgurl=http://www.spectralmusic.com/sotorrio
    keyboard/accordion.jpg&imgrefurl=http://www.spectralmusic.com/sotorriokeyboa
    rd/bilinearchromatickeyboard.htm&h=252&w=395&sz=155&hl=en&start=7&tbnid=W1jd
    H9Pe4Gm08M:&tbnh=79&tbnw=124&prev=/images%3Fq%3Dalternate%2Bpiano%2Bkeyboard
    %2Bdesigns%26gbv%3D2%26hl%3Den%26safe%3Doff
    Poly
      • Advertising
Share This Page
