FA: M AUDIO Omni Studio Delta 66 Near Mint Low Hours
Discussion in 'alt.steinberg.cubase' started by OldGold, Feb 1, 2009.
  1. OldGold Guest
    Message Count:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41784&item=260354392681
    M AUDIO Omni Studio Delta 66 Computer Interface
    This is a superior interface which uses the Delta 66 soundcard married
    to the Omni i/o desktop audio station.
    Item is in near mint condition. Low hours. I am the original owner.
    Includes original boxing, interface, delta 66 sound card, drivers,
    cables, power supply, manual etc.
    Pre amps are GREAT on this interface!
    Features:
    2 Mic/Inst and 2 line level balanced/unbalanced analog inputs to the
    Delta 44 or Delta 66 soundcard.
    2 Mic/Inst inputs equipped with XLR phantom power, insert I/O jacks,
    individual gain controls, gain reduction "pad" switch, and signal/clip
    indicator LEDs.
    Low impedance mic inputs provide 66dB of gain and utilize M Audio's
    critically acclaimed DMP2 pre-amp technology. They are switchable to
    hi-impedance instrument inputs with 46dB of gain, ideal for electric/
    acoustic guitars.
    The Omni Mic/Inst pre-amp has a frequency response of 10Hz to 200kHz,
    low THD of .0009%, with a dynamic range of 130dB.
    Stereo effect return. Mixing Section (all balanced/unbalanced on TRS
    jacks).
    4 Delta outputs can simultaneously be used as independent balanced/
    unbalanced direct outs for use as additional effects sends, alternate
    mix output, or feeds to a secondary mixer.
    4 stereo aux inputs for MIDI devices.
    Stereo Aux inputs 1 and 2 can be muted in the mixer and re-routed to
    the Delta line inputs for easy audio recording of MIDI instruments or
    other auxiliary inputs.
    Mix out for recording to a mix deck
    Control room outs with independent level control for monitoring
    2 headphone outputs with individual level controls
    1 mono effect send per channel
    L/R output signal/clip LEDs
    Powerful digital mixing, routing, and monitoring capabilities with
    included software
    Technical Info:
    Peak Analog Input Signal: +14dBu (+4dBu setting), +6dBV (Consumer
    setting), 0dBV (-10dBV setting).
    Peak Analog Output Signal: +14dBu (+4dBu setting), +6dBV (Consumer
    Dynamic Range: Outputs: 103dB (a-weighted), Inputs: 99dB (a-weighted)
    THD (at 0dBFS): Outputs: less than 0.0015%, Inputs: less than 0.0024%
    Frequency Response: 22Hz - 22kHz, -0.3, -0.2dB
    Input Impedance: 10k ohms minimum
    Input Connectors: 1/4 in. female TRS-type, balanced or unbalanced
    Output Connectors: 1/4 in. female TRS-type, balanced or unbalanced
    Digital Input Format: S/PDIF coaxial, 0.5V to 5V peak-to-peak.
    Digital Input Sample Rate: 8kHz to 96kHz.
    Digital Output Format: S/PDIF coaxial, 0.5V peak-to-peak; AES/EBU data
    stream over S/PDIF coaxial.
    Digital Output Sample Rate: 8kHz to 96kHz.
      • Advertising
  2. Bas Guest
    Message Count:
    On Sun, 1 Feb 2009 08:50:34 -0800 (PST), OldGold <>
    Since when is this newsgroup used for trade?
      • Advertising
Share This Page
