FA: Unique Kurzweil Midi Controller
Discussion in 'alt.music.synth.kurzweil' started by Electrow, Sep 18, 2003.
  1. Electrow Guest
    Message Count:
    This auction is located at:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2558770123&category=38071
    Auction ends Monday 7:32 PM PST
    This fantastic controller has never been used & comes complete with all
    components.
    Discover New Dimensions of Control
    The ExpressionMate is a powerful MIDI processor that can be added on to any
    MIDI device. It comes as two parts: the desk top control box, and the 600 mm
    ribbon controller, similar to the ribbon controller on the K2500. Hook it up
    to a MIDI synth and you will find you have a whole new level of expression
    and control over your instrument.
    In addition to the ribbon, the ExpressionMate has two pedal inputs, a breath
    controller input, and two button switch controllers. All of these physical
    controllers can be assigned to send any MIDI message you want, include, all
    MIDI controller messages, note messages, and even sysex.
    For older MIDI synths that don't have very many physical controllers, the
    ExpressionMate will give you many possibilities for controlling your sound.
    Use the ribbon to open and close filters, crossfade between two sounds,
    change panning and volume - the possibilities are as endless as your synths
    ability to respond to MIDI control. And since you can assign notes to the
    ribbon ( as well as all other controllers), you can use the ribbon to
    actually play your synth. Just tap on various spots on the ribbon to play
    different notes! And with 16 preset and 8 user created scales available, you
    have complete control over exactly which notes you will use the ribbon to
    play.
    Incredible Arpeggiaton Capabilities... see e-bay for more info
      • Advertising
Share This Page
