First experiences with SONAR x64 on Win7 x64
Discussion in 'cakewalk.audio' started by Rick Paul, Oct 28, 2009.
  1. Rick Paul Guest
    Message Count:
    Late yesterday afternoon I got around to installing SONAR 8.5 on my newly
    upgraded 64-bit Windows 7 Professional system.
    When you install SONAR 8.5 (at least on a 64-bit system -- I don't recall if
    this was true on 32-bit XP), it gives you the choice of installing the
    32-bit or 64-bit version. I kind of wish it had let me install both so I
    could try them side by side to compare in the event of problems. I went
    with the 64-bit version since going to 64-bit SONAR was my big reason for
    going to 64-bit Windows in the first place. If that ends up being a big
    problem once I get around to trying more things out, I guess I can always
    revisit the choice. I should note that I have no clue if there is actually
    the possibility of installing both side-by-side. The directory name used
    and file name used for the 64-bit version has nothing in it to suggest a
    64-bit version, but maybe just specifying a different directory name would
    be good enough to install the other version alongside it. Or maybe not. ;-)
    I did the custom installation so I could choose paths and which plug-ins I
    want and don't want. I mostly choose all the plug-ins, but there are some
    that aren't on by default that I want to have there and some that are on by
    default that I don't want. Guitar Rig 3 LE is the main example of the
    latter (since I have the full Guitar Rig 3 plug-in). There are a few of the
    old Cakewalk plug-ins that are good examples of the former.
    One thing I noted in selecting plug-ins was there are a number that say
    32-bit only, but some of those were not automatically turned off for
    installation in the 64-bit SONAR installation. For example, the
    DSP-FX-based Fx-series plug-ins like FxReverb fit that description. This is
    only applicable to DX and DXi plug-ins as BitBridge should take care of any
    32-bit VST and VSTi plug-ins. I was disappointed that DreamStation is on
    the 32-bit only list, though I have plenty of options these days for the
    sort of thing it does decently. It's kind of a bummer to not have the Fx
    plug-ins, too, though I honestly haven't used them in some time now. (It
    will be a bigger bummer to not be able to use the full DSP-FX suite, as
    there are still one or two plug-ins there I use occasionally, and one I'd
    been using in most of my projects.) I also noted stuff like QuickTime
    import support was enabled by default, even though it says 32-bit only, so I
    disabled that kind of stuff, too.
    This is the first time I've installed SONAR on a "fresh system" (i.e. in the
    sense of having no user data to migrate) in ages, so I have to think about
    what all my preference stuff was so I can set that back up. In general, the
    installation went fine, then I had to tweak a few things to get to a
    starting point, such as changing the default of WDM audio card support to
    ASIO for my device's better drivers, resetting my audio and folder
    preferences, etc. I also applied the 8.5.1 patch to get things up to date.
    I could not get the MP3 encoder authorization program to work. It told me
    it couldn't find the shared utilities directory, so SONAR must not be
    installed properly. Well, it was installed and it works, so I don't know
    what gives with that. Something to revisit later...
    I loaded Beatscape next since that is on a separate DVD. I made a mistake
    in telling it what VST directory to use (I'd changed the default so I can
    get the Cakewalk plug-ins where I put the other ones, rather than having two
    separate VST root directories), so I had to move that manually later when I
    noticed it wasn't showing up in the plug-in list. Got that done and
    working. Side note: Just playing with Beatscape a few minutes "to verify
    its installation" reminded me how much fun that can be to play with. Still
    don't know if/when I'll ever use it in a real song, though.
    Next up was Dimension Pro. I'd hoped there would be a way to just reinstall
    the software without reinstalling the samples, since they were already on my
    hard disk, but, if so, I didn't find it. So I decided to have the samples
    go to a different directory since I was going through that anyway, then I
    can clean up the original ones later. I was pleasantly surprised to see
    that it is Dimension 1.2 that is shipping with SONAR 8.5's package with the
    media, and it offered me the choice of installing the 64-bit or 32-bit
    version. I went with 64-bit. After going through that installation and the
    ones for extra libraries for that (both from the 4th SONAR 8.5 DVD and some
    I have elsewhere), I was ready to try things out. It took a long time to
    rebuild its database/screen, but that eventually came up for the DX version.
    The VST version wasn't in the menu at all. I checked, and it was in the
    right location, so I don't know why it wasn't there. So I decided I'd do my
    usual trick of moving it out of the way, running SONAR again to refresh
    things, then moving it back and running SONAR again to refresh things and
    get it in there. That also didn't do it, but then I remember the tech note
    on making 64-bit Dimension Pro work, and it specified doing some things as
    admin, so I tried again, running SONAR as Administrator, and that got it in
    the menu. Somewhere in the course of doing something, though -- and I may
    have my order of events wrong above since it is from memory -- something got
    messed up. At one point the VST version came up and loaded the patch list,
    but now it won't load the VST version at all. Also, I hadn't tried last
    night to actually load a patch, just to bring up the directory, and this
    morning, when I tried loading patches, they were giving error messages about
    not finding their samples. I think that in the course of moving the
    Dimension Pro VST directory around I accidentally moved another Dimension
    Pro directory. While I thought I did a Windows Explorer-level Undo enough
    times to get back to where things were, it may be that I did not, or that I
    messed something up as I'm not even sure how I moved the wrong directory in
    the first place. Bottom line is I don't have Dimension Pro actually
    functioning at the moment, and I'll have to troubleshoot that when I get a
    chance. The DX version does load and shows its patch list, but the VST
    version doesn't even load.
    This morning I used SONAR 8.5 to practice some new songs for the worship
    band I play in at a local church. The routine there is to use a SONAR
    project I have preconfigured with the most common instrument types I use and
    a blank audio track. I drag an MP3 reference file of the song to the blank
    audio track, set the focus on the instrument track with the instrument sound
    I want to use for the song, then let the song play and play along. Because
    I haven't installed my non-Cakewalk instruments yet, I used the 64-bit
    version of TruePianos and a lame-assed organ sound from Roland GrooveSynth
    (I was originally going to see if Dimension Pro had something for me there,
    but got the sample errors I mentioned above).
    Lately I'd been setting latency for that practicing at 5-7 ms because, with
    Outlook sitting in the background and running whatever else was going on
    with my system drivers-wise and all, I'd get some crackling in something at
    lower latencies. However, today I decided to go straight for 2 ms, which is
    the lowest my card goes. It worked like a charm, even when I was playing
    along with Windows Media Player with a complex visualization playing at one
    point due to another problem I encountered (see below). Of course, there
    isn't as much going on with my system now as on the XP system, so that may
    be contributing, and I was using different instruments (e.g. TruePianos
    versus Garritan Steinway, GrooveSynth versus B4II) or maybe Win7 x64 really
    does have some performance benefits? I'll be watching this more as I get my
    system back to its more normal state.
    The only other problem I had in the course of this is that, when I dragged
    the MP3 file from one of the 5 songs I worked on from Explorer to the audio
    track, it gave me an Out of Memory error message. I was most certainly not
    out of memory, and I even tried stopping and restarting SONAR to make sure
    there wasn't just some funky internal state. I tried the file repeatedly,
    as well, to make sure there wasn't just some fluke, and other songs I
    dragged over afterward worked fine, too, so there is obviously something
    specific to the one MP3 file. That is when I just gave up on figuring it
    out for now and played it in Windows Media Player. (All the files worked
    fine there, so I knew the MP3 file was okay at that level.) I'll have to
    look at that further once I have some other applications installed, for
    example trying to read it into Sound Forge to see if that will handle it,
    looking at any specific attributes of the file to try and narrow down why
    it's not working.
    The problems with Dimension Pro also reminded me that I haven't loaded all
    the other synths yet to see if they actually work on the new installation,
    locate their patches, and so on. I did actually try most of the audio
    plug-ins when going through to test things, and they were fine. I was
    pleasantly surprised to see that most of the Cakewalk plug-ins that were on
    my previous system from my 9 iterations of SONAR and one of ProAudio were
    still there, even some of the older ones. The notable fallouts were the
    above-mentioned Fx-series, the surround version of Lexicon Pantheon (not
    sure when that was last included), the above-mentioned Dreamstation synth,
    and the FX3 Soundstage plug-in. I was kind of bummed in principle on the
    Soundstage thing in that I always thought that was a very promising plug-in,
    but, in reality, I hadn't used it in ages anyway because I never much liked
    the sound of it for ambience purposes. (It was never really part of SONAR
    anyway, so I didn't really expect it would be there. I think I got it as
    part of Cakewalk Pro Suite, which was an enhanced version of ProAudio 9.
    However, with the 64-bit stuff, and that being a 32-bit DX plug-in, it might
    have been nice if there were a 64-bit version available. It's really too
    bad Cakewalk never did anything further with that, because the idea of being
    able to localize things visually is really cool, and a lot of work goes into
    trying to do that aurally with other tools.)
    Oh yeah, and the other notable thing that isn't there (and wouldn't be from
    just installing SONAR 8.5) is the Timeworks plug-ins that were in SONAR 2
    XL, namely CompressorX and Equalizer. Those were ones that made it worth
    going back to the SONAR 2 disc to get them, but their being 32-bit DX means
    they won't work on 64-bit SONAR, so there is no point now. Bummer. There
    are a few others in a similar category of one-time inclusions, like Tassman,
    LiveSynth Pro, VSampler, and probably one or two others I'm forgetting -- oh
    yeah, Revalver. But CompressorX and the Timeworks Equalizer were really the
    only ones I was still using with any regularity. (I think I also have the
    VST version of DR-008, but I haven't used that in awhile, so may not even
    reinstall it.)
    I've got a few more office-oriented applications I want to get out of the
    way before I focus on more plug-ins. I just needed enough of SONAR working
    to do my practicing this morning. But I should be getting back to
    installing my high priority plug-ins in the fairly near future, probably
    starting later tonight or tomorrow.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news: the killer robot
    "Rick Paul" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > recall if this was true on 32-bit XP), it gives you the choice of
    > installing the 32-bit or 64-bit version. I kind of wish it had let me
    > install both so I could try them side by side to compare in the event
    > of problems. I went with the 64-bit version since going to 64-bit
    > SONAR was my big reason for going to 64-bit Windows in the first
    > place.
    I'm sure you can install the 32 bit version, and not blow away the 64 bit
    version. Surely they live in different folders and can coexist. To do
    otherwise would be extremely stoopid, and while they may luv beetz & loopz,
    I don't think Cake is that stoopid. ;)
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. kitekrazy Guest
    Message Count:
    >> place.
    Yes you can. All 32 bit apps intall in a program files x86 folder.
    The only pain is installing the various Vsts. They also have separate
    folders. Plus Cakes VST scanner sucks compared to Reaper and FL.
  4. kitekrazy Guest
    Message Count:
    >>> place.
    >> bit version. Surely they live in different folders and can coexist.
    >> To do otherwise would be extremely stoopid, and while they may luv
    >> beetz & loopz, I don't think Cake is that stoopid. ;)
    BTW, stay away from trying to install Dimension Pro as 64 bit. I've had
    nothing but problems.
      • Advertising
  5. Rick Paul Guest
    Message Count:
    "kitekrazy" <> wrote in message
    news:hcb38a$u37$-september.org...
    Thanks for the info. I'll revisit the 32-bit SONAR at some point in the
    future if I end up having issues I suspect may be 64-bit specific or need to
    have the 32-bit version around for some specific needs.
    As for Dimension Pro, what sort of issues are you having? I'm wondering if
    they are the same sort of things I've been seeing with the VST version not
    loading at all at the moment and the DX version not being able to find its
    samples. I *think* those issues are probably due to user errors on my part
    as I did do some kind of strange folder move thing that I still don't
    understand how I did in the first place (best I can guess is I was confusing
    the software folder with a folder of the same name under the VST structure,
    perhaps due to not being used to the different look of Windows Explorer in
    Win7) and thought I'd reversed it (but maybe fell short of one Undo command
    or something).
    In general, I've started a list of issues to revisit when time permits, and
    figuring out what's going on with Dimension Pro is one of those (most of the
    others aren't related to SONAR at all). For now, though, much more pressing
    is getting my other apps and plug-ins back in shape, and I've got a boatload
    of plug-ins, even just among the ones I use frequently, no less all the
    rest.
    Rick
    Rick Paul
  6. polymod Guest
    Message Count:
    "Rick Paul" <> wrote in message
    news:...
    if
    actually
    by
    the
    is
    any
    I
    the
    the
    date.
    two
    I
    Still
    reinstall
    my
    the
    the
    some
    version.
    my
    note
    in
    got
    list,
    about
    I
    in
    and
    blank
    sound
    Because
    there,
    with
    at
    is
    one
    really
    my
    audio
    not
    > it's not working.
    on
    plug-in,
    liked
    might
    being
    into
    from
    means
    Tassman,
    oh
    the
    > reinstall it.)
    working
    Cripes, this post makes me want to throw everything out the ****ing window
    and just sit at a piano ;).
    Poly
  7. Rick Paul Guest
    Message Count:
    "polymod" <> wrote in message
    news:4ae9be7b$0$4983$...
    LOL. I do that every day. It's funny how an instrument we've been playing
    for decades can still be the favorite over all the new-fangled toys. Wouldn't
    want to record my piano, though, so the toys win out when it comes to that
    side of things.
    Rick
    Rick Paul
  8. Glennbo Guest
    Message Count:
    In news:4ae9be7b$0$4983$ the killer robot "polymod"
    <> grabbed the controls of the spaceship
    > window and just sit at a piano ;)
    Ok, but no off the cuff jamming! You have to read pages and pages
    of sheet music to offset Rick's pages and pages of post! ;)
    ________ __
  9. Glennbo Guest
    Message Count:
    > window and just sit at a piano ;).
    ________ __
  10. Michael Fanning Guest
    Message Count:
    Hi Rick- I went through that with Vista 64 and Sonar8 x64 and trying to get
    the mp3 encoder to work. I contacted Cakewalk through their online support
    and they sent me a link for a download that fixes the authorization problem.
    No problems after that
    MICHAEL FANNING,
    http://www.soundclick.com/michaelfanning
  11. polymod Guest
    Message Count:
    news:...
    window
    playing
    Wouldn't
    > side of things.
    Well, if I had it my way, I'd run a couple of mics to my living room and
    record nothing but acoustic piano tracks for the rest of my life.
    But I got some test recordings to do in Reaper first<VBG>
    Poly
  12. Rick Paul Guest
    Message Count:
    news:4ae9de53$0$4993$...
    > news:...
    > window
    > playing
    > Wouldn't
    >> that
    >> side of things.
    Your piano and living room are obviously better sounding than mine. I did
    try recording my piano once (not in my living room, because it was back a
    quarter of a century ago when I lived in a condo in San Jose), and stuff
    like pedal squeaks, bench squeaks, the generally non-optimal sound of a
    spinet piano, etc., not to mention the "ambience" of a small bedroom, just
    didn't deliver the same experience on a recording as it felt in the room
    while playing. Of course, that was also back when I only had an 8-track
    reel-to-reel recorder, and the mics had a lot of self-noise, too. Still,
    I'll take my Garritan Steinway for recording over my 1940-something Story &
    Clark spinet any day. But I'll play the old spinet over any electronic
    piano recreation any day, too. There's just something about a massive hunk
    of mahogany, real strings, and ebony and ivory.
    Rick
    Rick Paul
  13. sambodidley Guest
    Message Count:
    I thought Outhouse Express was the only thing that sent double posts.<g>
    "Glennbo" <> wrote in message
    news:Xns9CB38A2D979B7BrownShoesDontMakeIt@188.40.43.213...
    > ________ __
  14. Glennbo Guest
    Message Count:
    In news:d848d$4aea0b02$62143331$ the killer robot
    "sambodidley" <> grabbed the controls of the
    Check the post times.
    Date: Thu, 29 Oct 2009 18:12:06 +0000 (UTC)
    Date: Thu, 29 Oct 2009 18:35:07 +0000 (UTC)
    *I* sent the second one because the first one didn't show up for over
    thirty minutes, so I sent the second one 23 minutes later, which also
    didn't show up till over thirty minutes later. This dup post was the
    result of a server hiccup, that made me think the first one was not going
    to post.
    ________ __
  15. BobF Guest
    Message Count:
    > to post.
    sure, pal. xnews has *nothing* to do with it ... sure ... you'd like to
    think so!!!
  16. Glennbo Guest
    Message Count:
    In news:hcd3g5$liq$-september.org the killer robot BobF
    >>> posts.<g>
    >> going to post.
    > to think so!!!
    Xnews can do no wron+++ATH+++ >>>NO CARRIER<<<
    ________ __
  17. Sue Morton Guest
    Message Count:
    Hey BobF what do you expect from the guy who isn't who he says he is?
    Sue Morton
    Glennbo wrote:
    > BobF wroet:
    >> to think so!!!
  18. BobF Guest
    Message Count:
    Those darned expectations keep getting in the way :)
  19. Glennbo Guest
    Message Count:
    In news:hcd59a$bav$-september.org the killer robot "Sue
    Morton" <> grabbed the controls of the spaceship
    >>> to think so!!!
    It's like that Star Trek episode where Kirk says "everything Spock says is
    a lie". Then Spock says "I'm lying" and all the robots begin to short out.
    ________ __
  20. kitekrazy Guest
    Message Count:
    > or something).
    > rest.
    > Rick
    First off Cake needs to create a seperate 64 bit install for it. Their
    way of updating it is really half assed. The updater still installs the
    DP files in 32 bit Sonar. That's the wrong way to do it. Personally I
    hate installers for plugins. They should just have a zip file.
    Plus their installers need to be redone since the 64 bit VSTs get
    installed in the same directory as the 32 bit. NI and Garritan put them
    separately. Pretty half assed for a company that has been making 64 bit
    apps for awhile.
    I just have to be careful which DP I select in Sonar. One causes it to
    crash needing a reboot.
      • Advertising
Share This Page
