Exporting MIDI from Cubase 5??
Discussion in 'alt.steinberg.cubase' started by lancelightning, Feb 22, 2010.
  1. lancelightning Guest
    Message Count:
    I've been using Cubase 5 to manipulate some midi files. I can import
    them ok, though whether the voices and midi channels are correct is a
    bit hit and miss. This isn't really too much of an issue as I can
    alter them to suite. I can finish a project and export the finished
    mix to a wav file without a hitch. BUT sometimes I want to export the
    part-finished midi file for a friend to continue working on...and this
    is where I'm running into big problems. I can't seem to get Cubase to
    export the voices and their corresponding midi channels....that info
    is getting lost somewhere in the process. As soon as I try to open the
    midi file up again, all I'm getting is the GM drums while everything
    else has defaulted to piano.
    I must have overlooked something basic...maybe something in
    preferences, but I can't for the life of me work out what it is...
    Can anyone help?.........LL
      • Advertising
  2. Max Doorrijhoogte Guest
    Message Count:
    Don't export as midi, but send him the cpr?
  3. lancelightning Guest
    Message Count:
    On Mon, 22 Feb 2010 22:14:27 +0100, Max Doorrijhoogte
    I wish it was that simple!! He isn't using Cubase. He has a very old
    hardware sequencer. I can't get him into using Cubase.
    I have a feeling that once I start using vsti's etc, I'm stepping
    outside the world of General Midi altogether which could be the cause
    of my problems. Nontheless I would have thought there would be a way
    of exporting the patch info....something in MIDI Device Manager or
    whatever its called?? I dunno...
    Everything works fine for me when I'm creating my own songs...but
    we're working on some backing tracks here...hence the need to use the
    old midi file format which is antiquated. but still seems to be the
    accepted way of doing things when it comes to this type of work.
    Thanks anyway...any other takers?...LL
  4. Jos Geluk Guest
    Message Count:
    I have at times successfully exported MIDI with Cubase 5. It is not
    always easy to check whether Cubase has done what you intended, unless
    you have some independent MIDI monitor or other. When you reimport the
    MIDI file into Cubase, it makes its own assumptions, so that doesn't help.
    Anyway what Cubase exports is determined by the settings in
    Preferences/MIDI/Midi File. "Export Inspector Patch" means that any
    settings to the "program selector" field (which you have on a track that
    is routed to a MIDI device) is converted to Program Change / Bank Select
    messages. This is what you want. Make sure it is selected.
    To be honest, I don't rely on this myself. I don't make General MIDI
    files for the public domain. If I have to export as MIDI, I make sure my
    tracks and events are clearly marked with the name of the instrument or
    whatever. I leave it to the other side to get the settings right.
    HTH
    Jos.
    Ardis Park Music
    www.ardispark.nl
  5. Max Doorrijhoogte Guest
    Message Count:
    Maybe the old trial-and-error way?
    Fiddle with settings, export as MIDI and then play back with a simple
    player such as Winamp.
    Time-consuming, I know, but it will get the job done in the end :)
  6. lancelightning Guest
    Message Count:
    On Tue, 23 Feb 2010 00:24:49 +0100, Jos Geluk <>
    >HTH
    >Jos.
    Hi Jos...
    Thanks for your input...Yeah I've tried all the stuff in '
    Preferences' as you suggest. It does indeed work ok sometimes, but
    more often than not, much of the original voice/midi info gets lost
    once I start manipulating the files within Cubase. Your last comment
    about clearly marking instrument names/events etc. is probably as good
    as it gets.
    I'll blame my mate for using his crappy old midi sequencer!! We'll
    get around it one way or another. Someone told me that Sonar was
    better at handling midi files...but I'm not about to change my DAW for
    that!! I use Cubase mainly for recording my original songs, and it
    does everything I want for that purpose.
    I'd still be greatful for any other ideas.......LL
  7. lancelightning Guest
    Message Count:
    On Tue, 23 Feb 2010 01:08:26 +0100, Max Doorrijhoogte
    Yeah...there isn't much along those lines I havn't already tried. None
    of the media players will successfully open the files up once I've
    exported them from Cubase ...I've tried Windows Media Player, the
    Apple one - whatever its called..Winamp, a couple of others...you name
    it. To make matters worse my mate is trying to open them up using an
    old Yamaha hardware sequencer which doesn't help at all.
    The problem is, I think, down to what happens to the files inside of
    Cubase..it would appear to be beyond capabilities of the GM/XG type
    formats.
    I'm still open to ideas though.....LL
  8. lancelightning Guest
    Message Count:
    wrote:
    I've found a workaround...It seems that the midi channel and voice
    info is getting lost or corrupted when the original midi file is
    loaded onto Cubase instrument tracks. If I create the same number of
    midi tracks and drag all my finished work down onto those..reset all
    the voices and midi channels...voila! Cubase will now export the midi
    file properly. Its a lot of messing about, but at least my friend can
    now load up my work.
    The midi file format is antiquated. but it is still widely used for
    backing tracks. I don't think that the current incarnation of Cubase
    is really designed for this type of work. I might benefit from loading
    up an old Cubase version...VST5 springs to mind.
    I'd still appreciate any other suggestions....
    LL
  9. Jos Geluk Guest
    Message Count:
    Op 23-2-2010 12:30, lancelightning schreef:
    > On Tue, 23 Feb 2010 00:24:49 +0100, Jos Geluk<>
    Dunno about that. I have often tried to have SX2 export MIDI. I think
    only one ever really played in another player, as it had only one track
    with a single instrument. I had more luck with Cubase 5.
    Why don't you ask around in the alt.binaries.sounds.midi group for a
    decent editor? I haven't been there for a while, but I remember the
    topic of a MIDI editor came up frequently. There should be several good
    ones to be found. Then export from Cubase as best you can, and tweak the
    file with the MIDI editor.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  10. lancelightning Guest
    Message Count:
    On Tue, 23 Feb 2010 13:40:50 +0100, Jos Geluk <>
    >Jos.
    Good idea..I do have an old Yamaha sequencing program somewhere buried
    away. I'll try and find that...Its rather old but it might provide a
    simple solution. Or possibly an older version of Cubase... Otherwise
    I'll ask around as you suggest. I will try that NG.
    I have actually found a workaround in Cubase 5, but it involves an
    awful lot of messing about.
    Thanks for your suggestions....LL
  11. Jos Geluk Guest
    Message Count:
    Hey, NOW I'm curious. What kind of messing about?
    A bit of a cliffhanger, that :)
    Jos.
    Ardis Park Music
    www.ardispark.nl
  12. lancelightning Guest
    Message Count:
    On Tue, 23 Feb 2010 15:12:27 +0100, Jos Geluk <>
    >Jos.
    Jos,
    I suspect that the problem is caused by importing the original
    midi files onto Instrument Tracks, rather than plain Midi Tracks.
    Perhaps I shouldn't do that, but its what Cubase 5 does by
    default..plus its nice to be able to play the files using Halion or
    whatever, rather than some crappy wavetable synth. Anyway this is
    where I think some of the info gets lost or corrupted...particularly
    if I start manipulating stuff, adding new parts/sections or whatever.
    I still would have thought that the basic midi info would be retained.
    If I try to export midi at this staget, I usually find that all the
    voices default back to piano, except for the drums.There's other
    problems too.
    The workaround: Jeez, how do I explain it?!! When I've completed
    work on a particular midi song, I've found that if I create the same
    number of empty midi tracks and drag or copy all the info onto
    those...I can then reset all the midi channel numbers and voices,
    delete or mute the instrument tracks and export the midi file. Of
    course I lose any vsti settings, but that's not an issue. Unlike
    before, the new midi file now plays/loads up as it should. Does any of
    this make sense??!!
    It does work, but its a horribly convoluted way of going on. I'm
    hoping that Laurence might chip in on this one! I have a feeling that
    I'm going about this completely the wrong way else I've missed
    something obvious.
    LL
  13. Jos Geluk Guest
    Message Count:
    Op 23-2-2010 19:01, lancelightning schreef:
    > On Tue, 23 Feb 2010 15:12:27 +0100, Jos Geluk<>
    >> Jos.
    > Jos,
    > problems too.
    > this make sense??!!
    > something obvious.
    Thanks for explaining that. I never use instrument tracks. I understand
    the idea behind it, but it just isn't flexible enough for me.
    What you explained does make sense, but have you tried this instead:
    enter program changes (and bank select messages, if you have them),
    volume and pan controllers etc. straight into the list editor? Those
    should be preserved at export time.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  14. Swanny Guest
    Message Count:
    How are you setting your program changes? Do you include a pre-roll bar
    with the program setup (ie bank and voice selection for the module you
    are targeting)?
  15. lancelightning Guest
    Message Count:
    >are targeting)?
    Well that shouldn't be necessary, but I'll certainly have a play along
    those lines.The info should all still be there from the original midi
    file...I think I need to forget about using Instrument Tracks for this
    particular purpose.
    LL
  16. lancelightning Guest
    Message Count:
    On Wed, 24 Feb 2010 00:45:38 +0100, Jos Geluk <>
    >>> Jos.
    >> Jos,
    >> problems too.
    >> this make sense??!!
    >> something obvious.
    >Jos.
    I'll try what you suggest, but I reckon the solution long-term is not
    to use instrument tracks at all for this project. Rather to import
    onto midi tracks ...I reckon that'll work....LL
  17. XODDI Guest
    Message Count:
    "lancelightning" <> wrote in message
    news:...
    >>HTH
    >>Jos.
    > Hi Jos...
    > as it gets.
    Insert a program change at the beginning of each MIDI track specifying which
    GM patch is to be used.
    http://www.midistudio.com/Help/GMSpecs_Patches.htm
    Patch 1, Acoustic Piano, is default.
  18. lancelightning Guest
    Message Count:
    On Fri, 26 Feb 2010 14:27:03 -0500, "XODDI" <>
    >news:...
    >>>HTH
    >>>Jos.
    >> Hi Jos...
    >> as it gets.
    Thanks for that...I'll give it a try..........LL
  19. lancelightning Guest
    Message Count:
    >>>> Jos.
    >>> Jos,
    >>> problems too.
    >>> this make sense??!!
    >>> something obvious.
    >>Jos.
    In conclusion to my own question...Cubase will, by default, import
    midi files to instrument tracks using Halion if it is installed.
    That's finet if all future work on the songs is to be completed
    exclusively within Cubase. However if we want to export a midi file
    again at any time, all the original voice and channel info is usually
    lost...you end up with just two tracks..drums and then everything else
    merged onto a single piano track. Not very useful at all. I've tried
    every option in 'Preferences' without any luck.
    The solution is to use a midi track template(not instrument track) and
    drag the midi file onto that...and then set up any vsti routing
    afterwards. That way the original voice and midi channel info seems to
    remain intact. It isn't ideal but it seems to work.
    I appreciate that the GM format and midi files in particular are
    antiquated by design, and perhaps no longer a consideration for many
    users, but nothing has really replaced them. For those of us who are
    involved with making/using midi backing tracks, the ability to import
    and export midi files without a lot of hassle is still important. This
    doesn't appear to be a strong point in C5...Of course I may still be
    missing something obvious.
    As I use Cubase for recording all my original material, and that's its
    main purpose, I'm not going to buy a different DAW just for this midi
    file stuff. I'm still open to any other suggestions........LL
  20. XODDI Guest
    Message Count:
    > >>>> Jos.
    > >>> Jos,
    > >>> I still would have thought that the basic midi info would be retained..
    > >>> problems too.
    > >>> this make sense??!!
    > >>> something obvious.
    > >>Jos.
    The GM spec was meant to be playable on a multitimbral synth or synth
    card, wasn't it?
    Could you set up a VSTi as a ch 1-16, drums on 10, multitimbral synth?
    I know I can do that with DirectWave (I haven't learned as I never
    needed to) and possibly Kontakt.
      • Advertising
Share This Page
