FA: Yamaha DGX 500, KORG es-1 and Fostex 4 track
Discussion in 'rec.music.synth' started by The Big D, May 2, 2004.
  1. The Big D Guest
    Message Count:
    Musicians and DJ's, here you go!
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3721806322
    This auction is for a Brand New ONLY USED ONCE Yamaha DGX-500 and a
    new, used KORG ES-1 Rythm Production Sampler with Smartmedia Memory
    Card! And, as a special, if you use the BUY IT NOW feature, I will
    throw in a Fostex 4 Track Recorder!
    The DGX500 is the first Portable Keyboard with piano keys and is the
    flagship in a new series of instruments from Yamaha called Portable
    Grand™. It is packed with functions and features designed specifically
    for the new piano user. Included with the DGX500 is a furniture-type
    stand that completes its piano image. The Yamaha Portable Grand
    feature in the DGX500 is immediately apparent when you see the large,
    piano-shaped button in the center of the front panel. When you push
    it, the best piano is automatically chosen, the auto-accompaniment is
    turned off, putting the keyboard in full keyboard mode — just like a
    piano.
    When you want to record your playing, just press record, the track
    button you want to record on, and start playing. It's that easy. When
    you're done, save your song internally or to the floppy disk drive as
    a Standard MIDI File (SMF) to make it compatible with other General
    MIDI keyboards as well as most computers. Then simply pop the disk out
    of the drive and insert it in your computer. With over 600 voices to
    choose from, the combinations are only limited by your imagination.
    3.5" Floppy Disk Drive opens up a Whole New World
    The DGX500 has a 3.5" disk drive allowing it to communicate with the
    world. You can download a song file from the literally thousands of
    songs on the Internet onto a 3.5" disk in your computer, then take the
    same disk, insert it into the instrument and play the song. You can
    also purchase professionally made MIDI song files and education
    software with music from your local music store. Conveniently, the
    backlit display allows you to select a song from the disk by name. To
    play the song, just push the start button, sit back, and enjoy. And
    finally, even though the DGX500 comes with a generous amount of
    built-in music styles, the disk drive opens up the ability to load in
    even more styles for you to enjoy. And guess what, the Internet is
    alive with people exchanging styles that they have created on hi-end
    Yamaha keyboards. The disk drive will allow you to save and organize
    your favorite data for years to come.
    Yamaha Education Suite™ Learning to play songs and chords
    The DGX500 comes with 100 built-in songs with Songbook. But if you've
    never played before, where do you start? Well, if learning to play
    music is important to you, the Yamaha Education Suite II, a wonderful
    set of music training functions, makes learning music incredibly easy.
    Seven types of lessons are available as well as a convenient chord
    dictionary.
    Three keyboard lessons for each hand
    Timing mode: You can play the melody or chord by pressing any key
    using the correct timing.
    Waiting mode: Playback pauses until you find and play the correct
    chord or melody note.
    Minus One mode: Mute the left-hand, right-hand, or both parts of a
    song and play along nonstop.
    Lesson Grading — monitors your progress as you practice each lesson.
    Chord Dictionary — shows you how to play chords and tells you which
    chords you are playing by displaying the notes and chord name on the
    LCD screen.
    Sound Quality
    2-Way Speaker System
    Separate tweeters deliver high frequency sounds with clarity and
    precision for more lifelike instrument voices.
    Bass Boost System
    A special port on each speaker adds a powerful impact to bass sound
    reproduction.
    Stereo (Not just 2 Speakers)
    We all know that stereo sound adds realistic character and spatial
    depth. But how can you tell if the portable keyboard you're looking to
    purchase is stereo or not? With Yamaha, the answer is simple. All
    Yamaha Portable Keyboards are true stereo.
    Digital Signal Processing (DSP)
    Enhances sound quality with sophisticated digital effects like Reverb,
    Chorus & Echo effects.
    Advanced Wave Memory (AWM)
    Yamaha Advanced Wave Memory technology delivers amazingly realistic
    sound.
    Keyboard Styles and the One Touch Setting
    The DGX500 includes a huge assortment of 135 built-in styles that
    cover all genres of music waiting for you to play along with. It's
    just like having a built-in band.
    32-Note Polyphony
    "Polyphony" is how many notes a keyboard can reproduce simultaneously.
    As with many things, more is often better. Some keyboards in this
    price range have 16, 24 or 28-note Polyphony. The DGX500 has a full
    32-note Polyphony allowing you to play intricate instrumental
    arrangements and dense musical passages.
    Computer Connectivity
    The Floppy Disk Drive makes it easy to transfer files between your
    computer and your Yamaha keyboard, but for those who would rather
    connect the two directly together, Yamaha makes it easy. On the back
    of the keyboard, you'll find a special MIDI (Musical Instrument
    Digital Interface) port that lets you connect your keyboard to your
    computer (requires a MIDI Interface like the UX16 and music software).
    PLUS WITH THIS AUCTION, YOU GET...
    KORG ES-1 Rythm Production Sampler with SMARTMEDIA Memory Card!
    Sample and Go!
    The Electribe S is a new type of sampler that doesn't simply play back
    a recorded sound — it lets you aggressively process the samples to
    create your own signature sound. Play any sound or phrase in and use
    the pitch, filter, and effects knobs to drastically alter the sample.
    Slice Loops with Time Slice
    Chop a sampled phrase or sound into pieces with the Electribe S Time
    Slice function. Time Slice detects the attacks of each part within a
    loop (e.g., bass drum, snare, and hi-hat), so that these parts can be
    massaged separately. You can also use the knobs to modify the tone of
    a phrase processed by Time Slice, creating complex patterns from a
    simple loop or phrase.
    Realtime Resampling
    With the resampling function, you can apply effects to a
    previously-recorded sample and then resample the result. You can even
    resample while modifying parameters such as pitch in realtime, and
    create even more new sounds with absolutely no deterioration in audio
    quality.
    Instant Rhythm Creation
    Assign sampled sounds to up to 10 parts, then use the step sequencer
    to create rhythm patterns. The step sequencer's 16 pads divide a
    measure (or 2 measures) into 16 parts. You decide where you want each
    sound to play by touching the desired keypads to create a pattern. And
    with the touch of a button you can add rolls or reverse playback for
    each part, so you can easily create highly complex rhythms that used
    to take ages to program in.
    Sequence Function
    You're in complete control of sound alteration. With the Motion
    Sequence function, every tweak of a knob can be recorded as part of
    the rhythm pattern. Alter your tone at will on each part using one of
    the following parameters: pitch, filter, level, or pan. Then, with the
    Motion Sequence assign effect on/off, roll, and reverse playback for
    each part (all three can be recorded per part). Plus you can apply an
    Effect Motion Sequence (a motion sequence for effect parameters) and a
    Delay Motion Sequence to the entire pattern.
    Radical Sample Processing:
    In addition to a master delay effect, you get a built-in effects
    processor with 11 types of effects, that can be switched on/off for
    each part. The 11 types include basic effects such as Reverb and
    Flanger/Chorus, as well as unique effects like Decimator, Isolator,
    and Resonant Filter. Effect parameters can be edited using the knobs,
    and knob movements can be used as part of the rhythm pattern in the
    form of a Motion Sequence. The sound processed by the effects can also
    be sampled again. The internal memory of the Electribe S can hold 128
    user patterns. Combine up to 256 patterns/steps to create a song,
    which can be stored in one of 16 internal song memories.
    Store your Data with Smart Media
    The Electribe S provides a Smart Media slot for storing data. 3.3 V
    Smart Media ranging from 4 MB to 64 MB can be used to store your own
    sampled sounds, patterns, and songs. The Electribe S can also load
    AIFF and WAV files via Smart Media, allowing you to take advantage of
    sampled data stored on your computer.
    The Word is in...
    The Electribe's thick, meaty analog sounds are making their own unique
    contribution to global mayhem. But we're not done with our radical
    donation to the rhythmic revolution. Introducing the Electribe S, a
    sampler with a sound that is as fat and gritty as ever. And in true
    Electribe fashion, the Electribe S is packed with tweakable knobs for
    extreme sound editing, and 16 pad keys to program rhythm patterns and
    break beats.
    AND ONLY IF YOU USE THE BUY IT NOW FEATURE, YOU GET THIS, TOO!
    FOSTEX 4 Track Recorder
    Easy Operation
    Once recorded, your tracks can be mixed using the 4 level faders,
    placed on the stereo stage using the independent pan controls, and
    monitored on headphones or via the RCA pin line output. Separate L/R
    line outs means the X-12 can be connected to a Hi-Fi, powered
    speakers, or standard 2-track cassette deck for final stereo mastering
    of your composition. Great care and attention has been paid to the
    design and usability of this compact unit to ensure easy and simple
    operation straight out of the box. Just plug in the power cord, pop in
    a C90, connect your instrument or mic, select a track, press record,
    and start making music.
    Hiss-Free Recordings
    And, being Fostex, you have the tools to ensure great sounding music,
    too. Hiss-free recording is all about getting the most out of the
    available headroom on the tape. In short, you need to maximize the
    input gain of your instrument or mic without overloading. Too little
    gain and you get an excess of hiss, too higher gain, and the signal
    will distort. To achieve the best balance, the X-12 features a
    low-noise mic/instrument input with the addition of a rotary gain
    control and an illuminated level meter. By adjusting the gain whilst
    watching the meter you can achieve the best signal to noise ratio.
    Aiding quality still further is the new tape transport which has been
    re-engineered from previous models and includes a larger flywheel
    which enhances reliability, ensuring consistent recording quality.
    Musical Sketch Pad
    Highly portable and robust the new, low-cost Fostex X-12 Multitracker
    is a blast to use, has the tools you need and looks pretty cool too.
    For grabbing inspiration when it comes nothing beats it.
    DO THE MATH!
    Keyboard = $700.00
    Sampler = $450.00
    Mem Card = $50.00
    4 Track = $100.00
    TOTAL = $1250.00
    BUY IT ALL NOW FOR $900! What a savings!
    Serious bidders only please!
      • Advertising
Share This Page
