fp vs rd
Discussion in 'alt.music.synth.roland' started by slowpoke, May 28, 2006.
  1. slowpoke Guest
    Message Count:
    can anyone explain in words or one sylabal the difference in the fp
    range and the rd range. In particular I am interested in the fp-2 and
    teh rd-300sx. Is is about voices? inbuilt speakers?
    or what?
    Thanks
    C
      • Advertising
  2. Kzie Guest
    Message Count:
    hello,
    I'm not so familiar with the fp range but I do know the RD range (I gad
    the RD 150, RD 170 and RD 500 and played on the RD 300SX and RD700SX
    The FP is called a home piano and the RD is called a Stage piano. This
    might tell you something. Like the FP will have a nicer (fixed) stand
    and probably speakers as well. The RD is more for on the road.; no
    speakers but more options like sounds and rhytms and stuff.
    The feel is different in both instruments. That's something personal
    and you have to experience this. So go and play on both of them.
    The RD300SX has lots of features such as ryhtms and splits. What I
    don't like about the RD300SX is that you can not expand this one with
    expansion boards. If your looking for expandable version that's a minor
    so look for another. I like the RD 700 which is a bit older but has a
    nice touch, nice rhytms and can handle expansion 2 boards.
    It has 3 layers + rhytm while the RD 300SX has only 2 layers. The RD
    700SX has 4 layers but its price is almost twice the RD 700
    If you work with computers the RD SX series is ok as is has USB !
    Sorry for not knowing the fp but I loved the RD as I saw it :)
    Kees
    The RD 300SX is light weigthed for a weighted keyboard.
  3. slowpoke Guest
    Message Count:
    Thanks for the info Kzie.
    Your comments make sense as many of the Yams and Rolands I have tried
    look more suited to home use rather than gigging. I am seriously
    looking at the 300sx despite its limitations. Portability and piano
    sound are priorities. I will have to try action of course but in my
    price range It looks good.
    C
      • Advertising
Share This Page
