Editing songs on Microstation
Hi all. Just bought myself a Microstation to use on stage and I'm trying to edit some songs I've converted from midi files. I can edit the songs whilst they being played in the sequencer but all instruments/parameters etc revert to their original values as soon as I re-start the song. I can't see how to save the new settings and the manual is a little less than helpful.....!!! Appreciate any help you can give me. Cheers.
Dunno how to do it in the Microstation's sequencer but in any computer DAW you simply delete the MIDI CC numbers that control patch and bank selection in each track. If there are multiple program changes in each track you will have to search and delete every one of them.
Often though there is usually only one program change in the first five bytes of the track.
