FA: Unique Synths from Korg & EMU NO RESERVE
Discussion in 'alt.music.synth' started by Electrow, Jan 7, 2004.
  1. Electrow Guest
    Message Count:
    These synths are in excellent condition. There is no Reserve Amount. The
    starting bid for each is only $50!!. All auctions end Sunday 1/11/04 pm.
    These are classic distinct synths. On E-bay at:
    Korg Wavestation:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2371365631&category=38071
    &rd=1
    Review quote:". The Wavestation is also a pretty cool standard synth as
    well, containing a palette of some 650 internal patches, including a few of
    the usual instrument impressions such as sax, horns etc... a large selection
    of different piano's, organs, strings and synths etc....and a mass of
    gorgeous pads, sweeps & atmospheres.......absolutely lush is the best way to
    describe some of them.....You also get some cool industrial sounding
    pads....with lots of robotic/metallic sounds evolving away....."
    EMU Morpheus:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2371368515&category=38071
    &rd=1
    Review quote: "..For a sample-playback based machine, it allows you to do a
    LOT to tweak the samples. First of all, every patch can (but doesn't have
    to, if you choose otherwise) contain primary and secondary samples, filters,
    envelopes, function generators, etc... certain parameters allow you to
    trigger one sample and have it morph/crossfade into the other. Each sample
    gets it's own filter (of which there are 197 to choose from), envelope, etc.
    Samples can also be reversed, tuned across a 4 or 6 octave range, transposed
    +/- 3 octaves (bear in mind, one works on the sample itself, one works on
    keyboard placement)..."
    EMU Audity 2000
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2371377054&category=38071
    &rd=1
    Review quote: "..Ask yourself a simple question :how many synths do I know
    feauturing 12 pole-filters ??? 24 cord patches allows you to modulate
    anything in any way you like.........
    ".Since Emu's marketing can't shut up about the 16 arpeggiators, the first
    thing I did was set up 16 basic patches using internal patterns and fired
    them up one by one from my Roland XP50."
      • Advertising
Share This Page
