GR 20- and a basic MIDI question
Discussion in 'alt.music.synth.roland' started by Peter Pan, Nov 23, 2007.
  1. Peter Pan Guest
    Message Count:
    I'm currently using a GR 20 guitar synth with my band. The draw back to this
    unit is when I need to change from one patch to the next or back to the
    guitar , I have to use the switch on the Pick up. This some times causes a
    less then smooth transition. Some of the earlier GR models have floor pedals
    that you pre-program for faster/ smoother switching.
    My question is this: Would a Foot Control board such as the FC 7 work for
    changes I need?
    http://rolandus.com/products/productdetails.aspx?ObjectId=832
      • Advertising
  2. Mr. Strat Guest
    Message Count:
    In article <>, Peter Pan
    > changes I need?
    I assume you're talking about how the sound you're playing cuts off
    when you switch to a different one. I don't know of any way around that
    - it's just the way the unit is built. And yes, it is a bit clunky to
    flick the switch from guitar to synth or whatever. Generally, whatever
    sound I start with is going to be it for the whole song, but that's
    just me.
  3. Peter Pan Guest
    Message Count:
    > just me.
    What I am talking about is a faster way to change for one bank to the next
    or from a bank to the guitar, without using my hands (without using the
    slector switch on the pickup). A foot controler is what I'd like to use, its
    built into the older GR 33. I'm wondering if I bought a MIDI foot controler,
    would this work?
  4. Mr. Strat Guest
    Message Count:
    > would this work?
    Don't know about that. Never used a GR-33, but am considering getting
    one now that I've become a bit more proficient with the GR-20. Have you
    tried e-mailing Roland to see what they have to say?
      • Advertising
  5. Peter Pan Guest
    Message Count:
    "Mr. Strat" <> wrote in message
    news:231120071328498832%...
    >> next
    >> its
    >> controler,
    >> would this work?
    I was at Sam Ash today asking them about the floor controler... they were
    clueless.. I did learn that when Roland made the GR 20, they cut corners,
    trying to make the guitar synth more affordable, hence, they removed the
    pedal board.
  6. Mr. Strat Guest
    Message Count:
    > pedal board.
    Oh yeah...they simplified it from the GR-33 for which you pay a price
    in versatility. I still think the sounds are great and it's been
    relatively painless to adapt.
  7. KennyB Guest
    Message Count:
    On Thu, 22 Nov 2007 21:43:37 -0500, "Peter Pan" <>
    >changes I need?
    I have a GR-20, have the same complaints many have, and dislike Roland
    very much because they forced this piece of crap on us. Sure, it has
    good sounds but they took away valuable programming that only costs a
    few pennies to keep. Pros will spend the money. I can't believe all
    the rave reviews the GR-20 got - they all must work for Roland, or
    they're all stupid. That's it - Roland thinks all guitar players are
    stupid! I bought it anyway because I could not find a new GR-33. I
    recently bought a Roland FC-300 foot controller so I could set up
    patches with real names (the biggest blunder Roland made with the
    GR-20). It works very well. Next is to try to use the expression
    pedals and control switches in the FC-300 so I can put the GR-20 aside
    and use only the FC-300 in performance. I hope they followed through
    with total midi command responses in that "effects pedal" mode. What
    were Roland engineers thinking when they designed in the ability to
    use an external effects pedal to select sounds simultaneously with the
    effects pedal patches? The units have totally different purposes and
    can't work topgether like that. What Earthly good is that??? So, we
    have to be creative in order to use their stuff. My next move will be
    an Axon driving a midi sound module - more expensive but it all makes
    sense! By the way, the FC-300 is very nice, and complete - a great
    addition to any midi environment. I hope this helps. Sorry for the
    ranting but somebody has to do it. Email me at
    to swap some ideas.
  8. Peter Pan Guest
    Message Count:
    Kenny thanks for the response. I read your posting a few times and I'm a bit
    confused:
    You purchased the FC 300, does it allow you to change the patches like the
    GR 33
      • Advertising
Share This Page
