Hard Drive Failure ?
Discussion in 'cakewalk.audio' started by NickPeter, Dec 8, 2003.
  1. NickPeter Guest
    Message Count:
    I think my WD 40GB hard drive may have gone south on me. I've spent the
    better part of the weekend trying to install XP on the WD HD in my new DAW.
    Sorry but this is gonna get a little lengthy.
    The hardware:
    Sonata case
    P4P800 mobo
    P4 2.8 x 800 w/ Zalman ALCU
    2 x 512MB Kingston CL2 DDR
    Powercolor Radeon 9200 SE 64MB AGP
    48x Mitsumi ATAPI CDROM
    Delta 1010
    I have tried innumerable methods to load the OS without success. The drive
    appears to be recognized properly by the BIOS. If I go into the BIOS and
    select the Primary IDE Master it shows the drive as being a WD400BB, DMA-5,
    etc.
    I first set up the BIOS to boot from the CDROM. Seemed to go OK (I had
    formatted the drive as NTFS while it was in my other machine.) WinXP copied
    a bunch of files and then rebooted. When it rebooted, it booted off the CD
    was back at the beginning like nothing ever happened. So I tried again.
    This time, when it rebooted, I went into the BIOS and switched it to boot
    off the HD. All I got was a flashing DOS prompt that would not respond to
    any keyboard input. So I reset it to boot off the CD and started over.
    This time when it rebooted I left the BIOS alone and just pulled the CD out
    of the drive. Same result, just a flashing DOS prompt. I tried several
    sets of cables just to be sure that was not the problem, but same result. I
    also installed my SCSI CDROM and installed the OS off that drive but still
    got the old DOS prompt.
    I tried installing off a Win98 boot disk per the instructions on the
    Microstuff web page but received the following message:
    An internal Setup error has occurred.
    Could not find a place for a swap file.
    Setup cannot continue.
    So I boot off the floppy again. I tried:
    dir c:
    Invalid drive specification
    dir d:
    dir e:
    (The drive has three partitions.)
    I tried fdisk and it reported that the drive had three partitions and that
    they were formatted NTFS. OK, so I downloaded the WD Data Lifeguard utility
    and copy it onto a floppy. Everything looks OK. But just in case, I use
    the WD utility to repartition and format the drive. Load the OS and get the
    So I pull the WD drive out and install it into my everyday machine as
    Secondary IDE Master. When I boot this machine the BIOS does not recognize
    the drive (even though this drive had been used with this CUSL2 mobo
    previously.) But when I get the system running, I go to My Computer and
    there is the WD drive. I click on the three partitions and view the
    properties and each state the hardware is operating properly. I tried
    screwing with the jumpers on the WD drive just in case there was a poor
    contact but that did not help. It is still not recognized by the BIOS
    So in desperation, I put another drive, a 40GB IBM into the new DAW. Boot
    from the CD and the OS loads flawlessly. And now the DAW is up and running
    with the IBM drive (which was going to be my data drive in the DAW.)
    So what on earth is wrong with this WD drive? It is not that old and has
    very, very low hours on it.
    Nick
      • Advertising
  2. kitekrazy Guest
    Message Count:
    Use the WD disk and use it to write O s to the drive and that will do a
    complete erase of the HD and start over.
    "NickPeter" <> wrote in message
    news:RwQAb.3553$...
    DAW.
    > The hardware:
    > Sonata case
    > P4P800 mobo
    > Delta 1010
    drive
    DMA-5,
    > etc.
    copied
    CD
    out
    I
    > dir c:
    > dir d:
    > dir e:
    utility
    the
    recognize
    running
    > Nick
  3. Organfreak Guest
    Message Count:
    On Sun, 7 Dec 2003 20:09:11 -0600, "kitekrazy" <>
    Yup, I went through almost exactly the same thing two days ago, and
    that was the solution. The drive had a corrupt boot sector as it
    turned out. I have ten new grey hairs.
    -OF
    >news:RwQAb.3553$...
    >DAW.
    >> The hardware:
    >> Sonata case
    >> P4P800 mobo
    >> Delta 1010
    >drive
    >DMA-5,
    >> etc.
    >copied
    >CD
    >out
    >I
    >> dir c:
    >> dir d:
    >> dir e:
    >utility
    >the
    >recognize
    >running
    >> Nick
  4. Jim McCrain Guest
    Message Count:
    On Sun, 7 Dec 2003 20:34:37 -0500, "NickPeter"
    I have had the very same problem with WD drives. (I never did get the
    last one to work!) Notice that I said the LAST one. I won't use WD
    discs anymore. I only use Maxtor or Seagate. I've never had any
    trouble with either of these two brands. They may cost a little more,
    but the aggravation factor is MUCH lower.
    Jim
    Remove SPAMGUARD from my address to reply.
      • Advertising
  5. Michael Guest
    Message Count:
    In <news:>,
    > a complete erase of the HD and start over.
    That'd be my suggestion. A full diskwipe, and start as fresh as you can.
    ((U))
    M
    > news:RwQAb.3553$...
    >> the better part of the weekend trying to install XP on the WD HD in
    >> my new DAW. Sorry but this is gonna get a little lengthy.
    >> The hardware:
    >> Sonata case
    >> P4P800 mobo
    >> Delta 1010
    >> The drive appears to be recognized properly by the BIOS. If I go
    >> into the BIOS and select the Primary IDE Master it shows the drive
    >> as being a WD400BB, DMA-5, etc.
    >> had formatted the drive as NTFS while it was in my other machine.)
    >> WinXP copied a bunch of files and then rebooted. When it rebooted,
    >> it booted off the CD was back at the beginning like nothing ever
    >> happened. So I tried again. This time, when it rebooted, I went
    >> into the BIOS and switched it to boot off the HD. All I got was a
    >> flashing DOS prompt that would not respond to any keyboard input.
    >> So I reset it to boot off the CD and started over. This time when it
    >> rebooted I left the BIOS alone and just pulled the CD out of the
    >> result. I also installed my SCSI CDROM and installed the OS off that
    >> drive but still got the old DOS prompt.
    >> dir c:
    >> dir d:
    >> dir e:
    >> and that they were formatted NTFS. OK, so I downloaded the WD Data
    >> Lifeguard utility and copy it onto a floppy. Everything looks OK.
    >> But just in case, I use the WD utility to repartition and format the
    >> drive. Load the OS and get the flashing DOS prompt.
    >> recognize the drive (even though this drive had been used with this
    >> CUSL2 mobo previously.) But when I get the system running, I go to
    >> My Computer and there is the WD drive. I click on the three
    >> partitions and view the properties and each state the hardware is
    >> operating properly. I tried screwing with the jumpers on the WD
    >> drive just in case there was a poor contact but that did not help.
    >> Boot from the CD and the OS loads flawlessly. And now the DAW is up
    >> and running with the IBM drive (which was going to be my data drive
    >> in the DAW.)
    >> and has very, very low hours on it.
    >> Nick
  6. Steve Karl Guest
    Message Count:
    You could also use ptedit.exe ( if you have partition magic )
    or possibly delpart.exe ... a free utility that sometimes can *nuke*
    a pesky partition that won't go away.
    sk
    "kitekrazy" <> wrote in message news:...
    > news:RwQAb.3553$...
    > DAW.
    > > The hardware:
    > > Sonata case
    > > P4P800 mobo
    > > Delta 1010
    > drive
    > DMA-5,
    > > etc.
    > copied
    > CD
    > out
    > I
    > > dir c:
    > > dir d:
    > > dir e:
    > utility
    > the
    > recognize
    > running
    > > Nick
  7. Kevin Perry Guest
    Message Count:
    Horses for courses - I've had more Seagate drives fail than any other brand
    I've tried. Everyone has a horror story about one brand or other.
  8. Glennbo Guest
    Message Count:
    The entity known as Kevin Perry, posted:
    >> the last one to work!) Notice that I said the LAST one. I won't use
    >> WD discs anymore. I only use Maxtor or Seagate. I've never had any
    >> more, but the aggravation factor is MUCH lower.
    > brand I've tried. Everyone has a horror story about one brand or
    > other.
    WD did at one time have some real problem drives out there. I had one go
    ka-chunk ka-chunk, and actually held the phone up to the drive for a WD
    support tech, who instantly recognized the death sound of their drives.
    They sent me a replacement drive that failed the same way within two
    months. I also had two other friends in the video biz see the same thing.
    I have 12 Maxtors in service ranging in age from a couple months to several
    years old, and never a hiccup.
    Remove YourHeadFromYourAss to Reply by email
    _______ _____ ___ _____ ____
    / ___/ / / __/ |/ / |/ / _ )/ __ \
    / (_ / /__/ _// / / _ / /_/ /
    \___/____/___/_/|_/_/|_/____/\____/
    Glennbo These go to eleven
    Non-Linear Sound http://www.soundclick.com/glennbo
    Hear My Music http://www.soundclick.com/jambits
  9. Kevin Perry Guest
    Message Count:
    And of course IBM had a run of bad drives. There are ranges that suffer
    widely, but some manufacturers just don't seem to get on with some people
    above and beyond this :)
  10. Paul Layman Guest
    Message Count:
    I worked for a company that supplies chips to all of the hard drive
    manufacturers. All take reliability very seriously. However, one
    of them always stood out in my mind as more serious about it than
    others. This happened to be Maxtor. I own about 20 drives. They
    are all Maxtor. I considered switching when they reduced their
    warranty to 1 year, but decided against it.
    Paul
    >>other.
  11. BlackHawk Guest
    Message Count:
    "Kevin Perry" <> wrote in message
    news:br25cv$26i79d$-berlin.de...
    go
    Someone oughtta say that the Service one receives is an important factor.
    On that score, IBM, WD, and Maxtor have had great service in the past; ....
    but no one talks ablut IBM lately.... those 60 GB hi-failure drives several
    years ago kinda put the damper on IBM for awhile....
    BUT, I also remember the troubles <now long since fixed> of WD and
    Maxtor<now fixed>.
    Bottom line, my recent (2 years) experience, both personal and reading here,
    is that if I get a bad Maxtor or WDC, a phone call will have a replacement
    on the way Immediately.... no waiting for the defective unit to be received
    by the company.
    I have 4 WDC 120 GB drives in short and long term use, and several 80 GB
    <boot> Maxtor drives.
    YMMV,
    Bob
    P.S. One shouldn't blame the companies for one's lack of good regular
    Backups.
    We all have "been there".... <sigh> ....
  12. owlbird Guest
    Message Count:
  13. Glennbo Guest
    Message Count:
    The entity known as BlackHawk, posted:
    > Backups.
    Backup?
    Is that the beeping sound big trucks make when not going forward? <g>
  14. Kevin Perry Guest
    Message Count:
    Nah, it's what a failing drive does to you...puts your back up.
  15. Martin Schiff Guest
    Message Count:
    IBM doesn't make PC hard drives any more. They sold that business to Fujitsu
    I believe.
    -- Martin
    "BlackHawk" <> wrote in message
    news:...
    > go
    people
    several
    > Maxtor<now fixed>.
    here,
    received
    > by the company.
    > YMMV,
    > Bob
    > Backups.
  16. Gerry Peters Guest
    Message Count:
    I've had IBM, Maxtor, and WD drives fail. It seems all the HD manufacturers
    go through periods of bad drives. I guess the only ones who can give
    reliable up to date info on this are poeple that deal with a large quanitiy
    of drives or have some latest inside knowledge.
    Unfortunately this information seems to change every few months, making it
    difficult for guys like us to really know what dogs to avoid at any moment
    in time. I remember many years ago when HD's have lifetime warranties, then
    it went to 5 years, 3, 2, 1 year, now about 3 months. That ought to tell you
    something.
    Always backup, expect a HD to fail, it's likely it will. Make sure you have
    a new HD image any time you make changes to your boot drive. Many times I've
    had HD's seem to fail, but after restoring an older disk image they were up
    and running, sometimes you'll need to use diagnostic software to zero a
    drive, other times the drive is unsalvageable.
    I have 4 computers networked and backup every night to a 120 gig HD using
    Vice Versa. It mirrows the entire HD or any specific folders you select.
    Once it's setup all you have to do is double click an icon and let it go. In
    addition I have images of all my C drives handy.
    I eventually Archive song project folders on HD's, I also double archive
    these folders on another HD in case the whole Archive drive fails. My next
    step will be to backup over the internet to HD in another city. Years from
    now we'll have every project we've ever done saved to our watch, that's a
    day I look forward to
    These threads are always interesting to me and I follow them, hoping maybe
    I'll make a good guess on my next HD purchase. It's a crap shoot guys, so
    you better backup
    Gerry Peters
    Midi Magic Studio
    http://gprecordingstudio.com
    Album Productions and Songwriter Resources
    "Martin Schiff" <> wrote in message
    news:...
    Fujitsu
    > I believe.
    > -- Martin
    > news:...
    one
    > > go
    suffer
    > people
    factor.
    > several
    > > Maxtor<now fixed>.
    > here,
    replacement
    > received
    > > by the company.
    > > YMMV,
    > > Bob
    > > Backups.
  17. Sharon Memphis Guest
    Message Count:
    news:...
    several
    How ironic, just had an IBM drive flat out die on me tonight, thank God I
    ghosted it over the weekend !! We have 16 drives in service at the moment
    all Maxtor except for two....now one IBM, better put the last IBM on life
    support, I'm gonna pull it real soon <g>.
    Outgoing mail is certified Virus Free.
    Checked by AVG anti-virus system (http://www.grisoft.com).
    Version: 6.0.547 / Virus Database: 340 - Release Date: 12/2/2003
  18. Paul Layman Guest
    Message Count:
    IBM got out of the business. I wonder why? ;-) Sold it
    to Hitachi who has had there own set of problems.
    Not as many a s Fujitsu though.
    Paul
    > news:...
    > several
  19. NickPeter Guest
    Message Count:
    Thanks for all the responses and sorry for my delay in not responding
    sooner. Apparently, a road crew cut the phone lines and my entire
    subdivision has been without phones (and internet connection) until this
    evening.
    I tried several of the suggestions but it looks like the HD is toast. The
    WD drive utility won't recognize the drive anymore. And the BIOS in neither
    of my machines will recognize the drive.
    It is a real shame because this drive has had so little use. I'm certain it
    has less than 20 hours on it.
    Nick
    news:...
    > news:RwQAb.3553$...
    > DAW.
    > > The hardware:
    > > Sonata case
    > > P4P800 mobo
    > > Delta 1010
    > drive
    and
    > DMA-5,
    > > etc.
    > copied
    > CD
    boot
    to
    > out
    result.
    > I
    still
    > > dir c:
    > > dir d:
    > > dir e:
    that
    > utility
    use
    > the
    > recognize
    Boot
    > running
    has
    > > Nick
      • Advertising
Share This Page
