I want to get a copy of EZ Drummer,but I see that it doesn't many versions of Cubase LE, SX SE SL etc... What is a similar functioned solution?? Thanks
On Fri, 22 May 2009 10:49:21 GMT, (MG) wrote: >I want to get a copy of EZ Drummer,but I see that it doesn't many >versions of Cubase LE, SX SE SL etc... > >What is a similar functioned solution?? > >Thanks I don't understand the question. I use EZ Drummer with Cubase 5..also had it working with SX3, Cubase 4 and LE4... it will work with any version of Cubase that supports virtual instruments. LL
On Sat, 23 May 2009 00:11:03 +0100, lancelightning <> wrote: >On Fri, 22 May 2009 10:49:21 GMT, (MG) >wrote: > >>I want to get a copy of EZ Drummer,but I see that it doesn't many >>versions of Cubase LE, SX SE SL etc... >> >>What is a similar functioned solution?? >> >>Thanks > >I don't understand the question. I use EZ Drummer with Cubase 5..also >had it working with SX3, Cubase 4 and LE4... it will work with any >version of Cubase that supports virtual instruments. > >LL ....no, it doesn't work with versions up to SX3 apparently...
MG wrote: > On Sat, 23 May 2009 00:11:03 +0100, lancelightning <> wrote: > >> On Fri, 22 May 2009 10:49:21 GMT, (MG) >> wrote: >> >>> I want to get a copy of EZ Drummer,but I see that it doesn't many >>> versions of Cubase LE, SX SE SL etc... >>> >>> What is a similar functioned solution?? >>> >>> Thanks >> >> I don't understand the question. I use EZ Drummer with Cubase 5..also >> had it working with SX3, Cubase 4 and LE4... it will work with any >> version of Cubase that supports virtual instruments. >> >> LL > > ...no, it doesn't work with versions up to SX3 apparently... So, why does it work for me with SX3, then? Do you have the latest version of EZdrummer installed? Phil
On Sat, 23 May 2009 22:45:28 +0200, "Phil W" <> wrote: >MG wrote: >> On Sat, 23 May 2009 00:11:03 +0100, lancelightning <> wrote: >> >>> On Fri, 22 May 2009 10:49:21 GMT, (MG) >>> wrote: >>> >>>> I want to get a copy of EZ Drummer,but I see that it doesn't many >>>> versions of Cubase LE, SX SE SL etc... >>>> >>>> What is a similar functioned solution?? >>>> >>>> Thanks >>> >>> I don't understand the question. I use EZ Drummer with Cubase 5..also >>> had it working with SX3, Cubase 4 and LE4... it will work with any >>> version of Cubase that supports virtual instruments. >>> >>> LL >> >> ...no, it doesn't work with versions up to SX3 apparently... > >So, why does it work for me with SX3, then? Do you have the latest version >of EZdrummer installed? > > >Phil > It works fine with SX3..I recorded several songs that way..it almost certainly works with any other Cubase version that supports VSTi's....LL
lancelightning wrote: > It works fine with SX3. I recorded several songs that way. it almost > certainly works with any other Cubase version that supports > VSTi's... Just tried it with "Cantabile Lite" (a small VST host, that supports VSTi), which I had installed out of interest a while ago. Second, I tried Samplitude 10.21 SE And guess, what happened: EZdrummer just works in both VST hosts, which are definitely not any kind of Cubase... ;-) The OP probably has some other kind of problem, if EZdrummer does not work with his system. One approach to find out, what´s wrong is to try, if other VSTi do work, or if only EZdrummer causes problems. But without more information, it´s hard to figure out his actual problem... Phil
