Getting your Line 6 FBV Shortboard MkII to work with PodFarm pluginin Sonar 6, 7, or 8
Discussion in 'cakewalk.audio' started by Ken, Oct 10, 2009.
  1. Ken Guest
    Message Count:
    Getting your Line 6 FBV Shortboard MkII to work with PodFarm plugin in
    Sonar 6, 7, or 8
    Intro:
    I want to say that this is a slightly more involved process than it
    needs to be due to Sonar's ACT controller setup is one of the worst
    ui's possable. I almost went to hacking the xml directly to avoid it.
    I realize that most people aren't used to xml markup so, I did my
    modifications through the GUI interfaces. On the other hand Line 6's
    FBV Control Software is really easy to use. That being said, Line 6
    should work with Sonar developers to supply a preset or importable
    surface control xml file. Due to competition in the industry it may be
    impossable.
    My Setup Relevent to the Process:
    Windows XP
    Sonar 8.5.1
    FBV Control 1.00
    Goal of My Setup:
    The shortboard should control transport and PodFarm plugin in a stage-
    like fashion for recording or live playing with Sonar.
    Expected Control Specifics:
    Button A Rewind
    Button B Stop
    Button C Record Start/Record Punch
    Button D Play/Stop
    Tap Button Shift Between Tone 1 and 2 in Dual Mode for the Stomp/Mod/
    Delay/Reverb
    Up Button Go|Next Marker
    Down Button Go|Previous Marker
    Function 1 Button Edit|Undo
    Function 2 Button Edit|Redo
    Stomp Button Switch on/off for Distortions/Dynamics/Filters
    Modulation Button Switch on/off
    Delay Button Switch on/off
    Reverb Button Switch on/off
    Toe Switch Toggle on/off for Tone 1 WAH Pedal
    Pedal in Wah Mode WAH Position for Tone 1 WAH
    Pedal in Vol Mode Do nothing due to no input level control exploited
    as a VST adjustable paramater
    The Process:
    This breaks into a hardware and software configuration. First you have
    to configure the Shortboard hardware via Line 6's FBV Control Software
    and then you need to setup the Sonar software to interpret the
    hardware signals.
    Harware Config VIA FBV Control Software:
    *Assume all channels and ports are 1*
    Control: MIDI Command Value: Switch Mode:
    Function 1 Midi CC CC 26 Single
    Function 2 Midi CC CC 27 Single
    Bank Up Midi CC CC 29 Single
    Bank Down Midi CC CC 30 Single
    A MMC Rewind Single
    B MMC Stop n/a
    C MMC Record Punch(Protools) n/a
    D MMC Play n/a
    Tap Midi CC CC 31 Toggle
    Stomp Midi CC CC 25 Single
    Modulation Midi CC CC 50 Single
    Delay Midi CC CC 28 Single
    Reverb Midi CC CC 36 Single
    Toe Switch Midi CC CC 43 Toggle
    Pedal Wah Midi CC Foot Control n/a
    Pedal Vol Unassigned n/a n/a
    Save this config to a file for backup purposes:
    Sonar Config:
    *I'm assuming a basic understanding of how to do basic tasks in
    Sonar*:
    Setup Test Project:
    1. Create a new project with one audio track
    2. Add PodFarm to the FX bin
    3. Set PodFarm to Dual mode and make sure each tone contains a
    distortion, chorus, delay and reverb
    4. Make sure tone one has a WAH assigned to it
    Make the Transport Controls Work
    1. Goto Options -> Controllers/Surfaces
    2. Add a new "MMC" using the FBV (usb audio device on my system) as
    the input port. If its not available use the MIDI Devices button to
    enable it. Select none for the output port and hit okay.
    3. Close Controller/Surfaces pane
    4. The transport should work now using A - D buttons as stated in my
    Goal section.
    Make the FBV control aspects of Podfarm (The Tricky Part):
    *This get a bit fiddly so bare with me*
    *Instanciate the FBV as an ACT Contoller*
    2. Add a new "ACT MIDI Controller" using the FBV (usb audio device on
    my system) as the input port. If its not available use the MIDI
    Devices button to enable it. Select none for the output port and hit
    okay.
    *Prep the ACT MIDI Controller for Use*
    1. Goto Tools -> The name of the controller
    2. Select the default preset enter in a nave for your preset and save
    3. Set the rotary, slider, and button banks to 4, 4, and 2
    respectivly
    4. Set the Rotaries Mode to Channel Strip and the Control group to
    Main
    5. On the options tab set the following (make sure you set the banks
    right for the buttons)
    Rotaries Bank 4 Uncheck Exclude from ACT
    Sliders Bank 4 Check Exclude from ACT
    Buttons Bank 2
    Assign the following for the button values
    Button: Command: Excude from ACT:
    Button 1 none uncheck
    Button 2 none uncheck
    Button 3 none uncheck
    Button 4 none uncheck
    Button 5 Go |Next Marker check
    Button 6 Go |Previous Marker check
    Button 7 Edit |Undo check
    Button 8 Edit |Redo check
    Shift-Button 1 none uncheck
    Shift-Button 2 none uncheck
    Shift-Button 3 none uncheck
    Shift-Button 4 none uncheck
    Shift-Button 5 Go |Next Marker check
    Shift-Button 6 Go |Previous Marker check
    Shift-Button 7 Edit |Undo check
    Shift-Button 8 Edit |Redo check
    6. Return to the Controllers Tab and save the preset
    7. With the Controller Tab open double click the PodFarm plugin to
    bring up its properties frame
    8. looking back at your Controller tab you should see some frames have
    turned blue and the Active Controller Technology section reads Pod
    Farm
    9. Check the "lock" box to make the plugin have the focus for "midi
    learning"
    10. save the preset
    *Frame Assignment and Midi Learn (the tricky part)*
    As you look at the frames in the Controllers Tab you'll see that they
    are not the controls we need so we will have to alter them using the
    ACT Learn Feature. The help file and manual are brief in their
    description and in some cases leave out steps when describing this
    feature. I willl try to be more verbose. My ACT Learn process is as
    follows:
    Frame Assignment Repeated Process:
    With both the PodFarm frame and the Controllers tab open do the
    following:
    Note: In the case of the FBV make sure the pedal on your controller is
    in WAH mode prior to starting as it seems more reliable in being
    sensed than the buttons
    1. Hit one of the "ACT Learn" Buttons on either of the frames (button
    just says ACT)
    2. Then left click the cell you want to assign a function to in the
    Controllers Tab (it will display MIDI learn)
    3. Then adjust a parameter in PodFarm like turning the distortion
    pedal on or off
    4. Move a midi control (in the case of the FBV I use the Wah Pedal
    moving it back and forth once not engaging the toe switch)
    5. Hit one of the "ACT Learn" Buttons on either of the frames (if all
    has gone well you should have a prompt saying it has seen one control
    and parameter move.)
    6. Accept the change (you should see the frame now contains the
    parameter you just moved)
    7. Left click the cell it will say "midi learn" now click the
    floorboard button you want to assign to that parameter
    8. Test that the button adjusts the parameter ( sometimes it took a
    few tries for the midi learn to take )
    How I assigned my frames(follow my order using th above process and
    variations in process are labeled with **):
    Frame: Value: FBV Button learned: Where in PodFarm:
    Button 1 1 DstDynFltOnOff Stomp On/Off button for tone 1's
    distortion pedal
    Button 2 1 ModOn/off Modulation On/Off button for tone 1's
    modulation pedal
    Button 3 1 Dly-On/Off Delay On/Off button for tone 1's delay pedal
    Button 4 1 Vrb-On/Off Reverb On/Off button for tone 1's reverb
    processor
    **on the options tab "Clear Midi learn"
    **On the Controllers Tab hit "Shift Learn" and press tap twice on the
    FBV
    **Assigning the shifted Buttons is the same but the shift must be
    engaged when doing the ACT Learn
    **Make sure the tap is lit and proceed ACT Learning the shifted
    buttons 1-4
    Shift + B1 2 DstDynFltOnOff Stomp On/Off button for tone 2's
    distortion pedal
    Shift + B2 2 ModOn/off Modulation On/Off button for tone 2's
    modulation pedal
    Shift + B3 2 Dly-On/Off Delay On/Off button for tone 2's delay
    pedal
    Shift + B4 2 Vrb-On/Off Reverb On/Off button for tone 2's reverb
    processor
    **Turn off the shift by pressing tap so that it is not lit
    **Put the FBV Pedal in Volume Mode
    **Assign the next parameter using the toe switch instead of the sweep
    and there is no need to do the midi learn of the cell at the end
    Rotary 1 1 Wah-On/Off Toe Switch On/Off of the tone 1's Wah Pedal
    **leave the pedal in Wah Mode and assign it
    Rotary 2 1 Wah-Pos FBV Pedal The Wah position dial in tone 1's Wah
    Pedal
    **Now just midi learn the buttons 5-8
    Button 5 Go | Next Marker Bank Up
    Button 6 Go | PreviousMarker Bank Down
    Button 7 Edit | Undo Function 1
    Button 8 Edit | Redo Function 2
    **test all controls but you should be done (Clear Midi Learn is your
    friend if you have bad button to cell assignments)
    **remove the check in the ACT lock
    **Save your preset
    Summary:
    The transport controls will work in any context the PodFarm controls
    will only work in a PodFarm plugin. You Should be done. Post back if
    you have any questions.
      • Advertising
Share This Page
