Hi All Maybe a stupid question, but is there any way of grouping midi tracks in Cubase Studio 5 the same way as you can route audio tracks to a single group channel? I've got a 12 channel percussion section currently running on midi which I'd dearly like to be able to control the level of on a single fader. DC --
On Wed, 23 Dec 2009 17:13:05 GMT, "Django Cat" <> wrote: >Hi All > >Maybe a stupid question, but is there any way of grouping midi tracks >in Cubase Studio 5 the same way as you can route audio tracks to a >single group channel? I've got a 12 channel percussion section >currently running on midi which I'd dearly like to be able to control >the level of on a single fader. > >DC Simple: select all the tracks you want to group (in the mixer window) then right-click and select "link channels". No matter what channel fader you use, all the others will move with it
Re: Grouping Midi Tracks in Cubase Studio 5 Bas wrote: > On Wed, 23 Dec 2009 17:13:05 GMT, "Django Cat" > <> wrote: > > > Hi All > > > > Maybe a stupid question, but is there any way of grouping midi > > tracks in Cubase Studio 5 the same way as you can route audio > > tracks to a single group channel? I've got a 12 channel percussion > > section currently running on midi which I'd dearly like to be able > > to control the level of on a single fader. > > > > DC > > Simple: select all the tracks you want to group (in the mixer window) > then right-click and select "link channels". > No matter what channel fader you use, all the others will move with it > Brilliant! Thanks, Bas, yes that works - have a rockin' Christmas! DC --
