Basically, I've EQing the tracks, doing the final levels and then export them as a .wav file and removing any DC offset and normalizing them, finished. It just occurred to me that this is probably not optimium. Yes, I know I am a ****ing savage. So, use any specific plug-ins on the main? Render options? TIA yer pal XODDI
Op 14-11-2010 0:07, XODDI schreef: > Basically, I've EQing the tracks, doing the final levels and then > export them as a .wav file and removing any DC offset and normalizing > them, finished. It just occurred to me that this is probably not > optimium. > > Yes, I know I am a ****ing savage. > > So, use any specific plug-ins on the main? Render options? I use a multiband compressor and a bit of maximizing on the final mix. A little of both goes a long way, usually. Jos. -- Ardis Park Music www.ardispark.nl
There's no rules, but there are some common procedures. After the mix, I export the file and import it on Wavelab Most of the times I put a multiband equalizer, a multi band compressor and multiband maximizer. Sometimes if needed I put an harmonic exciter and a stereo enhancer... These last 2 have to be used carefuly. Unlike you, I don't normalize but like you, I remove DC offset. I always leave 2 seconds of silence in the begining. As for Eqs, Compressors and maximizer, I don't have any rules, it goes how I hear it. Respect Paulo "XODDI" <> wrote in message news:... > Basically, I've EQing the tracks, doing the final levels and then > export them as a .wav file and removing any DC offset and normalizing > them, finished. It just occurred to me that this is probably not > optimium. > > Yes, I know I am a ****ing savage. > > So, use any specific plug-ins on the main? Render options? > > TIA > > yer pal > XODDI
On Nov 14, 3:09 pm, "Paulo Gomes" <> wrote: > There's no rules, but there are some common procedures. > After the mix, I export the file and import it on Wavelab > > Most of the times I put a multiband equalizer, a multi band compressor and > multiband maximizer. Sometimes if needed I put an harmonic exciter and a > stereo enhancer... These last 2 have to be used carefuly. > > Unlike you, I don't normalize but like you, I remove DC offset. > > I always leave 2 seconds of silence in the begining. > > As for Eqs, Compressors and maximizer, I don't have any rules, it goes how I > hear it. > > Respect > Paulo > > "XODDI" <> wrote in message > > news:... > > > > > Basically, I've EQing the tracks, doing the final levels and then > > export them as a .wav file and removing any DC offset and normalizing > > them, finished. It just occurred to me that this is probably not > > optimium. > > > Yes, I know I am a ****ing savage. > > > So, use any specific plug-ins on the main? Render options? > > > TIA > > > yer pal > > XODDI Multi compressors, loudness maximizers and even exciters all work towards no dynamics. Be careful. See this: http://www.turnmeup.org/
You're absolutely right... One gotta be carefull using those processors other wise it might sound dead. Paulo Multi compressors, loudness maximizers and even exciters all work towards no dynamics. Be careful. See this: http://www.turnmeup.org/
On Nov 15, 6:50 am, "Paulo Gomes" <> wrote: > You're absolutely right... One gotta be carefull using those processors > other wise it might sound dead. > > Paulo > > Multi compressors, loudness maximizers and even exciters all work > towards no dynamics. Be careful. See this:http://www.turnmeup.org/ Jos, Paulo, Danny, thanks for the tips. I have always kept compressors off the mains, almost superstitiously. But what about the UV22 Apogee dithering plug-in?
On Nov 15, 1:05 pm, XODDI <> wrote: > On Nov 15, 6:50 am, "Paulo Gomes" <> > wrote: > > > You're absolutely right... One gotta be carefull using those processors > > other wise it might sound dead. > > > Paulo > > > Multi compressors, loudness maximizers and even exciters all work > > towards no dynamics. Be careful. See this:http://www.turnmeup.org/ > > Jos, Paulo, Danny, thanks for the tips. I have always kept compressors > off the mains, almost superstitiously. > > But what about the UV22 Apogee dithering plug-in? People say they can hear the difference but I can't so I leave it alone. As for keeping compression off the mains, that is not an issue. You can compress the mains with stellar results, just don't over compress. Keep in mind a few things to look for. Audio, when compressed wrong not only loses dynamics but makes a pumping sound. You might want that for some things. You'll hear it if you are thinking about looking for it. If you compress everything just a little, you can bring out dynamics too. When you have a guitar miked up close, you'll see that some things really get accentuated. A compressor can level it out and make it sound much more natural but only when used lightly. I like to compress an acoustic that I'm figure style on with about 2:1 or maybe 2.5 :1. That brings up the quite stuff and mellows the over picked notes. I do about the same to my vocals. I usually compress the hell out of the bass at about 6:1 so that it is just a solid backbone. I do something similar to snare and kick but I leave the toms a lot more loose. Back ground vocals I compress the hell out of too so that they are not the dynamic for people to pay attention to, leaving the lead vocal as the main actor. .. usually good.... In the end when everything has the flavor that fits into the pie just right, I often compress the entire mix by about 1.5:1 to 2:1. that brings everything into the same room so to speak. Having said all that, I do natural sounding music where as in a dance song none of that applies. I am not into dance/trance/house... whatever. I do more of an acoustic style. When you are going for effects, nothing but creativity applies. The over squashed sound might be fine and dynamics can be achieved by removing instruments for a few bars. That sort of non intelligent mood music needs to grab your body, not your brain. No I don't like it but I do understand it.... Good luck - make lots of music
