Hi all, After using VST5.1 for a number of years off and on (hobbyist)..I decided to upgrade to Cubase % essentials. Then software arrived today and installed fine. However, opening an instrument from the project menu shows Prologue only..no Halion. I think there's a number of internet posts relating to this but I can't find a solution. So, how do I access halion? Cheers, Paul win7 64bit
ubase 5 essentials that is. "Paul Burdett" <> wrote in message news:4ce39efc$0$29823$... > Hi all, > > After using VST5.1 for a number of years off and on (hobbyist)..I decided > to upgrade to Cubase % essentials. Then software arrived today and > installed fine. However, opening an instrument from the project menu shows > Prologue only..no Halion. I think there's a number of internet posts > relating to this but I can't find a solution. So, how do I access halion? > > Cheers, > > Paul > > win7 64bit >
Issue is now solved. "Paul Burdett" <> wrote in message news:4ce39f1f$0$25361$... > ubase 5 essentials that is. > > > "Paul Burdett" <> wrote in message > news:4ce39efc$0$29823$... >> Hi all, >> >> After using VST5.1 for a number of years off and on (hobbyist)..I decided >> to upgrade to Cubase % essentials. Then software arrived today and >> installed fine. However, opening an instrument from the project menu >> shows Prologue only..no Halion. I think there's a number of internet >> posts relating to this but I can't find a solution. So, how do I access >> halion? >> >> Cheers, >> >> Paul >> >> win7 64bit >> > >
On Nov 19, 7:23 pm, "Paul Burdett" <> wrote: > Issue is now solved. > > "Paul Burdett" <> wrote in message > > news:4ce39f1f$0$25361$... > > > > > ubase 5 essentials that is. > > > "Paul Burdett" <> wrote in message > >news:4ce39efc$0$29823$... > >> Hi all, > > >> After using VST5.1 for a number of years off and on (hobbyist)..I decided > >> to upgrade to Cubase % essentials. Then software arrived today and > >> installed fine. However, opening an instrument from the project menu > >> shows Prologue only..no Halion. I think there's a number of internet > >> posts relating to this but I can't find a solution. So, how do I access > >> halion? > > >> Cheers, > > >> Paul > How was it solved?
