http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3707672657&category=23792 Ends Mar-06-04 12:43:26 PST KMX-16 Midi Central - Programmable 15x16 midi patchbay Features include quick and easy programming, a MIDI merger on inputs 1 & 2, internal memory for up to 99 patch configurations as numbered presents. Presets are recalled buy the front panel switches or by sending MIDI program change messages. There are two rows of MIDI connectors in the back. Top row is MIDI IN and the bottom row is MIDI out. MIDI CENTRAL allows you to internally patch its MIDI inputs to its MIDI outputs thereby saving you the trouble of plugging and unplugging MIDI cables to and from one device to another. A single input can drive up to 16 outputs at once.... Each output on MIDI CENTRAL can have one input assigned to it, have no input assigned to it, or have a merge from inputs 1 & 2 assigned to it. You can store your configurations in memory for later recall. There are 99 memory locations and they are preserved in MIDI CENTRAL even during power down. These memories can be stored and saved changed and saved all without requiring an internal battery. Memories can be recalled with a MIDI program change command sent from your controller, sequencer, drum machine, etc., or from the front panel. Happy bidding This device is working 100% Home use only This Ensoniq KMX-16 MIDI CENTRAL is in great condition with minor rack wear. Comes with a manual and power supply. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3707672657&category=23792 Ends Mar-06-04 12:43:26 PST
