Help! Laptop virtual synth / DAW advice needed!
Discussion in 'alt.music.synth' started by John Freal, Dec 13, 2004.
  1. John Freal Guest
    Message Count:
    I'm an old school keyboardist that just stumbled into a gig with a
    successful live show. I need a wide array of meat & potato patches,
    sequences, loops & custom sampled sound FX.
    I have no desire to hump 16 rack spaces of modules. And it all needs to fit
    in my large 4-door sedan.
    I'm thinking "virtual synths/DAW on a laptop". I own an M-Audio Keystation
    88 controller with USB & midi. I'd like to run one cable from my keyboard to
    the laptop for my sounds, and a stereo send out of the laptop for
    monitoring.
    I'd prefer to stay with PC as opposed to Mac.
    Questions: If cost were no object, (although I do have a $2500 laptop cap);
    What speed laptop?
    Off the shelf, or custom built?
    AMD or Intel?
    How much ram?
    Which midi/usb interface box?
    OS?
    Any all-in-one software you'd recommend? (i.e. Cubase, Sonar etc.)
    Obviously low latency is vital for playing real-time keyboard parts &
    triggering sound FX.
    Any other tips or anecdotes greatly appreciated.
    Thanks in advance!
    -Jake-
    Posted Via Usenet.com Premium Usenet Newsgroup Services
    ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
    http://www.usenet.com
      • Advertising
  2. reese thomas Guest
    Message Count:
    "John Freal" <> wrote in news:41be2293$1_2@127.0.0.1:
    > Keystation 88 controller with USB & midi. I'd like to run one cable
    > from my keyboard to the laptop for my sounds, and a stereo send out of
    > the laptop for monitoring.
    Sorry, wrong group, this is live sound reinforcement issues
  3. jtougas Guest
    Message Count:
    On Mon, 13 Dec 2004 17:19:50 -0600, "John Freal" <>
    >monitoring.
    >What speed laptop?
    Well, eMachines makes a 64-bit AMD based laptop, but they tend to be
    Russian Roulette on hard drive speed...
    ....so you're probably better off going with an AlienWare laptop, to
    make sure you get a good fast hard drive, if you're using any modules
    that load samples (or any other good reputable manufacturer that'll
    let you choose drive speed... Toshiba doesn't *usually*, Dell does on
    some, I'm not sure about any others).
    >AMD or Intel?
    Audio and the 64bit AMD tend to get along pretty well, but the P4's
    are better for audio in general.
    >How much ram?
    I'd opt for at least a full gig...
    M-Audio MIDISport 2x2
    >OS?
    If you'd rather stick with a PC, you're pretty much limited to XP (if
    you were geek enough to run Linux, you know what kind of machine you'd
    need :) ), though it wouldn't hurt to try and find XP Media Edition
    (supposedly, it's 'optimized' for media, but I don't buy it... I
    haven't noticed it showing up as an option on many of the DAW
    websites...)
    You might want to take a look at some of the hardware VST Host
    solutions, so you can avoid lugging a laptop around.
    http://www.museresearch.com/receptor_overview.php
    Cheers
    jtougas
    listen- there's a hell of a good universe next door
    let's go
    e.e. cummings
  4. John L Rice Guest
    Message Count:
    If you need any lengthy, complex or synchronized sequences, a laptop is
    probably your best bet, otherwise I think you should take a serious look at
    just getting the Roland Fantom XR module :
    http://www.rolandus.com/Multimedia/Flash/fantomxr/
    It comes with lots of great sounds, a ton more can be added with plug in ROM
    cards :
    http://www.rolandus.com/products/subcategory.asp?catid=13&subcatid=55
    and it's a sampler so you can record your own samples for specific sound
    effects, etc.
    It's under $1400 street price so you'll be able get it plus two additional
    ROM sound cards and some more user memory for under $2000.
    Throw it in a light 2 space rack, grab your controller keyboard and you
    should be good to go. Make sure to listen to the samples on the websites,
    it sounds really great.
    Best of luck and congrats on the gig!
    John L Rice
    "John Freal" <> wrote in message
    news:41be2293$1_2@127.0.0.1...
    fit
    to
    > monitoring.
    cap);
    > What speed laptop?
    > AMD or Intel?
    > How much ram?
    > OS?
    > Thanks in advance!
    > -Jake-
      • Advertising
  5. Guest
    Message Count:
    Apologies to all in the irrelevant newsgroups. The original poster
    apparently doesn't understand that broad cross posting is bad
    form, and if he's compelled to do it anyway, doesn't know how to
    concentrate replies to a single newsgroup that he actually reads.
    Anyway . . . .
    In article <41be2293$1_2@127.0.0.1> writes:
    to fit
    Have you looked at some of the new keyboard synths lately? Mighty
    impressive, and you don't have to fool with a computer. Just plug it
    in and play. Get one with a sampler at heart and you can load your
    custom samples and sound effects too.
    I'd avoid taking a computer on a day-to-day gig. Too much haywire,
    takes too long to load samples, too much to get wrong, too much to go
    wrong. It might work out after you've lived with it for a year (that
    will give you a year's worth of use before you feel the urge to
    upgrade) but it sure doesn't make sense to me to go out and buy what
    are essentially the components of the sampler/synth you really want,
    then have to accessorize and configure it yourself. You have to be
    pretty darn good to do that, and here you are asking which computer to
    buy.
    Don't do it.
    I'm really Mike Rivers ()
    However, until the spam goes away or Hell freezes over,
    lots of IP addresses are blocked from this system. If
    you e-mail me and it bounces, use your secret decoder ring
    and reach me here: double-m-eleven-double-zero at yahoo
  6. John Freal Guest
    Message Count:
    <> wrote in message
    news:...
    My sincere apologies for cross posting, I'm new to Usenet.
    Thank you for not flaming me into worthless particulate.
    -Jake-
    > Anyway . . . .
    > to fit
    > buy.
    > Don't do it.
      • Advertising
Share This Page
